Question about Kitchen Ranges
We have a ceramic flattop stove. Is there a heat element to prevent pot from scorching or burning food?
  • 77 Answers
Just takes practice and using smallest burner appropriate to pan. also should use medium weight FLAT pans. put a straight edge on bottom of pan before using or buying. I have seen pans that are $200 each that I don't feel are flat enough. much of gourmet cookware is designed to work on gas tops. The surface also needs to be cleaned every time it is used. I have a 6 month old white top that still looks brand new, lot of work though.
Posted on Jun 20, 2008
Can visionware go in oven
The short answer is YES!
In the 1990's Corning produced a series of Visions cookware, brown amber and cranberry colored glass-ceramic dishes and casseroles, that had the same basic properties of its white Pyroceram cookware. Visions cookware could go directly from freezer to hot oven to stove-top to the microwave oven to table to fridge to the broiler to the dishwasher, etc. Extreme temperature changes did not affect the very durable cookware, While many folks mistake Visions cookware for Pyrex bake-ware, they are not the same. Visions cookware was never issued in the forms (square pans, rectangle baking pans, loaf pans, pie pans, etc that clear glass Pyrex baking pans had been produced in for decades. In any case, Visions glass-ceramic cookware could go direct from the freezer to the hot oven - there would be NO DAMAGE to the cookware in such a practice. Visions glass-ceramic cookware also has markings to indicate usage. The majority of Visions cookware were of the "stove pot" design - stove top was intended from the start. However it is practical to let the food defrost first, or adjust the cooking time in order to create a better thoroughly cooked dish.
Yes, Visions cookware can be used in the oven! One caveat is that the pot lids are Pyrex which means that the pot lids can not be placed under the broiler (who does that anyway?), or under direct heat, or while hot on wet surfaces. The pot lids were meant to be pot lids - just like other Pyrex glass pot lids on most cookware.
Apr 17, 2014 | CorningWare Microwave Ovens
How do you clean the burnt on food inside the base of a crock pot with a removable crock?
I have the exact same problem! I cooked soup that slowly boiled over the edge and burned inside the base. I know you can't soak it and I don't want to ruin it. Help!
Oct 04, 2010 | Nutritionist 10 Cup Rice Cooker RA10NR
Westinghouse freestyle 521 stove ceramic top.elements wont turn down no matter where switch is. burns food. Have used different size pans etc,
there is a problem with either the elements or the controls,i doubt it is the elements as its unlikely that all of them are faulty at once.the control knobs or control panel is more likely the problem.
May 29, 2010 | Cooktops
OVEN WANT HEAT PROPERLY FOOD DOSEN'T GET DONE
It could be that your lower element is burnt out or ready to burn out. They last 3-5 years depending how much you use your stove.
Disconnect POWER to the stove, remove the screws holding the lower element to the back of the inside of the stove, pull out carefully and remove the 2 screws holding the wires on. Check the element with an ohm meter or take it to a store that sells replacements ($25) and they may check it for you.
Oct 31, 2009 | Kitchen Ranges
Whenever I cook cream soups in my stainless steel pots, they burn on the bottom. I watch them very closely and just have the heat on medium, but they always seem to burn. I recently bought a glass pot to...
I'm assuming this is an electric stove, since that's what the picure shows. Most electric stoves turn the heating element on and off to regulate the temperature. On high the element is on almost all the time, on low it's off most of the time. The problem is that when it's on, it's on at full power, and sometimes this is enough to scorch things like milk based creme soups.
You can do two things:
First, try using a double boiler. This will put water in the lower pan and help keep the heat lower than with a regular pan. You could also try to find a pan with a very thick bottom, and try that. It might work better.
Sep 13, 2009 | Frigidaire 31 in. GLEC30S8 Electric...
The inner right front element will not heat up on our Kenmore Elite ceramic stove top. The middle and outer elements on the right front work fine. Why is this happening?
inner element burned out. Either burner needs replacing or control switch is bad. Take out burner and see if coil has a break in it. IF not, then switch is bad. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 28, 2008 | Kenmore Kitchen Ranges
GE Spectra electric burner always on high
Sounds to me like the RF switch is bad.
Eddie Rentas
Tupper Lake NY
Jun 26, 2008 | Cooktops
Whirlpool electric stove
the sensor is built on to the top of the surface element if it was me id replace both the element and switch so you only have to go in once but its probably the element
Jan 19, 2008 | Kitchen Ranges
Kenmore flattop stove
how do I change the eye on my electric 2000 kenmore smooth top electric range
Dec 12, 2007 | Kenmore 30 in. 42701 / 42702 / 42709...
Kitchen Ranges Logo
147 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
