Question about HP Compaq FS7600 17" CRT Monitor
Compaq Monitor Model 7600
Please help I have developed cataracts need to dim the monitor! Please tell me how to do this. Miss-placed the book.
Thanks so much for your help and time.
  • Roselee Irvine
    Roselee Irvine Aug 15, 2008
    Thanks so much and ( IT IS FIXED) appreciate your time and have a wonderful summer.
    God Bless.
    from lilrose
Dear Lilrose: Here's how to dim your FS7600 monitor. Press
"menu" on the front of your monitor. Now press + button until
the icon just to the very right of the 12 0 clock position is
highlighted. Now press select. A graph will appear and by
pressing the minus button the screen should start to darken.
When you are satisfied, push the menu button to escape.
Hope this helps.
Radial
Posted on Aug 15, 2008
Compaq FS7600 service manual, can't find on internet
i want schematic diagram of FS 7600 Compaq Monitor please me a copy of circuit diagram.
Aug 15, 2012 | HP Compaq FS7600 17" CRT Monitor
Compaq FS 7600 - display - CRT - 17" driver
click start control panel you will see thre options change theme change desktop background and adjust screen resolution then select resolution from the drop down list you can adjust to your preffered settings 1024x 768 is usually recomended (you have not stated your problem)
hope this helps
Sep 22, 2011 | HP Compaq FS7600 17" CRT Monitor
My brother experienced a power hit today. No UPS. Anyway, his monitor indicator light is not green, but an brownish orange. Does this only indicate standby mode because the PC isn't booting either....
It means it is not getting the video signal from the PC. You should try this monitor with another PC or another monitor with this PC. You may have problrm in the PC.
Feb 26, 2011 | HP Compaq FS7600 17" CRT Monitor
My compaq n610c screen becomes very dim, with many small short lines blocks. Turn black after being on for a while. Please help. chee
I think the picture board on your monitor is malfunctioning that is why it brings those small lines on the screen, and since it even goes black after a while, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Apr 23, 2010 | Compaq EVO N600C (Refurbished) 14.1" LCD...
About how old is a 17" compaq 7600 monitor?-any reliability issues with this one?
This monitor is 2-3 years old.
There are not any real reliability issues, but it is a crt monitor, meaning that it uses more power then todays lcd monitors.
Its worth about $50 used.
Jan 03, 2010 | HP Compaq FS7600 17" CRT Monitor
''out of frequency range'' on crt monitor
Go into your "Device Manager" in Windows and find out if your HDTV monitor is still installed. Delete the settings under the monitor tab and reboot the computer. With any luck the reboot will cause Windows to re-detect your current monitor and install the proper settings. A similar process may need to be followed with your video card driver as well. CAUTION: Make sure you have a disk or some means of installing a copy of your video card driver before you delete out the currently installed one.
Hope this helps!
OpenSource13
Apr 05, 2009 | Compaq Computers & Internet
My laptop, hp compaq nx6110 has a screen problem. Its dim
OS?
Check the "Power Options" in your "Control Panel" (classic view). For whatever option you have picked, click "Change plan settings". There you can either "Restore default settings", or manually "Change advanced settings". If you choose "advanced settings", look for "Display" / "Display brightness".
Feb 26, 2009 | HP Compaq nx6110 PC Laptop
Microphone does not seem to be working
The microphone connector is on the rear of the monitor, and you need to connect it to your computer's microphone input jack. The cable is the same kind you would use to connect the audio output jack to the input on a set of computer speakers. Once the microphone is plugged in it works just like any standard microphone. No special drivers are needed for the monitor, but you do need to be sure that the proper drivers for your computer's sound devices have been installed.
If this solution has been what you needed, please take a moment to rate it. Thanks for asking here!
Feb 22, 2009 | Compaq Computers & Internet
Compaq presario V1000 display problem
Is this only when you are operating from batteries or also on AC (through the adaptor) as well?
You should also establish what the complete model number of your system is, there are many in that series:
http://h10025.www1.hp.com/ewfrf/wc/prodTopCategory?product=406879&lc=en&cc=us&dlc=
If the problem is only happening on battery operation, the pack may have one or more failed cells, reducing the available voltage below the level that the display inverter needs to keep the fluorescent backlight at full brightness.
The display is the power hungriest part after the processor itself.
The pack should have a rating on it and any multimeter (everyone should have one-digitals are dirt cheap) will tell you if the pack is charging up to its rated voltage.
May 05, 2008 | Computers & Internet
There are usually controls, button or knobs, to "Stretch" "Move" "Pincusion" and others... have you tried this, as this is what it "Sounds" like to me from ya description? If there are NO controls on the front to accomplish this task, at the REAR of the unit there should be controls marked to show the function. Below is a link where ya will find a Manual that may help ya. http://www.retrevo.com/s/HP-7600-Monitors-review-manual/id/281ci552/t/1-2/
Aug 06, 2007 | Compaq FS7600 17" Flat Glass Monitor
HP Compaq FS7600 17" CRT Monitor Logo
168 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
