Question about Canon CLC 1120 Color Copier
Can't scan to email for a Canon ImagineRunner C2550
When trying to scan a document and send to an email address (that I typed into the address book) I get a "TX image set not to display" error message. Any clue how to resolve this? Thanks!
  • OwenJ Jul 04, 2008
    Same message (TX IMAGE SET NOT TO DISPLAY) using the scan feature on Canon iR C3170 machine.
    Nothing in the manuals or the user CD's.
    Local Canon branch don't have the answer yet either. "we'll call you back ...."
  • Anonymous Mar 14, 2014
    Is there an easy way to scan multiple documents to the same person, without selecting their address each time? thx!
You need to set the scan settings in copier settings 200dpi 300dpi color or black and white....
Posted on Jul 17, 2008
I want to scan a document to send to email how do I do this
scan the document , save to your pc , laptop , then when wanting to send on attach it and send
Mar 15, 2016 | Canon PIXMA MX432 Office All-In-One Inkjet...
Cant get printer to send scanned documents to replacement laptop
you have to go into the address book and switch the ip to the ip of the current computer (open the run program type cmd the in cmd type ip config look for ipv4 settings the number you get is the ip you need in the address book of the machine
May 09, 2014 | Kyocera Office Equipment & Supplies
How do I email a document from a printer?
you will have to create an E-mail account for the printer in your mail server, then configure that email/password on the printer's SMTP configuration through the web browser or the printers panel.
once done, add email to the printers address book and start sending scans via email to employees.
I hope this helps,
Majdi
Jan 17, 2012 | Canon Office Equipment & Supplies
Purchased new Canon ImageRunner C2550... using as network printer and scanner. 3 computers on network, Canon 2550 recognized two computers no problem... cannot get it to recognize the third one. Third...
The network setting for the scanner driver may be incorrect. Check the IP address of your scanner and then set the IP address on the scanner driver.
1- The steps of setting the IP address may differ depending on your operating system.
For XP operating system:
Click Start > Control Panel > Printers and Other Hardware > Scanners and Cameras.
For windows 7 operating system:
Start > Control Panel > ... View scanners and cameras.
2- Right click on the scanner icon for your machine and select Properties.
3- Click Network Setting tab and select Specify your machine by address.
4- Enter the IP Address you confirmed from the snanner menu or ask your network administrator and click OK.
Hope this helps.
Jun 17, 2010 | Canon imageRUNNER C2550 Color Copier
Canon 6570 Copier Scan to a network file share, not email it
the easiest way to do this is to goto additional functions, address book, register new address, file, then you can type in the name you would like ie. Bill or Contracts. when it asks for the file path change it from ftp to smb and then select browse this will let you browse the network and just select till you get to your shared file. you can also type the ip address in the address bar of internet explorer and manually put the file path in the RUI under address book.
Aug 31, 2009 | Canon IMAGERUNNER 6570 Copier
Scanning from a canon 3220
Yes, the type of scanning mentioned by the previous answer is called 'pull scanning' and you will have limited functionality. You have to load the document on the copier, turn on the scanner (nobody can use the machine now) return to your desk which I hope is not far from the copier because the doc stays there until you 'insert picture from scanner' then the machine scans the document and you run back to the copier to get it before someone throws it in the trash! It's a free system but limited. To have a fully functioning 'push scanner' where you send a doc as you stand at the copier to either a file on your computer, server or an email address you would need a universal send kit installed. If your machine has one you'l see the option tab called 'SEND' along the top of your screen. If you have this you're in luck. All you need is to enter the necessary network and email settings which can be done by any half decent network administrator vis the 'system settings' area from the addtional functions screen (accessed by pressing the head key with a star in it). Once this is set up merely select the 'SEND' tab and insert your document. In the top right hand corner will be a drop down menu reading either 'FILE' 'EMAIL' or 'FTP' If you want to send it to a shared folder on your network (anywhere) you select the 'FILE' option and then use the drop down menu in the centre of the screen to search the network for your shared folder. Select it and then press ok then the start key - IT'S GONE - IF YOU'RE LUCKY. To send to email you just select the 'EMAIL' option and enter the email address of the recipient and ok then start and you're in business provided that all the network and email settings are correctly entered and permissions for network access is set up. The machine needs a email account registered for it as well. I'm tired now - good luck.
Feb 17, 2009 | Canon imageRUNNER C3220 Color Copier
Sending to a file setup
No, you can't retrieve deleted phonebooks so far as I'm aware but probably you're not referring to phonebooks because there probably is no phone. But sending to a file should be quite easy. Now, as you've posted on a Canon thread, I hope you are referring to a canon, a clc or irc. If this is the case then all you do when scanning your document is in the top right hand corner where you will, by default, see 'email' you can use the drop down menu to select 'file'. Now, you will then be able to use the down arrow keys on the main display to search your network for the relevant 'shared' folder and select it. Remember, the folder must be 'shared' for the canon to see and select it and there must be no conflicting firewalls. If passwords have been set up for network access the machine will prompt you to enter it where necessary. Once you have arrived at the3 destination folder you can scan your document to it. You can set up your address book in the same way so you don't have to go through this whole procedure everytime.
Need a Canon Copier Service Manual
Nov 24, 2008 | Canon imageRUNNER C3200 Color Printer
Canon CLC 1120 Color Copier Logo
5,352 people viewed this question
old marine
old marine
Corne Viljoen
