Question about Refrigerators
Hotpoint fridge I'm trying to turn off the defrost mechanism on my hotpoint 8232 slimline model. (the little button inside the temperature control dial). I don't have the instruction manual (It's second hand), any advice please.
  • 1 more comment
  • drickerby Dec 18, 2008
    I have a Hotpoint 8214 with the same problem.
    Any assistance would be appreciated.
  • Anonymous Apr 24, 2009
    defrost button was pressed by mistake and can't get it back up.
  • Ross Sherwood Nov 29, 2013
    turn off at the wall and wait. then reset dial to off mode. (0) then push past zero to 9 (-1) then turn on power and turn up dial to desired temp.
Just turn the control knob back down to 0 and button should pop back up.
Posted on Sep 21, 2009
  • hyperopiadeb Apr 04, 2011
    This button is still pressed in when I put it back to 0. Any other ideas? Is it on a timer maybe?
    I was removing the ice without the button pressed and then i pushed it near the end. Now i cant get everything cold again!
    Looked up the user manual at www.hotpointservice.co.uk/hs/pages/manual/manualSearch.do and it says the it will turn back one once its finished defrosting. fingers crossed
Older Quattro fridge freezer When turning back on the buttons controlling drawer temperatures are setting themselves to freeze and we cannot get them to release.
posting the model would have helped
take out the draws till fixed
de stock or stack neatly what you can inside the freezer area
possible faulty thermostat
model may be discontinued and after market generic parts required to be retro fitted
a user manual may help if not that old a model
Download Manual Hotpoint Service
Apr 02, 2017 | Refrigerators
Hotpoint fridge freezer mod no fufl 1810 not working properly .food in fridge warm and freezer food starting to defrost. Have to turn on and off at plug before it kicks in again.... Any ideas
I have the samo model with same problem!
Try to do defrosting 24 hours! You can remove the back cover of freezer (inside) and check is there ice on the evaporator (looks like a radiator) If ice is there you can defrost by hair dryer!
Check after, should be ok, but I have a bad news! You have defrost system problem like me.
Mar 15, 2015 | Hotpoint Refrigerators
How do I fix my refrigerqtor hotpoint double door not defrostiong
Generally, if you unplug the refrigerator and set the freezer and refrigerator temperature controls to off then plug it back it, this will put the refrigerator in forced defrost mode. Keep the doors closed and allow defrosting to last for about 20 minutes. Then unplug again and reset the temperature controls to mid-range or a little above, and plug it back in. If this does not reset the defrost cycle, you probably need service.
Mar 07, 2015 | Hotpoint Refrigerators
I have a Hotpoint Fridge Freezer Model RFA52P. Its a recondition one which I have had for over a year and has been working fine up until last week. For some reason it is now switching off every few hours...
Temperature gauge or thermostat? If a thump gets it going then the electronics are a problem, get a new control board. If your thumping the thermostat it could be the defrost timer behind there, the timer motors get weak and won't go out of defrost, the thump gives it the umphh to move. Check with your local appliance parts supplier they can supply you with the proper replacement and they can show you a diagram to determine whether you need a control board or defrost timer.
Oct 29, 2013 | Refrigerators
Kelvinator fridge not cooling
Try defrosting the fridge. Check the cold plate at the back of the food compartment once the fridge has been defrosted and turned back on again. The cold plate in the freezer (around the walls) will be cold to touch as will the cold plate at the back of the fridge,
Oct 20, 2013 | Refrigerators
Fridge freezing up
Check the fridge sensor. On my Hoover HNMF2805AL80 f/f, first I replaced control module - still freezing.
Have just replaced cheap fridge temperature sensor. Part No. 97061619. Trouble is you have to cut into insulation at back of fridge to replace. I just plugged in sensor & placed inside fridge at back at the bottom - so far so good, only lettuce freezing now, everything else v. cold but not frozen. :)
Jun 02, 2010 | Hotpoint RLA50 Refrigerator
Hotpoint fridge - temperature problem
Somewhere there's another knob that controls the position of a damper that balances cold between the freezer and the refrigerator. Despite where the knob is, the thermostat is probably controlling the freezer temp. The damper controls how much cold from the freezer gets to the refrigerator.
You need to adjust that knob to divert less cold air into the refrigerator section.
It's also possible the damper has gotten stuck and can't be moved, in which case you may need a repair tech.
Feb 25, 2018 | Refrigerators
Refrigerator not cooling
The fridge gets its cold air from the freezer through a vent(damper)between the freezer and fridge.The fan in the freezer blows air through it.Make sure this fan is running. You may have to hold the door switch in for itto run. There is a flap you adjust withthe fridge temp. control. Make sure it's opening and closing when you adjustthe fridge temp.
The problem could be the electronic control ifyou have one or the mechanical linkages.
OR
The evaporator coil behind the cover on the backwall inside the freezer will ice up under normal conditions. Every 8 to 10hours for around 20 minutes the defrost timer (or in most newer models the electronicadaptive defrost control) will turn the defrost heater on tomelt the built up ice. There is a defrost thermostat which prevents the heater fromoverheating the freezer by breaking the heater circuit when the temp reachesclose to 32 degrees F. The entire cooling system shuts off during the defrostcycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue tobuild up until the air can’t flow over the coil to circulate the cold airthrough the freezer and into the fridge. The temperature change in the fridgeis usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater fromcoming on OR it won’t turn the heater off when it gets too warm. It is clampedto the evaporator coil at the top to sense the temp. If it appears to bemisshapen it is bad.
With an ohm meter it should show continuity whencold and none when warm.
You can also bypass the thermostat to see if theheater comes on then. If it does then you know the thermostat is bad and needsreplaced.
The defrost heater islocated on the evaporator. It is in a tube which is at the bottom and can alsogo up the sides of the evaporator. On some types you can see a burnt spot ifit’s bad. With an ohm meter it should show continuity from end to end whendisconnected from the wiring in the freezer. You can also test the wiring forvoltage when it’s in the defrost mode.
Ifyou have a defrosttimer youcan test it. It can be located under the fridge behind the kick panel on thefront. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shutsdown. The heater should now come on. If it does, replace the timer because thatmeans the timer is not running. If itdoesn't, check the heater and defrost thermostat. Turn the timer again tilleverything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer,replace it if the heater and thermostat test good. It is located in the fridgewith the controls in some models and on the back in others.
If you need help finding your model number seehere> http://www.appliancepartspros.com/modelnumber_locator.aspx
To locate your timer, motherboard, control or adaptivedefrost control , enter your model number and search for the part or post backon Fixya.
http://www.searspartsdirect.com/partsdirect/index.action?psid=26129238&sid=PSx20071217x00001a
Oct 08, 2009 | Refrigerators
Cannot turn off defrost mechanism
you need to have a defrost or the freezer will not work unplugging the time clock then the compressor will not work.if it is staying in defrost their is a manual stem you have to turn.Tom
Jun 18, 2009 | Freezers
Deforst mechanism
you need to have a defrost or the freezer will not work unplugging the time clock then the compressor will not work. Tom
Refrigerators Logo
476 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
