Question about Samsung Televison & Video
I have a Samsung projector TV and the picture is off horizontal by a few degrees. I can not adjust it with the remote. Appears to be alignment problem.
  • 1 more comment
  • loupenn1 Jun 20, 2008
    The model is HC-R4755W
    I have a Samsung projector TV and the picture is off horizontal by a few degrees. I can not adjust it with the remote. Appears to be alignment problem. The model is HC-R4755W. How do I do a manual alignment? Manual? Local guy thought it could be an ic problem.
  • loupenn1 Jun 23, 2008
    Yes it appears I will need professional help.
  • Samsung Master
  • 6,487 Answers
Try this one if this wont work you really need to do some manual adjustment to align it.
Mute, 1, 8, 3 = Brings up the service convergence grid
Arrow buttuns = Move cursor around grid
7 = Selects Red to be adjusted (a R should appear above the letters VGA)
8 = Selects Green to be adjusted (a G should appear above the letters VGA)
9 = Selects Blue to be adjusted (a B should appear above the letters VGA)
Press 4 once to select Line Adjustment; Press 4 twice to select entire Grid Adjustment
Channel up/down adjusts convergence up/down
Volume up/down adjusts convergenge left/right
Button under 7 = turns Red gun on/off
Button under 8 = turns Green gun on/off
Button under 9 = turns Blue gun on/off
When done press Add button to save adjustments
1 is the factory unconverged
2 is factory converged
3 is recall last saved setting...
Posted on Jun 20, 2008
    Genius:
  • 1,036 Answers
Hi there!
This needs a physical adjustment rather than electronic.
On the projector module, there will be coils above, below, left and right. If there is an adjustment ring to move them a little, then do, otherwise it is the base module which will need to turn a few degrees.
It may even be out of a retainer clip.
Hope this helps you.
    Master:
  • 848 Answers
It is easy to fix alignment problem by just adjusting the settings in your samsung tv
  • gopinath pasupathy Jun 20, 2008
    just see the display settings in which there will be separate menu for horizontal and vertical alignment
  • gopinath pasupathy Jun 23, 2008
    Horizontal position may be set via a switch or jumper, a pot, or (mostly in B/W TVs) a set of rings on the CRT neck.
    Horizontal size should be set so that there is about 10-15 percent overscan left and right. This will allow ample margin for power line voltage fluctuations, component aging, and the reduction in raster size that may occur with some VCR special effects (fast play) modes.
    Many sets no longer have any horizontal size adjustments and depend on accurate regulation of the voltage to the horizontal output stage to control horizontal size. There may be a B+ adjustment to perform first.
    On those that do, the adjustment may either be done by setting the B+ voltage, by a pot, or a width coil in series with the horizontal deflection coils.
    Some of the newest sets control all these parameters via settings in non-volatile memory and use service menus accessed via the remote control for nearly all setup adjustments.
    Genius:
  • 1,142 Answers
Convergence on RCA can only be done by service center with RCA Chipper Check computer interface box. It looks like possibly missing -15 volt or +15 volt supply to digital convergence circuit, could be a bad IC.
    Master:
  • 788 Answers
The service manual is available here: http://www.eserviceinfo.com/downloadsm/34617/Samsung_HC-R4755W.html It's a 6 part .rar file, download all the files and get the program called 7zip to open it. The manual alignment procedure will be in there.
    Brigadier General:
  • 3,614 Answers
Where exactly this harizontal lines was..?
  • micromaster
    micromaster Jun 20, 2008
    you must check the resistor, capacitor on convergence module, find any bad solder on the board
  • 2,307 Answers
Is it something like this picture?
  • Jaime Hernandez Jun 20, 2008
    You can try to autofocus your TV and see if that works. If it doesn't work it means there is a defective component(s) in the convergence board.
    You can also read the posts from here to know the parts that will need to be replace.
    It might not a DIY project if those parts need replacing.
    Sergeant:
  • 243 Answers
You need a manual Aligment. If you give me the make and model i could try and find the service manual. If you are inquiring on doing it yourself. Although i do not recommend this unless you are very confident in your ability to do so.
Ghost image in different color from main image - text appears "doubled"
Use the remote to access the menu and you'll be able to POSITION the colors horizontally and vertically .
You should be able to align with the other colors to make it sync'd.
Dec 16, 2009 | ViewSonic PJ551 Multimedia Projector
My big screen panasonic tv has a double fuzzy picture what am I supposse to doto fix it
Adjust the convergence or reset it to factory default. Use only the remote when adjusting convergence. The front controls have no effect.
  1. Press action button to enter MENU.
  2. Navigate to SETUP.
  3. Scroll down to CONVERGE.
  4. Press VOL > to select.
  5. Press CH buttons to navigate up or down.
  6. Choose CONVERGENCE ADJ or RESET TO DEFAULT.
  7. Press VOL > to select.
  8. If CONVERGENCE ADJ is selected the align Green to Center screen will be displayed.
  9. Use the navigation buttons on the remote control to align the horizontal and vertical green lines on screen, with the cabinet reference marks on top center and left
    center of cabinet.
  10. Press ACTION button to display red center correction screen.
  11. Use the navigation buttons on the remote control to align the red cross with the white cross pattern at the center of the screen. To prevent picture tube damage do not leave test pattern on for an extended period of time.
  12. Press “0” on the remote control keypad to display the BLUE center correction screen, repeat procedure for adjusting blue. If needed press “0” again to return to RED correction screen. An adjusted cross pattern appears white with a minimum of color protrusion.
NINE POINT CONVERGENCE CORRECTION
Remote Control must be in TV mode.
  1. Press ACTION button to display red correction screen.
  2. Press the 1 through 9 keypad buttons on the remote control to select the desired convergence position.
  3. Use the navigation buttons to align the RED cross with the white cross pattern.
  4. Press “0” on the remote control keypad to display the BLUE correction screen, then repeat procedure.
  5. To exit press ACTION button repeatedly, then press CH up.
Nov 07, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Hour glass cannot adjust red horizontal convergence
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 09, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Red and blue ghosting,
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
*Screen Looks 3-D
*Colors wont align
Problem #2
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 12, 2009 | LG RU-52SZ51D 52" Rear Projection...
Fine tuning grid on my Samsung HDTV with remote.(BP59-00048)
To adjust manual convergence on your projection TV, follow theses steps:
  1. Turn your TV on.
  2. Let it warm up for 30 minutes.
  3. Press the Menu button on your remote. The Main menu appears.
  4. Use your remote to select Function, and then press the joystick.
  5. Select Convergence, and then press the joystick. The Manual Convergence screen appears.
  6. Select Red, and then press the joystick. A series of crosshairs appears on the screen.
  7. Select one of the outside crosshairs by moving the joystick up/down/right/left or by pressing the 2 (up), 4 (left), 6 (right), or 8 (down) buttons on your remote. The method you use depends on the model of remote you have. Note: You must do the outside crosshairs first.
  1. In the crosshair you selected, if you can see a horizontal red line, use the CH up or CH down buttons to move the line so that it is superimposed on the horizontal center line of the crosshair. Note: Make the single horizontal line as white as possible.
  1. In the crosshair you selected, if you can see a vertical red line, use the Vol + or Vol - buttons to move the line so that it is superimposed on the vertical center line of the crosshair. Note: Make the single vertical line as white as possible.
  1. Repeat for all outside crosshairs, and then for the inside crosshair.
  2. Return to the Manual Convergence Screen, and select Blue, and then press the joystick.
  3. Repeat Steps 7 through 10 for Blue.
  4. Press the Menu button on your remote to exit.
Important: The directions above work for most Samsung Rear Projection TVs. Yours may be different. For exact directions to perform manual convergence, see your user's manual. If you don't have your user's manual on hand, click HERE to view your manual on line.
If you cannot get your Projection TV to converge, it may need to be serviced. To arrange a service appointment, call Samsung Customer Care at 1-800-Samsung (1-800-726-7864). Have your TV's model number and serial number on hand when you call.
Jan 05, 2008 | Samsung BP59-00016A Remote Control
Can't watch footbal
NOTE: ----DO NOT TOUCH THE CONVERGENCE BOARD " -------
1. Bring Up 1 Projector Light 2. Bring Your Color Convergence + Sign and Should Be Center In Your TV 3. If Not Adjust Center with The 2 Tabs Just Above That Projector Tube You Have Lighted 1 Tab Will Move + Sign Horizontal Then Roll The Other Vertical Then Roll..U Will See--" 4. Once Your + Sign Is Center Turn Up Your 2 Other Projectors Make Sure They Are Able To Adjust Across The + Sign You used 1st Make Sure the 2 Other + Signs Move Left And Right And Up And Below The Vertical and Horizontal Lines. If Not Adjust There Tab to Make This Possible. 5. Using Your REMOTE Converge The + Signs Together. ---------------- IF YOU MESSED WITH THE CONVERGENCE BOARD ------------------- 6. Now Lower The 2 Lights So Your 1st Projector Is Lighted 7. Bring Up A Menue On Your TV -- Look At It ...Are The Lettering Center and Square ..?? 8. If They are Lower That Projector and Light Your Projectors 1 At A Time To Verify Letters are Center and Square. ---------------If You Have To Adjust The Menue To Bring Center And Square -------- 9.Looking At The Convergence Board You Will See 3 Rows Of Adjustment Dials Each Row Is For 1 Projector. ---TAKE NOTE TURN THE ADJUSTMENT Slowly--- 10. Locate The Row that will adjust The Projector You Have LITGHTED".... 11. Label On A Paper What Each Knob Will Do To The Screen Very Help-Full 12.Adjust Your Letters Dead Center and Square then Lower That Projector Light And Bring Each Projector Lighted At 1 Time To Verify Menue Is Center And Square. 13.Leave On Your 3rd Projector and Bring Up Your Light On The 1st Projector 14. Adjust the Letters Of Your 1st Projector Over The Letter Of Your 3rd Projector 15. Switch To Your Convergence + Sign To Help --Turn Knobs Slowly --- 16. Make Your Letters Merge Together And Your Lines Square. 17. I Use The Top Letters and Lower Letters And Keep The box Square 18. Hey If Your Projector Colors When Looking Through The Rear Of The TV Are Not Equal With Take And loosen The Wing Nuts And Turn The Lens To Focus the Color and Make Narrow Or Wide....All 3 - Equal DO NOT GET UPSET THIS WILL TAKE TIME MAYBE ALL DAY SO RELAX HAVE FUN" Do Not go Sticking Your Hand Into The TV While TV Is Plugged into The Wall" ---
Dec 16, 2007 | Philips Televison & Video
Projection red is above other colors
Look in your menu for something called "horizontal static convergence" or just "convergence". Adjusting this will align all three tubes electronically. If physical adjustment is needed, then you have to do this manually inside the Tv. keever
Dec 09, 2007 | Mitsubishi WS-65908 TV
Distorted Color and geometry of Picture
I've posted this solution several times but here goes. Try setting up the convergence through the menu by accessing the convergence setup menu. If this fails to work you have a bad digital convergence box and need a tech to replace it. About $60 to $100 fix.
Nov 03, 2005 | Panasonic PT-47WX49 47" Rear Projection...
Televison & Video Logo
75 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
