my computer does not regonize my sansa e250 , lost the software that came with itmy computer does not regonize my sansa e250 , lost the software that came with it
AnonymousOct 02, 2008
i lost the software it came with..where can i download the software from an online source?i lost the software it came with..where can i download the software from an online source?
AnonymousOct 03, 2008
my laptop will not read my mp3 played.my laptop will not read my mp3 played.
You can't post conmments that contain an email address.
If you are using a USB connector [that connects extra ports to your computer] it sometimes doesnt work... so if possible hook the USB sansa cable to the main ports in the back of the server. It might also work to hook it in, and then go to 'My Computer' and see if it shows up there. Good Luck =]
I assume that you are running an older version of Windows from XP/2000. If you can get on the internet, go to Sansa's site and download the driver from there. Here is a link http://mp3support.sandisk.com/sansa/SMC
The device is supposed to refresh each time in case you put in a new memory card or added additional files. That's not the problem - this is:
There are two connection settings in USB: MTP and MSC. For some reason MTP is the default, but it doesn't connect properly on all computers. Select MSC and plug the player in again, the computer will recognize sansa e250 but not show the driver just yet. It is installing recognition software (just basic drivers - nothing heavy) and it doesnt tell you what its doing until its complete. WAIT FOR IT. Once it is complete you will see both the sansa e250 and the removable memory slot in your "my computer" now you're good to go.
you cant. It isnt designed to read file formats. Only video, mp3/wav music, and pictures. I'm sorry but you need a sony reader or kindle for the type of files you want.
Go to hardware --> device manager and see if there is a yellow exclamation bu usb port - if there is, right click and update driver
otherwise: These are the most common methods for recovering Sandisk's Sansa Mp3
Players. I have been almost universally successful in recovering Sansa
players using one or a combination of these methods. These methods do
not work if you are having synchronization or music format issues -
they are for recovering a player that will not power up, freezes,
flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first.On most models, restart is done by holding the power button in for 15 seconds or longer.Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced. Download the Sansa Recovery Tool from the Sansa website. Format - Erases Everything: Connect your Sansa player to the
computer and open Windows Media Player. Click on the Sync tab. Pull
down the drop down menu underneath the Sync tab by moving your cursor
over the Sync tab and left clicking on the little black arrow
underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary
slightly), and then select "Format." - this should erase everything. Firmware Upgrade- Erases Everything: Get the latest firmware
upgrade from Sansa - it updates the firmware and erases every song in
the player all at once. Note: this method doesn't work if already have
the latest firmware. Go to this website and click "Firmware Updater" to
find out: http://www.sandisk.com/DriverDownload/driverList.asp If these fail, then: Try this: disconnect the player from the computer, turn it off,
hold in the volume + button, and reconnect the player to the computer
while holding the volume + button in. Keep holding the volume + button
for an additional 5-50 seconds. Windows should eventually go into
recovery mode and revive the player- it will pop up a window that says
Found New Hardware Wizard. If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version). You may have to restart your computer after each of these methods
to get them to work properly. Disconnect your Sansa player BEFORE
shutting down your computer. -Tha Mp3 Doctor
Hi there , in the settings menu in your player if you go into usb you can change it to msc mode and it will read as a normal usb drive so you can transfer songs etc
Hi-USB refers to the USB 2.0 standards. It appears your computer only has USB 1.* hardare on it's motherboard. If you have a free PC slot, you can buy a 2.0 USB upgrade card. It will speed up the transfer times between USB devices and your computer.
As for your computer not "seeing" your sansa, try another USB cable. If that does not help, check under control panel/system/device manager to see if the device is properly installed.
The sansa operates as a "removable drive" so you
should see your player as another disk drive in windows explorer.
If you have a drivers/installation CD-rom for your player reinstall them, or check the sansa website for possible newer updates.
Good Luck!
Switch your player into MSC mode via Main Menu > Settings > USB mode. When the player is connected it will show as two drives, the player, and the microSD card just like a card reader. You can transfer files directly to the expansion card.
