Trouble with picture
We turned on our tv tonight and the screen has an arc on the top and bottom and the color is bad.
  • Winnie08 Jun 20, 2008
    Yes it does look 3D. I will try to get you some photos. The model number is: HCN4226WX/XAA
    Thank you so much for your fast reponse!
  • 8,617 Answers
Can you post a picture of your screen it sounds like convergence ICs. Also need your model number and does the picture look 3D
Posted on Jun 20, 2008
  • Sonny Berry
    Sonny Berry Jun 20, 2008
    If you cant load them here send them to slinteriors@yahoo.com and youre welcome I enjoy helping people I have been doing TV repair exclusively since 1977.
LG Projection TV Model# RT-49NA11T Green color gun shows bent arc on top & bottom.Red & blue guns are ok.How to adjust the green gun to remove the bent arc. This is causing picture shows mix...
This problems ur tv have can't not be fix by adjustment.The tv have a problems known as convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to repair the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 10, 2011 | Panasonic PT-53WX53 53" Rear Projection...
I just received a Hitachi 50" projection Tv from a friend. He was the original owner and it appears after 8 years the picture quality went bad. After spending some time with the operating manual it appears...
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Apr 23, 2009 | Hitachi 50GX49B 50" Rear Projection...
RCA HD52W59 Projection Big Screen TV
you have cold solder conections if you know how to solder you can fix it with a good light
Oct 14, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
60" TV has an arc in the pic
Check the fuses 1007 & 1405. If they are blown in will cause an Arc.
Note: If the screen shrinks/expands you may need a chip kit from www.repairkits.com
Aug 28, 2008 | Philips Magnavox 9P6034C 60" Rear...
Blue color is out of position
sure sounds like convergance problem
http://www.partstore.com/Part/Samsung/
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Jan 30, 2008 | Samsung HC-P4752W 47" Rear Projection...
Older Projection TV Hitachi 50ES1B about 1993?
Convergence amp ic's bad
Jan 07, 2008 | Hitachi 50UX57B 50" Rear Projection...
Trouble Aligning Colors
If the convergence is missing in the menu in screens,you have a bad reg ic on the convergence power supply the part number is 215530,the power supply is located on the black plastic above the right module with all the heat sinks
Nov 15, 2007 | RCA P56930BL 56" Rear Projection...
Arcing noise in big screen tv 1996 rca
Probable bad HV block Part # 205064
Possible bad CRT = disconnect HV leads one at a time from
HV block until arcing goes away
Please rate this solution..........
Nov 14, 2007 | Televison & Video
TV not working
Vertical amplifier s faulty.Replace and resolder surrounding area.
Oct 30, 2007 | Sony KP-51HW40 51" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
