Question about HP OfficeJet 7110 All-In-One Thermal Printer
It's not getting recognized by the Plug & Play, but everything is installed
I installed all the programs needed for the printer, but every time I plug the USB cable in, it'll make two dinging noises, and that's it. All the software works, and I don't think that the USB port hub is faulty...
Please help, I really need it!
    Scholar:
  • 77 Answers
Anime-
1. try a shorter usb cable.
2. plug the unit directly to the power source instead of a power strip
if this doesn't work first uninstall the ghost devices from device driver and try again. steps are below(with printer usb plugged to computer).
1. right click on my computer > click on properties
2. click on hardware tab
3. click on device manager
4. click on view in the top menu
5. click on show hidden devices
6. uninstall any unknow devices by right clicking on it
7. expand system drives and it will show generic drives- uninstall them all
8. unplug usb > reboot and plug back with installation cd in the drive
If this doesent work you have to make changes in the registery: let me know and i will give you the steps:
you can try following the steps in the link below:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00040499&cc=us&dlc=e&lc=en&jumpid=reg_R1002_USEN
Posted on Oct 10, 2008
Told that this is a PCL5 type printer and can be used as a plug n'play, and no need to install a driver. It does work, but will not hold the programming. I only want to use Tray1.
the thing is that with plug and play equipment, when you plug it into the pc and turn it on Usb connections) , there is a small message just above the task bar which says installing driver for printer
it is the way that the pc recognizes the printer in a port
it may be best it you go to the control panel ,printers and devices , add a printer and install it properly
Oct 13, 2016 | Lexmark Office Equipment & Supplies
Have a hp office jet 6310 and i use it wirelessly all the time for printing and have used it to fax. I have never used scanner but would like to. when i click start scan or scan to it show select...
I suggest that you run the scan from a computer and not from the printer, it works tons better. Each computer needs to have the install program run on it, NOT PLUG AND PLAY. Plug and play will make most stuff work, but not everything.
Further, HP printers are fussy about exactly when to connect the printer, get the correct install program for your printer and OS from HP.com, and install following the directions exactly.
Scanning is the one function that never works with plug and play.
Feb 12, 2011 | HP Officejet 6310 All-In-One InkJet...
I just recently purchased a new computer with Windows 7 and have been unable to get the machine to recognize the printer. Will this printer work with windows 7 machines
Go to Konica web site and see if they have install software for 7. Not all printers and less scanners work with 7. Many printers work poorly if installed plug and play. Better success with manufacturers install program and follow EXACTLY the install directions.
Oct 09, 2010 | Konica Minolta Magicolor 2530 DL Laser...
Can I make this work with vista? Also, the scanner attachment?
Sorry, that printer is not supported by Vista, as far as I can tell there is no way to make it work. So sorry about that.
Sep 09, 2010 | Canon BJC-85 InkJet Printer
CDP78 USB Device Not Recognized
HOW did you re-install everything ?
Make sure you UNPLUG the usb cable first, then UNINSTALL the drivers and all software - reboot your computer - make sure at all times your usb cable is unplugged from the device - once cleaned and unisntalled - re-install drivers and software - BUT still, do not plug the cable - ONCE and only once the drivers are installed, then plug the USB cable, inspect the USB cable to make sure it's secured. Have you tried unplugging your printer for a few minutes and plugging it in again ?
IN windows device manager do you see the device listing with a yellow exclamation mark ?
If all else fails you may have a faulty circuit board on the printer.
Sep 26, 2009 | Vinpower Digital U-Print CDP78 Printer
Printer installation?
You will have to reload your printer. Plug the printer to your computer and reboot. The Plu and Play should recognize it. Then the Ad Hardware Wizard will pop up. Load the CD that came with the printer and the Wizard will allow you to load and configure the printer driver. Once the drivers are loaded you can print a test page. If it is a USB printer then load the drivers first, then plug your printer in and reboot.
Dec 24, 2008 | Canon MultiPASS C555 InkJet Printer
Laptop does not recognize wireless mouse
Most wireless mouse are not plug and play.
Try this:
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
May 28, 2008 | Bluetake (bt500+bt009x) Mouse
"Installing driver software" every time I plus it it
It is not installing it like it did the first time you plugged in the printer, but it is recognizing the device is now attached to the PC - so it is enabling the driver so you can use the printer. It is the nature of plug and play. You plug, it enables the driver, so you can 'play'...
May 12, 2008 | HP PhotoSmart C4280 Laser Printer
Plug and play problems
Let me ask one question. Have you loaded the print drivers for your printer. If not do so. This will fix the problem.
Feb 12, 2008 | HP PSC 2175 All-In-One InkJet Printer
HP OfficeJet 7110 All-In-One Thermal Printer Logo
67 people viewed this question
Seeker5211
Seeker5211
