Question about Maytag Dryers
Where is the thermistor on Maytag Neptune MDE5500 and how do I replace it.
  • 246 Answers
The thermisor is located on the blower housing. To access it, first unplug your unit. Next, remove the two screws holding the hinges on. You will be able to lift straight up on the door (slightly)and slide it out. There are two more screws straight across from the ones you just took out. Remove these as well. Now the grasp the front panel about an inch from the top. Using your thumbs, rotate the panel slightly towards the outside, this will let if off the clips. Now bring it forward about 45 degrees and you will be able to ligt the panel out of the way. Now on the the housing. If you look there is a white piece of plastic just under where your lint screen sits. This goes down towards the bottom of the dryer. The piece it sits up against is your blower housing. On the right hand side of it, you should see two peices with wires going to them. The white one is your thermal fuse. The other one beside it with the black or silver is your thermistor. Just remove the screws and install your replacement. (these are availible from local appliance parts stores or online from the manufactures web site). Good luck and I hope this makes it easier for you.
Posted on Jun 20, 2008
I can not get the Neptune MDE5500 in to the service mood
Start by asking King Neptune to change his mood? . . (I couldn't pass that one up) :) I tried to look up an answer for you, but sorry, I can't be sure I find the right info for that one. I believe someone will help you with that though.
Jul 19, 2014 | Maytag Dryers
My Maytag dryer is flashing a 6
That error is for the "Thermistor"
Check for resistance ( 50-300K Ohm) across thermistor.
If the resistance is out of tolerance, Replace the thermistor.
Here is a link to the part you need.
Oct 17, 2012 | Maytag Neptune MDG9700A Gas Dryer
I have a Maytag Neptune MAH 6700 AWW. It is shutting off and giving error code tE. Customer service does not recognize the error code. Can you help?
This is a problem with the signal from the water heating element "Thermistor" a Thermistor is a solid state sensor that senses temperature, in this case water temp. The Thermistor is part of the washers water heating assembly and not sold separately from it. There is a factory repair bulletin associated with the problem and the new part has improved reliability. I can't understand what the Maytag folks you called would tell you it is not listed, it is a common fault in the Neptune. Please rate my help. Thanks
Jan 23, 2012 | Maytag Neptune MAH5500B Front Load Washer
I have a Maytag Neptune front load model #MDE5500. The light in the tub is on but the control panel display not working. Checked power to to the 220 outlet and all is good. Is this a fuse problem?
door switch most likely, here is a website that will assist you,Tim:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Mar 12, 2011 | Dryers
How do you get to the belt in order to change it on a Maytag Neptune Dryer (MDE5500)?
There are two clips about one inch in from either side of the lid push them in with a flat tip screw driver and lift the lid.
the there are two screws on the inside of the panel that need to come out then remove the front panel. and you will see the other items that need to be removed to get your belt replaced.
Aug 25, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Maytag MAH550 washer and MDE5500 electric dryer Manuals
not available, try direct to maytag although they usually do not release to the public
Dec 01, 2007 | Maytag Neptune MAH5500B Front Load Washer
Dryers Logo
206 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
