Question about Canon imageCLASS MF5750 All-In-One Laser Printer
MY CANON MF5700 PRINTER SAYS CHECK PAPER SIZE
  • iswest Jul 01, 2008
    impageclass 5750 displays check paper size
  • Anonymous May 13, 2009
    I can not seem to clear all it is saying no jobs in print?????? This happened for 3 months when I first purchased and hasn't happened since (past 2 years)
Actionguy describes a solution where you: hit menu then # to get into service mode, scrolled to CLEAR, hit set, scroll to ALL and hit set again
You can also clear the printer's memory of the task that's causing the problem by pressing on the 'eye' button that gives the list of print/copy/fax tasks. press OK to select what kind of task you have, then choose your task to delete it. Finally press OK and Yes (minus) to clear it. Then, you can unplug the printer briefly to clear the error and it will start without the bad job and the error message.
Posted on Dec 15, 2008
  • 15 Answers
I just ran into this today. The fax was trying to print a legal size page even though RX reduction was turned on and on auto fit. I tried manual reduction sizes, turning it off/on but still would try to print legal size. I even tried taping pages together to make a legal size page and feeding it through the manual feed but it still said 'check paper size'.
I finally had to do a full clear/reset by hitting menu then # to get into service mode. I scrolled to CLEAR and hit set, scrolled to ALL and hit set and that cleared the fax that was screwing things up. I haven't tried sending it a legal size fax yet to see if it does the same thing.
Posted on Aug 12, 2008
I just wanted to say thank you for posting this, this just fixed my problem right off. If this wasn't posted I'd still be spending time messing with it.
Posted on Jul 04, 2009
Press
Menu
> until clear indicated.
press ok
wait.............
All Fixed
Posted on Jan 31, 2010
I HAVE HAD THIS HAPPEN ON TWO OCCASIONS, SEVERAL MONTHS APART. THE ONLY SOLUTION THAT WORKED FOR ME WAS TO PULL THE ELECTRICAL PLUG OUT OF THE UNIT AND LEAVE IT THAT WAY OVER THE WEEKEND. RECONNECT AND IT WORKS NORMALLY. IT WILL NOT WORK IF YOU LEAVE THE PLUG OUT JUST OVERNIGHT. I'M GUESSING 2-3 DAYS.
Posted on Sep 09, 2008
SOURCE: have canon mf5700 says check paper size and only prints one page of several page job
Unable to clear the store with this error showing!.. There were no jobs to clear.
Well, if you unplug the power and allow the unit to discharge,(maybe overnight), the error situation clears.
Posted on Mar 18, 2008
Unplug the printer and take outside,
Then blow the inside out with a airline
This solved the same problem with had with our printer
Posted on May 14, 2008
SOURCE: Canon MF5700 Series all in one printer
Throw it in the trash. It's a piece of shi*. I'm sick of mine.
Posted on Sep 18, 2008
SOURCE: Canon MF5700 Printer Error - It says change paper
press the menu then # key the m/c shows sssw then ok key, press the left or right key upto the display shows clear then ok key,press left or right key upto yhe display shows all then ok key,the wait the m/c reset itself switch the m/c off then on
Posted on Sep 11, 2009
  • 105 Answers
SOURCE: Canon MF5700 Printer Error says
thanks for contacting in fixya
u need to switch off ur printer and again switch on if this problem persists then let me know
regads
john symester
Posted on Nov 03, 2009
Canon MF5700 Printer Error says "Check Paper Size" and won't printHow do I fix this?
regads
john symester
Nov 03, 2009 | Canon imageCLASS MF5750 All-In-One Laser...
Canon MF5700 Printer Error - It says change paper size, how do I clear the error?
Aug 06, 2009 | Canon imageCLASS MF5750 All-In-One Laser...
Have canon mf5700 says check paper size. Powering off doesn't help Changing trays does not help. After powering on again it prints a test page and then gives the warning again.
You need to remove paper tray, and unplug canon. Leave it this way overnight, and in the morning, reinsert the paper tray, and plug back it. This should effectively reset the machine, and clear that error. It worked for me!
Mar 06, 2009 | Canon Office Equipment & Supplies
Problem in canon
i found a solution for printing with Canon MF 3110
1- Download Driver For MF5730/5750/5770 For Vista 64-Bit
File Name : L7602ENx.exe
http://software.canon-europe.com/products/0010260.asp
Follow These Steps
1- Add Printer
2- add a local printer
3- Use an existing Port : Choose : USB ( Virtual Printer for USB )
4- Have Disk
5- Locate the File Name : MF5700AK.inf
6- Printer Name : Change From Canon MF5700 Series To Canon MF3110 Series
7- Print Test Page
it Work for me on Vista Home Premium SP1 64-Bit
P.s
still Cant Manage to use the Toolbox 4.9.1.1.mf04 for Scanning ( Any Ideas ? )
Oct 22, 2008 | Canon MF3110 All-In-One Laser Printer
Am have Problem with Canon MF5700.
hey, I keep getting a paper jam message but there is no paper jam. Opening the cover does not reset, nor unplugging the machine. Bob
Jul 02, 2008 | Canon imageCLASS MF5730 All-In-One Laser...
Jun 25, 2008 | Canon ImageClass MF5770 Laser Copier...
Have canon mf5700 says check paper size and only prints one page of several page job
go to control panel> printers> and make sure in preferences its set to LTR (letter)
Hope this helps
Dec 21, 2007 | Office Equipment & Supplies
If your alarm light is flashing and your printer will not print, press the "copy" button to get the device into the copy mode, once the copy button light is on, press the "Status Monitor" button. The LED panel will then show two lines of words: Line 1 "COPY STATUS" and Line 2 "SELECT JOB TO CANCEL"; then hit the Set button and the screen will show you what print job which has jammed the printer and you then press the - (Minus) button to clear the job. Open and close the front panel and the printer should reset and the warning light go off.
I had trouble locating the problem because my machine tends to stay on the Fax mode and when I pushed the Status Monitor button I would only get information about fax jobs.
Hope you have already figured out the problem. I thought I had better tell someone so I will remember the next time I try to print a job which requires a different size paper than what I have in my printer.
Blessings!
tdocdaws
Oct 16, 2007 | Canon imageCLASS MF5730 All-In-One Laser...
Canon imageCLASS MF5750 All-In-One Laser Printer Logo
4,909 people viewed this question
old marine
old marine
