Does your unit have a induced draft motor? if so is it coming on when thermostat is calling for heat. If not I would replace it. Next I would check spark or hot surface ignitors. If induced draft motor is working but ignitors are not then replace them. If you get to this point and you don't get pilot or main burner I would replace the control board. As a last resort I would change gas valve. I hope this helps you and god luck. Thanks
