Question about HP Officejet 7210 All-In-One InkJet Printer
Printer wont work
My printer /fax machine turned off on its own this morning and wont turn back on it is only 1 year old
Wow, plug it in...what a genius! You must work for HP
Posted on Aug 01, 2008
    Scholar:
  • 162 Answers
Check the plug and make sure that plug is in. Also make sure the outlet has juice. If possible, try another plug.
Posted on Jul 25, 2008
Will not receive incoming fax. Everything tests OK
First, Connect the Phone line in Line 1 EXT at back of printer
Check the No. of Rings on your Answer machine.
If you have 4 Rings set on Answer machine then you need to set 6 Rings on the printer ( as simple 2 rings more than your Answer machine )
And you need to turn off ECM on the Printer setup
Press Setup button
Scroll till you find Fax Settings - Press OK
Choose Rings to Answer - Set it - 6 ( based on the Rings on Answer machine ) - Press OK
Check for ECM - Error Correction Mode - Press OK
Turn it OFF - Press OK
Check for Auto Answer option - Turn it ON too.
Try to receive Fax.. it should come thru.
Jul 01, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
How can i install the ink film?
Hello :
If you mean change then :
1: Turn the power off on your fax machine.
2: Open the front or top control panel Make sure not to force the door open.
3:Locate the ink cartridge. Gently pull the cartridge out. Set the cartridge aside.
4:Take the new cartridge out of the package and reserve the packaging. Remove the protective covers over the copper connectors.
5:Insert the new cartridge into the fax machine with the brand label toward you. Now place the old cartridge into the plastic wrapping and box that you reserved from the new cartridge. Recycle the old cartridge or dispose of it in the garbage.
6:Close the fax machine's access panel. Turn the fax machine's power back on.
Warning:
1:Touching the copper connectors on the ink cartridge could damage the cartridge. 2:Make sure that you purchase the correct cartridge for your fax machine. Purchasing the wrong one could damage the cartridge or your fax machine. good luck . please don't forget to rate !
Apr 04, 2010 | Panasonic KX-FHD331 Plain Paper Thermal...
My HP M1319f fax machine is having trouble sending faxes only to certain phone numbers. Is this a problem with the actual machine, or the phone line?
I have purchased the HP M1319f multipurpose machine 1 year ago and expected it to print as well as fax. Sadly to say 1 year later, the printing works as expected but the fax never worked consistently for me. The solution I found was to buy a used fax machine and only use the HP M1319f as a printer.
The problem I've read about this problem on HP forums was the fax speed of the M1319f. It is locked to 28.8k which means it is only able to communicate with some fax machines. Older machines that doesn't support 28.8 will get errors and the fax will fail. This is definately an HP problem but considering I purchased this 1 year ago, this problem will never be fixed. Avoid this printer at all costs if your considering to use the fax machine.
Oct 19, 2009 | HP Laserjet M1319F Laser Multifunction...
I have a mfc620cn. I have replaced the cartridges
This error code means that the size of the paper your machine prints onto is different to the size that it has received from another fax....take your paper out and adjust the side guides put the paper back in and then see what it says...
There may be a button on your console that says 'memory' or
"memory status". pressing this key should erase any documents in the memory.
if none of this works turn it off and leave it off overnight, if in the morning when you turn it back on the memory should have been cleared....dont turn it off at the machine turn it off at the wall socket so the machine thinks there is a power failure...this should make the machine print out a status report when you turn it back on.
The above is for the fax problem. For the unrecognized catridge:-
This is a usual problem observed in times of loose connection or dirty catridge contacts. Please make sure that the catridges are clean ( especially the contacting end ). Try cleaning with alcohol.
Sep 14, 2009 | Brother MFC-620CN multifunction Color...
Document jam
I had this totally annoying problem this morning. After looking for any obvious paper jams or small bits of loose paper, I tried several fixes: 1) open front cover, release levers that hold white rollbar in place, roll the bar forward to make sure nothing is stuck behind it, snap levers back in place; DID NOT fix the problem; 2) open top cover, remove print cartridge, look for jammed paper bits, close cover; DID NOT fix the problem; 3) unplug the machine, wait a few minutes, turn machine back on; DID NOT fix the problem. I even unplugged the machine, opened ALL the covers, turned the machine upside down and shake it to see if any paper clips, staples, or other objects have fallen inside the machine; DID NOT fix the problem. FINALLY, I pulled the paper feed tray forward, reached down to the feed rollers, twisted them a few turns, put paper back in the machine, and the "paper jam" message disappeared! This may not work for everyone, but it worked for me today, so I hope this helps someone out there to have a better day.
Oct 25, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
Canon MP 830 Error 6a00
thats because 6a00 is a service error not a user error, It could be down to use of none canon inks glogging the ourge unit up after time, it could be due to paper or objects in the purge, i would take the covers and inspect the purge and make sure that it moves back and foward, who ever told you to turn it upside down is having a joke., that will never work. Some times it could be gearing on the back on the purge.
I would ask for a service engineering, depending where you live i have a few contacts. Mp830 is a very good product and you shouldnt have alot of problems.
Oct 14, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Error Message: "Contact Your Dealer Printer Error E04-01" - What does that mean?
you can try a LBP fuser reset and LBP error log clear . this might fix the problem your having.
Mar 14, 2008 | Panasonic PanaFax UF-8000 Laser Fax
Machine Died?
We had the same problem at our office. Our machine is also about 1 year old. We checked the warranty and it is covered under a 3 year manufacturer warranty.
The repair person said that the whole motor gave out and they are replaceing it with a new one.
Get it fixed for free.....its still under warranty.....
Hope this helps.
Dec 26, 2007 | Quartet gbc Shredmaster 4550X...
Engine failure notification
Yep. Most likely you could replace it for the price of repair
Nov 12, 2007 | Xerox WorkCentre 385 Laser Printer
Scanner quit working
the scanner works with the windows built in driver. Uninstall the hole mfc suite and reinstall after restart. This is the fix for the software. You can check the hardware simply by copying a page. If you can copy there is no hardware prob. Post here again if it does not work and let me know your windows version, too, please.
Sep 29, 2007 | Brother MFC 420CN All-In-One InkJet...
HP Officejet 7210 All-In-One InkJet Printer Logo
41 people viewed this question
Seeker5211
Seeker5211
