Question about Linksys Wireless-G WRT54GS Router (e125894)
EASYLINK ADVISOR WHEN INSTALLING ADVISOR, EVERY THING WORKS FINE UNTIL YOU SELECT MODEL NUMBER OF ROUTER. WHEN YOU PUSH NEXT BUTTON-NOTHING HAPPENS.
    Sergeant:
    Champion:
  • 427 Answers
Call linksys
Posted on Jun 23, 2008
I forgot my password for my wireless router, and can not sign my wifes new phone up on our wifi
When your phone asks for the password, out in the Encryption key. If you didn't print this out when you installed the router, insert the CD and install the Easylink Advisor, which wil then show up down in your taskbar in the bottom right corner of your screen. Open it, click on the Support tab, and it will show all your settings. For the password requested on your smartphone, enter the encryption key from your settings in EasyLink Advisor. That did it for me. Good luck!
Oct 22, 2011 | Linksys Wireless-G WRT54G Router
Wireless router is not working
Go to Here for Linksys EasyLink Advisor (LELA). With this software you can monitor the routers status and troubleshoot.
Most trouble shooting involves disconnecting the power to the cable modem and the wrt54 router for about 10-20 seconds. Then plug in the modem until it lights, then plug in the router. The Advisor will then get a new address.
It also shows a graphic picture of your whole system.
I have a wrt54 and use this whenever I have a problem. I fix it then turn it off.
Hope this helps.
Good Luck
Feb 19, 2010 | Linksys Wireless-G WRT54GS Router...
When running EasyLink advisor Router does not see internet connection, however the internet is working fine ?
Save yourself some valuable system resources and uninstall the EasyLink advisor.
Go to the Web interface for your WRT54GS router. If you didn't change the settings the address will be http://192.168.1.1
There is no username and the default password is admin. Make sure you create a strong password and change the default value. A strong password uses 6 or more characters and contains both upper and lower case letters, numbers, and special characters.
Once you are able to log into the web interface click on status. You will be able to see if you are connected to your ISP.
Once you are configured the way you want it make sure you back up your configuration by going to Administration/Management. Click Backup Configuration and follow the instructions.
Best of Luck.
Jan 18, 2010 | Linksys Wireless-G WRT54GS Router...
Internet connection
I think you have the software LELA (linksys easylink advisor) installed in your computer. Sometimes if it's not updated you it will prompt that you're not connected to the internet though you have internet access.
Solutions:
1) update your LELA - go to linksys.com/download
there's a field there that says enter model/serial number - just type in LELA - then click enter
- on the next page - click on get downloads then select version 3.1
- below there's an option that says download and drivers and you can see there LELA 3.1 just click on the download link and save it in your desktop folder
note: it's quite a big file - more than 200Mb
- before you install it make sure you uninstall the old LELA in your computer
- to uninstall it - just go to add/remove programs then remove linksys easylink advisor
hope this helps... Tech what you want
Dec 28, 2009 | Linksys Wireless-N WRT150N Router
Will a linksys wrt 100 router work with a macbook?
Should work with any os from 98+.
Latest software found here
http://update.linksys.com/lela/install/lela.exe
Apr 01, 2009 | Linksys Wireless-G Broadband Router
Exception from HRESULT: 0x88980406
There are known issues with the Linksys EasyLink Advisor (LELA). It is a very buggy piece of software that ends up causing a conflict with windows manager as indicated by your specific 0x error code. It is supposed to take the hassle out of setting up your wireless network using Linksys devices, but as you can see this isn't always the case.
The best thing to do, if you are technically inclined, is to uninstall LELA and manually configure your wireless network or hire a teenaged geek to do it for you. If you cannot do this, then try the following (no guarantees):
1. Download the latest version of LELA at http://update.linksys.com/lela/install/lela.exe and save it to your desktop.
2. If you're using XP then go to Start >> Control Panel, click on "Add/Remove Programs", find "Liknsys EasyLink Advisor" and uninstall it. If using Vista, go to Start >> Control Panel, click on "Programs", click on "Programs and Features", find "Linksys EasyLink Advisor" and uninstall it.
3. Reboot your computer.
4. Reinstall LELA by clicking on the LELA file you downloaded in step 1.
Mar 16, 2009 | Linksys Wireless-G WRT54G Router
Router not connecting
The problem here is that the WRT54GS is an old model, so naturally the installation CD is also old. This is especially a problem if you are running Vista. I ran into the same problem when I was installing my wireless card; my computer would detect it on boot up, but when I installed the drivers from the CD, it said the card wasn't plugged in.
The solution would be to download the lastest installation and driver files from the LinkSys website and use those instead of the installation CD that came with it. You may have to hunt for it, as some companies would rather push new products than update older ones, but since the router is still on the market, they should have the updated drivers and installation files.
Feb 11, 2009 | Linksys Wireless-G WRT54GS Router...
Linksys Power cut problem
With regard to power cuts, i highly suggests you to buy a UPS (Uninterruptable Power Supply) to prevent further damage to your router. You can simply reconfigure the wireless settings of the router by accessing the router's Setup Page. Go to http://192.168.1.1, go to wireless tab and you can change the network name as well as enable the wireless security.
Jan 19, 2009 | Linksys Wireless-G WRT54G Router
I would like to network our HP color laserjet printer through our Telus wireless router. I connected the printer with a network cable, to the router, but when I tried to install the printer through my...
What model of HP LaserJet do you have?
You will have to go into the configuration menu on the printer itself and set up the network connection.
I don't know what model you have, but here is a generic answer
Press the Menu Right until you find the HP MIO Menu - Select it. Next press the Item right button until you find the Cfg Network Card = No, - make it say yes by pushing the value right button, then push select to put an asterisk ( * ) next to it. Then press the item right button until you find Cfg TCP/IP = No, - make it say yes by pushing the value right button, then push select to put an asterisk ( * ) next to it. (assuming you are on a basic network) Last press the item right button and insert the following information.
IP Address: Not one already in use - generally 192.168.1.XXX (where XXX is some number between 2 - 253) Subnet Mask: generally 255.255.255.0 Gateway IP Address: Generally 192.168.1.1 or 192.168.1.0 or 192.168.1.254
Once you give it this information, print out the config page and it should be there. If this doesn't work, or you don't know how to find those numbers, I would be glad to help you further.
Dec 04, 2008 | HP Office Equipment & Supplies
Setup problem
It is possible that your setup may not be recognized by the advisor. Please provide the following information so that I can guide you towards setting it up manually.
1. Internet Service Provider
2. Number of computers.
3. Model number of your router.
Jul 11, 2008 | Linksys Wireless-N WRT150N Router
Linksys Wireless-G WRT54GS Router (e125894) Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
