Here is a list computer beeps and what they mean.
- No Beeps: Short, No power, Bad CPU/MB, Loose Peripherals
- One Beep: Everything is normal and Computer POSTed fine
- Two Beeps: POST/CMOS Error
- One Long Beep, One Short Beep: Motherboard Problem
- One Long Beep, Two Short Beeps: Video Problem
- One Long Beep, Three Short Beeps: Video Problem
- Three Long Beeps: Keyboard Error
- Repeated Long Beeps: Memory Error
- Continuous Hi-Lo Beeps: CPU Overheating
Most times the beeping is caused by a bad/loose connection somewhere or card not seated properly.
Try disconnecting and reconnecting everything again. Make sure that all the power plugs are connected properly even if you didn't mess with them. Moving things around can sometimes be enough to give you the "BEEPS". ";-}
If you are still having much beeping and no computing you can try my personal favorite.
Start first with verbal threats. Next
move to a second floor window and, while you explain whats going to
happen if it doesn't knock it off, open the window.
If that fails give it the pitch.
Believe it or not I have used this technique and after reassembly and repair.....No more beep.
I hope this helps but if not let me know and we will try something else.
