Question about Radio Communications
Motorola MCX1000 Model no :MBT44UXA7H00AK
Hi there, could you tell me how to hook up my old MCX1000 for power, i have the main box, the front module, the mic and the speaker. But i am not sure on how to hook it up so that at least the display will power up or more. It is to put in my show police car. Thank you verry much 1
Simon
My email is: simonthuot@hotmail.com
  • 27 Answers
Sure, the red lead goes to the battery pos and the black lead goes to the battery neg as some cb radios have a reverse polarity idiot diode fitted, go with caution. With a multi meter you can find the neg terminal using the continuity or the low ohms
select on the meter...1 meter lead goes to the metal body of the set and the other lead goes to one of the power leads WITH THE SET TURNED OFF when the meter responds to a contact and shows low ohm reading you have found the neg lead..this lead is directly connected to the fram/case of the set. With a few sets
you need to have the mike connected in order to power up.
flyingfox@people.net.au
Posted on Jun 23, 2008
Ignition wiring for 1996 Geo tracker
old posts.
are you saying the Head lights are dead too?
the main fuse box (fender right) to cab box is bollixed.
fubar, hosed, mangled. ok.
10 points for getting the wire color... good going.
the whole wiring , is documented in section 8 (army code for crazy, lol)
10-8
cover this.
on the first page.
http://www.acksfaq.com/trackerfsm.htm
and this page, shows what crappy Geo\'s do on salted roads.
the Green-white runs the whole ignition switch power feed.
from the 60amp main. fuse. is the fuse blow
or this?
fuse good, and still bad.
the green death?
http://www.fixkick.com/electrical-failure.html
Apr 17, 2014 | 1996 Geo Tracker 2 Door
Motorola DVR Model DCX3501-M front display shows the channel selection. I want it to display the time of day and only show the channel selection when I am changing channels. The manual is of no help
It is a cable provider setup within the menu. On charter here are the steps - menu, TV guide main menu, setup, Cable box setup, front LED display.... I don't know what these other people are trying to answer for you...lol. You can also adjust the brightness display by pressing power followed by menu (starting with the tv on).
Jul 27, 2012 | Motorola Televison & Video
2007 dodge ram 1500 fuse box cant find aftermarket one .one from dodge is $600.
The fuse box is actually called a TIPM totally intergrated power module. fair common problem on dodge trucks sad to say. it has the front control module attached to it.
Feb 15, 2011 | 2007 Dodge Ram 1500 Quad Cab Sport
Where's the junction box to hook up main power cord
Underneath the dishwasher behind the kickplate... usually in the right front corner...
heatman101
Jan 05, 2011 | Whirlpool 24 in. DU1100XTPS Built-in...
Need to know about module
That box is called the BCM(Body COntrol Module)
Jul 06, 2009 | 1995 Chrysler LHS
Ruud urgh07e36jkr heater wont turn on
Well I checked and the pilot would light and then go off right away and repeat.I jumped the 24v terminal to the pv pilot valve terminal on the ignition module and the main burner lit up. I then disconnected the spark igniter and the burner shut off and it tried ti relight producing hi energy sparks from the ignition module. So I ordered the module from american hvac parts online and replaced it. I recieved an updated module and had to hook up the 24v to the th-w terminal to make it work the old module was a s86ooh
And i just searched the new model number to figure out how to make it work. The new one has self diagnostics on it. It cost 208$ with shipping
Dec 11, 2008 | Ruud UAMB Air Conditioner
How to hook up
hi Becca - does the tv have RCA jacks on it? ( the round holes, usually red,white and yellow)
May 12, 2008 | Sharp DV-RW340U DVD Recorder/VCR
Mitsubishi wd-62825 dlp
The WD62825 has a Digital Module located on the left side of the chassis looking at it from the rear of the set. It's housed in a metal box that can slide out of its holder after removing the trim screws.
The module has its own power supply board and there are a group of 16v/1000uf caps on that board which commonly fail causing the constant flashing standby light. Further back on the module is a small board about the size of a matchbook called the E2P module. Its SMT (Surface Mount Technology) caps also commonly fail which can cause the same symptoms. Techs can tell whether the E2P has failed by simply removing it, hooking the DM back up and trying to power the set. If it powers on the picture won't be much good - but at least you can tell what's keeping it down...
Back to the caps on the pwr board. If they've failed they usually will buldge visibly on top. And ESR is almost not necessary. In any event that's the nuts and bolts on this model.
Is it a job for a layman? Yes and no - you might strongly consider a tech if you don't feel comfortable removing all the connections that the DM has with the signal board. There are about six - multi-pin - wired connections to unplug and then sliding the DM out of the unit and carefully removing the screws and latching to take the DM top cover off...
Hope this helps.
Bill
Oct 29, 2007 | Mitsubishi WD-62825 62" Rear Projection...
Radio Communications Logo
284 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
