Question about Sharp AR-5316 Advanced Digital Imager Copier
I have a Sharp SF-7900 copy machine that won't switch on.
  • 148 Answers
Could be many things, Bad on/off switch, blown 15 amp fuse, bad fuse on the power supply, bad power supply...
You may need to have a tech look at it.
Hope that helps...
Posted on Jun 20, 2008
Sharp sf 7900 copier, after paper jammed and removed the trouble shooting code light H-4 keeps flashing
HELLO
try to remove or unplug the power from the outlet and also same at the back of the printer and wait for 5 minutes and put it back on
just leave comments
thank you
Mar 15, 2011 | Sharp Office Equipment & Supplies
I just aquired a used sharp sf-1016 photocopier (an old analog machine). Where can I find a copy of the user's guide and service manual for it?
Hi the best thing to do is to contact sharp directly if they have a copy they may be able to send it to you or you can check on line for an authorized sharp dealer who may be able to supply you with a copy
Feb 16, 2011 | Sharp Office Equipment & Supplies
After changing toner on my sharp, SF-2022 copy machine, the copies are coming out with black smudge marks across the paper? how/where should i clean?
This means the machine is over-toning ie using more toner than required caused by either improper toner or different brand of toner. The correct toner is sf 222T1. Replace developer and use the right toner and clean the drum and its blade. You may need to clean fuser rollers for cleaner copies.
Nov 13, 2009 | Sharp Office Equipment & Supplies
I own a sharp SF-7900. My pages are coming out black
I'm sure you may find a manual, but your copier is rather old.... When you make a copy do you get a error code? How about when you make a copy, do you see the scanning lamp turn ON? Here is you thing you can try, make sure the Primary Corona unit is pushed in all the way in. It has a grey handel on it and it should be found right above the Drum... Good Luck
Apr 19, 2009 | Sharp Office Equipment & Supplies
Diagnostic codes for Sharp SF-2014 copier
Sharp SF 2030 On power need enter operator key code, need reset.Please help.
Jan 06, 2009 | Sharp Office Equipment & Supplies
Sharp SF-1118 copying machine H 4 Error
Open right side door and check for a jam in the fusing unit (the one that is normally hot). Remove jam carefully. Hit P * C * and enter 14. Push the start button like you are making a copy. Machine should reboot and code should not return. if it does, you may have a dirty themistor, or blown lamp.
Jan 01, 2008 | Sharp AR-207 Copier
My sharp sf 2022 machine, i need solution
mr engineer please check the drum mark sensor and clean it and also check the check the toner motor connector and do this program    c interrupt 0 interrupt ,44 copy key 07 copy key after stoping the machine off and then on but first clean drum unit maintenance code is 20 then copy key and then three times ca ca ca
Oct 18, 2007 | Sharp AL 1631 Copier
Error CH uppon power up...copy lamp comes on scaner moves forward 2...3 inches shakes and machine stops...
OK, CH normally means the one of the covers(front or side panels) is open or the developer unit is unplugged try these to see if that fixes the problem. p.s When the covers are closed a small tab on the covers triger a interlock switch or optical switch. Hope this helps
Aug 22, 2007 | Sharp AR-160 Copier
Sharp AR-5316 Advanced Digital Imager Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
