Question about Bugaboo Cameleon Jogger
Chassis won't lock into position
Hi - the frame of my cameleon won't snap into position.  When I lift up the frame by the handle, the front and rear wheel axles collapse towards each other, making me nervous that if I put my son in the stroller and need to go over a curb, the whole thing will collapse.
    Problem Solver:
  • 19 Answers
Don't worry, this is normal. once you lock the seat into place, the front bar stays put, even if you hop a curb.
Posted on Jun 28, 2008
How do i remove the whole diff and IRS suspension in au falcon intact
jack up car, fit safety jacks at each side of frame well in front of rear wheels, remove tail shaft , place floor jack under rear axle housing and jack up , but not lifting off safety jacks.remove brake lines, remove rear shocks, remove drag links ect from chassis frame, lower and remove jack, wheel out rear axle.
Sep 27, 2016 | Ford Falcon Cars & Trucks
How to belt replace instructions
Hi! Below are instructions to replacing the belt on a Hoover U5064-930.
Disconnect cleaner from electrical outlet.
1. Place handle in operating position and turn cleaner over so bottom side is up.
2. To remove bottom plate, insert end of flat screwdriver into wide area of right-hand slot and push handle of screwdriver to the rear.Repeat in left-hand slot.
3. Lift extension of bottom plate, rotate plate and remove from cleaner body.
4. Remove agitator and broken agitator belt.
5. Slip agitator through new belt. (With lettering toward outside of cleaner) and position belt in belt guide. Push end of belt into opening in cleaner body. Reposition agitator making sure to align flat sides of projection on belt end of agitator with flat sides of slot in cleaner body.
6. Place the three tabs on bottom plate into slots in front of cleaner body. Snap bottom plate into place over agitator.
7. Remove hood by turning cleaner over and removing nozzle control knob on front of hood -- grasp knob and pull up.
8. Place handle in operating position and turn cleaner over. Insert end of flat screwdriver into one of the four slots beside an arrow on bottom of cleaner.
9. For slots nearest the rear wheels, push handle of screwdriver toward cleaner handle; for remaining two slots, pry outward to release latches.
I0. Turn cleaner over and lift off hood.
Il. Stretch new belt onto motor pulley.
Extra effort may be required to stretch new belt onto pulley.
Turn agitator, making sure the belt is not pinched between agitator and cleaner body. The belt must rotate freely inside the belt guide. If agitator does not turn, remove bottom plate and reposition belt in belt guide.
Hope this helps!
Aug 05, 2014 | Hoover Platinum Lightweight Upright Vaccum...
Hoover cleaner model u5057-930
Hi! Below are step-by-step instructions on how to change the belt on your U5057930.
Turn agitator, making sure the belt is not pinched between agitator and cleaner body. The belt must rotate freely inside the belt guide. If agitator does not turn, remove bottom plate and reposition belt in belt guide. Hope this helps. If you have further questions feel free to reach out to us hear on Fixya!
HHdedd
Aug 02, 2014 | Hoover Vacuums
Remove front tire on lawn mower
Jill,
If the tire has a hole have you considered a Plug?
If thats not an option before you can pull the tire off, there should be a small snap ring holding it in place. please use blocks to block the tires and do the following.
  • Park the lawn mower on a level surface, then place the wheel chocks in front and behind the rear tires.
  • 2Place the jack under the frame at the front of the mower. Raise the mower up and place the jack stands under each side of the frame. Lower the jack until the mower frame sits firmly on the jack stands
  • 3Remove the plastic cap in the center of the wheel by hand; this should expose the snap ring holding the wheel to the axle.
  • 4Pry the snap ring off the axle with the flathead screwdriver. Slide off the washer, wheel and the shim washers from the axle.
    To replace tire follow steps 3 and 4 in reverse order. place shim washers back on and then wheel and then snap ring, etc...
    hope this helps
  • May 29, 2012 | John Deere Garden
    I have the 3d pram system have they ever been recalled mine keeps closing even when my child is in it
    This pram has not been recalled as far as I am aware. If the pram is collapsing when in use, this sounds like the arms either side are not clicked into position properly when this has been opened. If you follow the frame from the handle toward the front wheel, at the bottom just above the wheel, there is a catch that the arms should click into when opened, if this has not been done properly, this may prompt the pram to try to collapse. Either that or there could be a problem with the catches. I would suggest that you have the chassis looked at to ensure that there is no fault with the chassis.
    I hope this helps.
    Nov 22, 2009 | Baby Gear
    The function that rsiaes and lowers the vehicle doesn't work,
    Lifting
    The following instructions must be carried out before raising the vehicle off the ground.
    • Use a solid level ground surface.
    • Apply hand brake.
    • Select 'P' on automatic gearbox selector.
    Note: If the propeller shafts are to be removed, reference must be made to the relevant operation. To avoid damage occurring to the under body components of the vehicle the following jacking procedures must be adhered to.
    DO NOT POSITION JACKS OR AXLE STANDS UNDER THE FOLLOWING COMPONENTS:
    • Body structure other than approved jacking points
    • Bumpers
    • Fuel lines
    • Fuel tank
    • Brake lines
    • Front or rear suspension arms
    • Transfer box
    • Steering linkage
    • Front or rear differential units
    • Engine sump
    • Automatic gearbox
    NOTE: For certain repair operations, it may be necessary to support the engine under the sump. In this case, a block of hardwood or a rubber block should be positioned on the jack lifting cup to protect sump. Vehicle jack
    The jack provided with the vehicle is only intended for use in an emergency, for changing a tyre. DO NOT use the jack for any other purpose. Refer to Owner's Handbook for vehicle jack location points and procedure. Never work under a vehicle supported solely by the vehicle jack.
    Hydraulic jack
    A hydraulic jack with a minimum 1500 kg, (3,300 lbs) load capacity must be used.
    WARNING: Do not commence work on the underside of the vehicle until suitable axle stands have been placed in their correct position. Always chock the wheels when jacking. The handbrake may be ineffective when the wheels are off the ground. Raising and supporting the vehicle
    To assist in raising the vehicle, jacking points are provided as shown in the following illustrations.
    Raising the front of the vehicle
    Apply handbrake, select 'P' on automatic gearbox selector and chock rear wheels.
    Axle stand positions - front
    Raise vehicle to enable axle stands to be positioned under, either, the front sub-frame, or the recommended customer jacking points.
    CAUTION: Place a piece of hardwood or a rubber block between each axle stand and the jacking point to avoid damaging the body / component. If the propeller shafts are to be removed, select NEUTRAL in the main gearbox.
    Carefully lower jack until vehicle sits securely on axle stands.
    WARNING: Always support the vehicle on axle stands when using a jack.
    Before commencing work on underside of vehicle re-check security of vehicle on stands.
    Reverse procedure when removing vehicle from stands.
    Raising the rear of the vehicle
    Select 'P' on automatic gearbox selector and chock front wheels.
    WARNING: Always chock the front wheels when jacking the rear of the vehicle.
    Axle stand positions - rear
    Raise rear of vehicle to enable axle stands to be positioned under the rear sub-frame. Alternatively, the axle stands may be positioned under, either, the recommended customer jacking points or the front mounting points of the rear sub-frame.
    CAUTION: Place a piece of hardwood or a rubber block between each axle stand and the jacking point to avoid damaging the body / component. If any damage occurs to the washers on the front mounting points of the rear sub-frame, then the washers must be replaced. Carefully lower jack until vehicle sits securely on axle stands.
    WARNING: Always support the vehicle on axle stands when using a jack. Before commencing work on underside of vehicle re-check security of vehicle on stands.
    Wheel-free lift
    The following warning must be read before attempting to lift the vehicle.
    WARNING: The vehicle cannot be supported safely in a wheel-free condition using the wheel-free facility of a four post ramp, and under no circumstances must this method be employedA wheel free condition may only be achieved on a four post ramp by raising each end of the vehicle and positioning axle stands beneath the recommended customer jacking points.
    CAUTION: Place a piece of hardwood or a rubber block between each axle stand and the jacking point to avoid damaging any components. If the propeller shafts are to be removed, select NEUTRAL in the main gearbox. WARNING: The front and rear suspension lower arms must NOT be used as lifting / jacking points. Alternatively, support the vehicle on an approved two post lift with the arms of the lift beneath the recommended customer jacking points.
    CAUTION: Place a piece of hardwood or a rubber block between the lifting equipment and the jacking points to avoid damaging any components. If the propeller shafts are to be removed, select NEUTRAL in the main gearbox.
    Oct 04, 2009 | 2003 Land Rover Range Rover
    How do I collapse bugaboo stroller
    take off the basinette or seat
    then, there are 2 knob, sticking out of the sides of the frame, about 6 inches below the handle, from the normal pushing position, hook yr fingers round them and slide them up the frame towards the handle
    the handle will drop, then just up the frame from the cross bar under where the set is.
    easy once you know how
    if it still don't work, go to your local park and accost the nearest person with a bugaboo and ask for some help - there'll be hundreds of them!
    Jun 21, 2009 | Bugaboo Frog Stroller
    Hi, I have a peg perego, single child stroller, standard, Not sure which model. It has just a bar not a tray. Anyway, I CANT figure out how to fold it. Theres a carrying handle on the side so I know it...
    Hello, if this is an umbrella type stroller, you first release a catch on both handles to unlock the frame. These catches are located on the front and can be pulled up with your fingers. If you watch, they release the bottoms of each side from the front. You then pull the handle or lever located on the cross bar at the back up toward you. Thus collapses the frame as the wheels come together and the stroller then locks closed in the standing position and can be carried by the handle on the side. Greetings from Oz.
    Dec 14, 2008 | Peg Perego Aria MT - Toffee Standard...
    How to fold bugaboo camaleon to fit the bugaboo travel bag
    Put the seat in first (upside down, with the back of the seat facing up). Then put the collapsed chassis (with the large rear wheel taken off) on top of the seat. Make sure the front wheels are facing up. The handle bar goes towards the skinnier part of the travel bag.
    Jun 21, 2008 | Bugaboo Cameleon Jogger
    How do I fold my Zooper Sport?
    OK, I finally figured out how to fold & unfold this ******!
    To fold: Stand behind your stroller. Go to the joint in the middle of the push handle. You have to simultaneously push up on the button underneath the joint and pull back on the little trigger at the front of the joint. I've found that this will require both hands. Doing this will unlatch the joint, and you now need to push it forward to fold the handle into a "V" shape. Now look down to the crossbars just above the rear wheels, and you'll see a handle (kind of like on a sutcase) above a sort-of triangular-shaped piece of plastic. Lifting up on either of these will collapse the frame the rest of the way. Push the rear wheels as far forward (toward the front wheels) as you can, and it will latch shut. If you swivel the front wheels around to the rear, the stroller will stand on its own
    To unfold: From above and behind your folded stroller, with it standing on its front wheels (as described above), place both of your hands on the side/corner joints of the rear push bar. From the top, run both of your thumbs down the back side of both rails. Your thumbs should hit a 'bump', then a slightly smaller 'bump' immediately underneath the first. That second 'bump' on each side is the latch that keeps your stroller folded. Squeeze both the latches on each side with your thumbs, and you should hear them unlatch. Now the frame is free, and you have to push down on the suitcase handle in the middle while lifting up on the center joint of the push bar. Pull back on the push bar until it latches, and then keep pushing down on the suitcase handle until the whole thing latches.
    Jan 24, 2008 | Zooper CoolZone Sport Stroller
    Bugaboo Cameleon Jogger Logo
    421 people viewed this question
    Top Bugaboo Baby Gear Experts
    Jennifer Rock
    Jennifer Rock
    J.D. Browning
    J.D. Browning
    Jerry Greenberg
    Jerry Greenberg
    Are you a Bugaboo Baby Gear Expert? Answer questions, earn points and help others
