Question about HP PSC 1315 All-In-One InkJet Printer
Hp printer will not show me ink level
Please provide us setup of hp officejet 4200 series
Posted on Jun 23, 2008
Hp photosmart touchscreen not working how can I check ink levels
If you have it connected to a computer then the HP utilities should be able to show the ink levels. You can also check the printer properties in the driver for a maintenance tab that should show ink levels as well.
Jul 25, 2015 | HP Photosmart D7260 Printer
Hp officejet 4620 does not print with starter cartridge
If printer is in warranty, demand for replacement.
1. Check ink levels in printer..if levels are showing, take out all ink cartridges refill them.
If levels are zero, go for new cartridges.
2. If ink level are showing in printer & physically cartridges having ink, then problem with print head, try to clean the clogged nozzles.
Nov 16, 2014 | HP Officejet 4620 e-All-in-One Printer,...
Hp 6515 cartridge shows low after a refill
There is no such mechanism to detect ink levels in your printer., it wont detect if adding more ink in it., it will detect only new cartridge when you replace it., printer shows estimated ink levels as per the print outs. This is hp trick to aviod refill &non hp consumables...
Sep 30, 2014 | HP Photosmart 6515 Wireless Color All In...
How do i check my ink levels on hp officejet 4215 printer
ideally diagnostics should return the info about ink levels.
but in case they dont you can try below
1. Hp Solution Center > Settings > print settings > printer toolbox > Estimated Ink level
2. go to control panel->printers->go to priinter properties it should show ink levels
Apr 11, 2012 | HP Officejet 4215 All-in-One Color Photo...
How can i check which ink are out
Your printer should have come with a disk. This disk would have installed the necessary program that runs printing jobs, as well as keeps track of the ink level. Locate this program on your computer (may be under All Programs, Accessories under the Start Menu).
If not, Go into the Control Panel: (see below)
Above, you see "Hardware and Sound"; and below that shows "View Devices and Printers. Click on this. It will then bring you into the below dialogue box, of which shows any and all printers currently installed and which are being used. (see below)
Once you have located your printer here - (name etc). Go into your Start Menu: In the Search Box at the bottom type "programs"; look for the words "show which programs are installed on your computer", should be the fourth in the list. Below is what the list will look like. Find your printer here to ensure it's installed.
Once you have determined it's installed, you need to locate the printer program in your file system. Once you retrieve this, click it to open it. The program should allow you to view the ink levels. With most printers, when ink is low it will automatically open a dialogue box showing the ink levels for each cartridge. If you're printer is not equipped with this feature, then the only way to know if any need changed is when printing a document, and any color is not present.
I apologize for such a long response, as I wanted you to know how to access these files. If you are printing, and all colors appear to be present, without fading, or "blotchy" spots, then your cartridges are still good. You should be able to do a print test (calibration or alignment test) to determine this as well.
Please let me know if you need further assistance.
carsandcomps,
Guru, Premium Expert, Phone Support, Live Chat @ Fixya.com
Jun 27, 2011 | HP Officejet 6500 Wireless All-in-One...
Can't find tool box to check ink level - HP 6310 using Vista 2007
doesnt matter most printers have a feature of their own to check ink levels.
press the setup button on the printer and scroll down(with the arrow buttons) till you get tools press ok and now scroll through until you get ink level and select it by pressing the ok button,walla you should have your ink levels in front of you.
Now about the hp solution centre/hp director icon on your desktop (if you have installed the software).
Click on settings and click on printer toolbox and now check your estimated ink levels it will show the ink levels of the printer cartridges.
May 26, 2009 | HP OfficeJet 6310 All-in-One Printer...
Estimated ink levels are incorrect
The simple solution is to buy the HP cartridges. Often times,.. MOST times, aftermarket ink cartridges and refill kits are an inferior product. The difference is not always noticeable right away, but almost always rears it's head in the end. This is usually due to the ink being of a different viscosity than the original ink. Which leads to sloppy prints, sensor errors, leaky or dead jets.
Personally I recommend everyone buy Laser printers. With prices where they are these days, there is no reason for anyone to buy an inkjet printer. Lasers will cost more up front, but are much cheaper per page and generally longer lasting.
Feb 15, 2009 | HP PhotoSmart C4280 Laser Printer
Can't find ink levels for my HP Deskjet 5940
The installation disk for your printer has a setup wizard that monitors your ink levels in your printer. Go through the installation again as it will not hurt anything and you should find it on one of your pop up screens that it leads you to.
Jan 14, 2009 | HP Deskjet 5940 Photo InkJet Printer
Not showing ink levels
Your Printer ink is wasted or you have a problem with the ink cartridges...(The printer head might be damaged)
<PLEASE RATE ME AS "FIXYA" for my help.........................>
Jul 30, 2008 | HP DeskJet F380 All-In-One Printer
Ink level
1. First go to your HP Solutions Center (for a PC it's START --> PROGRAMS --> HP --> HP Solutions Center
2. Once that comes up click on SETTINGS --> STATUS --> VIEW INK LEVELS
3. To set your computer up to automatically tell you the ink levels everytime you print, then click CONFIGURATION and check the box that says "Display Ink Status Window", click the APPLY button.
Mar 19, 2008 | HP Photosmart C3180 All-In-One InkJet...
HP PSC 1315 All-In-One InkJet Printer Logo
95 people viewed this question
Seeker5211
Seeker5211
