Question about Refrigerators
After replacing broken actuator, water, ice and light dont work when all 3 did before.
Kenmore side by side refrigerator 253.5569940N I just replaced the water actuator and in the process the ribbon cable became disconnected from the front panel. I reattached it with the silver metal side towards the circuit board. Now its like its not getting power - ice, water and light do not work - Whats wrong? I then tried with the cable facing the opposite direction and it still didn't work. Is there a manual that shows the direction of the ribbon cable? Is there a reset button somewhere?
  • frank6913ca May 15, 2009
    Exactly, I have the same problem. What happen and what Can I do to repair it? Do I need to call a technician or can I repair it myself?
    Thank in advance.
  • 74 Answers
SOURCE: GE Profile Refrigerator Ice/Water dispenser not working
Check the connector at the bottom of the freezer door first , you should also be able to hear the micro switch click when you press the paddle
Posted on Aug 28, 2008
Sea Breeze
  • 4655 Answers
SOURCE: need to replace the water actuator on frigidaire model FRS6B7EESB
To get help replacing the actuator you can visit mu site below and enter your model number FRS26R4A in search feature this will take you to the parts page. On left of screen click picture #15 dispenser. I shows a diagram of the parts and I or Appliance Parts can assist you in installing the actuator. Thanks Sea Breeze sea breezehvac@yahoo.com
click on link below
http://servicepartstec.blogspot.com/
Posted on Mar 30, 2009
  • 77 Answers
SOURCE: remove faceplate in door of a kenmore frig.
If you look at the bottom of the facial plate, underneath. There are two slots to insert a flat screw driver. You should be able to access everything once you take that off. Good luck
Posted on Apr 24, 2009
pilungu
  • 30 Answers
SOURCE: front panel on my GE side-by-side refrigerator doesn't work
Replace the touch pad.
Posted on Nov 07, 2009
TheMobilian
  • 8220 Answers
SOURCE: GE refrigerators GSS23WSTASS: The control panel on
GSS service manual
Posted on May 13, 2010
I have a kenmore coldspot side by side water comes out dispenser but there is no water flow up to ice maker,also just replaced dual water celanoid
Hello, so you just replaced the water inlet valve correct? Here is a video on how to test the icemaker by removing the cover of the icemaker and connecting the L to the V water should immediatley come from the water inlet valve to the ice tray. If it did not and you heard the water valve actuate then there would be an issue with the icemaker in the unit. click this link http://www.youtube.com/watch?v=AlYCJr9dc3E if you have any further questions message me back Thanks
Rick
Sep 11, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore side by side: ice maker works...ice
Probably a broken plastic tube from the solenoid valve to the water outlet tube. It will stay dry until you try to get water then it may take a few days to dry out.
Good Luck,
Gilsh
Nov 27, 2009 | Kenmore 57029 Side by Side Refrigerator
My ice cubes appear to be hollow. what is causing this?
The water valve is not letting enough water in . Replace the water valve .
Aug 06, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice Maker Works, Water Dispenser Doesn't
I have a whirlpool side by side. water and ice in front. ice working and water not. the hose is not frozen and it is not humming when you push the water dispenser. It would give us water and quit but now we have nothing.
Jun 25, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Kenmore side by side makes no ice
the water line coming into the freezer may be iced up. or the motor that spins the ice "ejector" arm may be stuck. try spinning it manually (just dont force it).
May 29, 2009 | Kenmore 44103 Side by Side Refrigerator
Broken water actuator
Hi this is tech crazy
the solution to the problem is
You should be able to replace this part yourself. Follow these steps to replace the water actuator:
  1. Unplug the refrigerator to completely disconnect electrical power. Turn off the water supply to the refrigerator.
  2. Remove the drip tray (Key 23 in the image below) from the bottom of the dispenser.
  3. Remove the screws (Key 43) from the bottom of the dispenser module cover (Key 4). NOTE: You model may not have screws at the bottom of the dispenser cover. If not, push down on the top of the dispenser cover and pry out on the bottom of the cover with a flat tip screw driver to remove it.
  4. Pull to dispenser module cover up to release the top clips and remove this cover and set it aside.
  5. Remove the screws (Key 17) that are on each side of the dispenser module (Key 8).
  6. Carefully pull the dispenser module out slightly from the door. It will have wires attached. Pay attention to how the water tube and the ice door assembly are positioned. Pull this module out far enough to remove and replace your water actuator (Key 24).
Reverse the above process for reassembly.
Jan 25, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Kenmore/Fridgedaire refrigerator ice actuator replacement
hi thanks for the question are you talking about the arm to stop the ice making if so you can just put back in clips on the front of ice maker and at back thanks the appliance doc
Sep 26, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
ICE MAKER NOT WORKING Kenmore cold Spot model# 106.55536400
Most common problem is a broken ice maker module.  Should also replace ice maker thermostat when changing the module.  Make sure fill tube isn't frozen first. If you take the ice maker out pull off the plastic cover and in the center of the wheel that kind of looks like a gear there are two little plastic studs.  If one is broke or they are pressed together then the module is bad. Make sure to replace the thermostat along with some silicone grease because a bad thermostat is what causes the module to break.
Oct 19, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Can't get ice
How old is the Kenmore? Sounds like you have a leak to freeon line to the ice maker. You can replace the ice maker yourself.
Let me know if this helps.
Okay, Spurs21
Oct 14, 2007 | KitchenAid (KSRD22FKST) Side by Side...
Refrigerators Logo
189 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
