Question about DeLonghi Pinguino PACL90 Portable Air Conditioner
Probe Failure Less than 18 combined hrs of operation. Any suggestions? Still under warranty but to early to start failing. Any comments on endurance of Pinguino PACL90 model. Thanks. Pete
  • Anonymous Aug 03, 2008
    Had same problem after a year of use. Just out of warranty cost $150.00 to fix. Replace main logic board.
    Novelist:
  • 121 Answers
I service the delonghi brand in tampa fl we have seen alot of probe failures. some last years some go out in 4-5 hrs of usage
Posted on Jul 11, 2008
My kenmore microwave decided to stop heating!! It's less than 1 year old whats the problem??
Any piece of gear with electronics it can have an early failure. It's possible that the fuse for the high voltage circuit has failed or even the magnetron or the diode that produces the DC for it has gone south. I have the ugly feeling that these don't have a year's warranty anymore but it would be worth checking. I'm growing tired of Chinese quality.
Mar 27, 2011 | Kenmore Microwave Ovens
Dear Sir, I was purchased SONY BRAVIA LCD TV Model KLV32S 550A from Singapore on 10, September 2009. Using at Chennai India. On 15-09-10 we had problem on this LCD TV. We registered complaint on...
Send all this information to Sony.com and see what they say regarding a warranty repair.
Your receipt for the product is proof of purchase and is seen as that.
I am however, not familiar with warranty repairs in your country. Speak to Sony.jpn
Jan 13, 2011 | Sony Televison & Video
We are in a 2011 chevy impala...it says service stabilitrak?
If this is a 2011 Early issue, a vehicle made after Sept 2010, or a 2010 for that matter it is under warranty. Take it back to the dealer and make them fix it. The reason I say this is that 1. The repair should be free and 2. There may be a recall on a part that is causing this to come up and again it would be free to be repaired.
Nov 21, 2010 | Chevrolet Impala Cars & Trucks
2008 F250 65000 miles still gets 14 miles to the gallon what can i do pre warranty out , also has gone though three radiators seal leaks at bottom of tank mch suggest somkind of elctro going on in tank...
Hello! I'll need the engine size...Yes, electrolysis is the problem...Lets solve it...You will need a digital multimeter...Send a comment and tell me if you have access to one...
Start and bring engine to operating temperature...Hold on 2000 RPM...Heat on full...Fan on high...Place the + probe of meter (set to read .5 volts) into the coolant tank...Place the - probe on the negative battery post...Record reading...If reading exceeds .4 volts...The problem is electrolysis...And we'll take steps to fix it...Guru..........Saailer
Aug 19, 2010 | 2008 Ford F 250 Super Duty 4WD
What is E!
Hi
Thanks for using FixYa. Error E1 means thermistor failure, it flashes when the thermistor circuit is open. The dryer will not operate if the exhaust temperature drops below 18° F. or exceeds 250° F. To resolve this the thermistor should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 06, 2010 | Whirlpool ET8CHEXSQ Dryer
Black screen in 1-5 min after turned on
HI,SOUNDS LIKE YOUR INVERTER PANEL IS GOING,CAN BUY NEW ONE,OR CHECK EBAY FOR GOOD S/HAND ONE,YOU MUST KNOW, WHAT YOU ARE DOING,BEFORE REPAIRING YOUR TV!!!,THANKS
Mar 21, 2009 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Emmerson HDTV f32
The failure with this LCD might be due to a failing power supply or backlight inverter board. Since your TV is less then a year old, I would suggest to call the manufacturer to get it fix under warranty.
Good Luck.
Jan 17, 2009 | Televison & Video
95 ford probe se auto. trans. shifts back and forth from 3rd and 4th gear once on hwy. suspect o/d switch or speed/shifting sensors. any ideas?
I own a 1995 Ford Probe SE 2.0L that suffered the same problem. The transmission shop Techs insisted the transmission was blown and needed replaced. After doing some research it turn out to be the Park Neutral Switch also known as a Transmission Range Sensor right below the air box. The part cost 54 bucks. The problem stopped after replacing it. About a year latter the problem came back. After doing some more research it turn out to be the VSS speed sensor. The part cost 57 bucks. The problem stopped after replacing it.
Dec 07, 2008 | 1995 Ford Probe
One third of my monitor has blaned out
ahh..you are experiencing the early vestiges of lcd failure..that usually is caused by the ribbon cable/board combination inside the lcd case..
you under warranty? if not, then it's not too tough to change..just be careful when taking the plastic bezel off the lcd..
check your computers warranty here 4 FREE
Mar 19, 2008 | Acer TravelMate 4200 Notebook
DCT758-4 Phone has failed
if they are less than a year old you should be able to bring them back under warranty and get them replaced. sounds like they might have got a power spike and it killed the base.
Jun 09, 2007 | Uniden DCT758-4 Phone
Heating & Cooling Logo
613 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
