Question about Philips Magnavox MWR10D6 DVD Recorder
MWR10D6 Since I bought this dvd recorder I've not been able to use it. I have a dvd I did off my digital camera and want to make a copy. Can I copy on my MWR10D6 if I play the dvd on another player connecting it to the MWR10D6. Is this possible ,and if so can you tell me what to connect and where. Thanks, Sandra
I cant record with my
MWR10D6
since i bought it I dont know what is the problem. I used all the correct conection.
Posted on Jun 28, 2008
Trying to connect Magnavox MWR 10D6 DVD/Recorder to Sanyo HDTV. TV is connected to Dish network through coax. cable.
Unfortunately, the Magnavox MWR10D6 recorder can not record HD signals. It's only video inputs are coax (RF) and composite video; both are limited to 480i (SD). NTSC (analog signals) are translated to video.
Your best recording option is to connect the composite video output of the Dish receiver to the video input (yellow for video, red and white for audio) of the recorder. Then set the receiver to the channel that you want to record and set the recorder to Line In.
HD recorders may exist. They are much more expensive than the SD versions.
I wish that I had better news for you. The manual for the MWR10D6 is available from Funai here: http://www.funai-corp.com/support/om/MWR10D6.pdf .
Apr 18, 2013 | Philips Magnavox MWR10D6 DVD Recorder
I am a member of a paranormal group. Can I use my magnavox MWR10D6 DVD recorder to record from a cam. Is this possible?
As long as your DVD recorder has line inputs yes you can.
If your DVD recorder has a DV input, you can use a firewire cable. If your DVD recorder has audio and video inputs you can hook the output of your camera to the line inputs of your recorder and record in realtime
Most DVD recorders do have inputs, you can use either the Y/C (black round connector) or the composite (yellow connector) along with the audio inputs (red & white) RCA plugs depending on the type of camera you are using.
Sep 24, 2009 | Philips Magnavox MWR10D6 DVD Recorder
I want to record a dvd from andother dvd player. I cant get it to work. help please.
you can record the output of the DVD player into the input of your DVD recorder, but I think the quality of the recording might be affected. Be sure to check copyrights before doing so.
or
Most DVD recorder/VHS combo allow to attach an external DVD and copy from the one to the other (assuming there is no copyright protection). In case there is no automatic copying option you can still copy manually -by plugging the external device and play while you record into the internal one.
Thanks.
Jun 04, 2009 | Philips Magnavox MWR10D6 DVD Recorder
I need a manual for Magnavox dvd/ recorder for MWR10D6
Although this is a Magnavox DVR, it is made by Funai. The manual for it can be found at:
http://www.funai-corp.com/6pdf/om/MWR10D6.pdf
Hope this helps!
Jan 04, 2009 | Philips Magnavox MWR10D6 DVD Recorder
How to set up my magnavox dvd player / recorder
http://safemanuals.com/user-guide-instructions-owner-manual/FUNAI/MWR10D6
Dec 07, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Dvd recorder mwr10d6
The manual is located at: www.funai-corp.com/6pdf/om/MWR10D6.pdf (copy and paste in your address bar) hope this helps!
Jun 07, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Brain fade
The manual is located at: www.funai-corp.com/6pdf/om/MWR10D6.pdf (copy and paste in your address bar) it shows some helpful connection scenarios...hope this helps!
Jun 02, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Manual
I got one at
http://www.funai-corp.com/support/manuals.aspx
May 25, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Philips Magnavox MWR10D6 DVD Recorder Logo
98 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
