Slinte please help me fix my Panasonic!
Ok I know you answer a million questions a day, but here's my problem. I have a Panasonic PT- 51hx42f Rear Projection TV. It works but shows alot of red with a glare reflection of whatever is on tv. I have tried adjusting convergence, but it will not change. If you can tell me anything like what parts you think I could buy to fix this problem and from where would be a great help. Thankyou in advance, David
Ps. Do you have an actual email address so I can send you a picture of the problem. Tried to send a picture on here, but said the picture was to big!
  • 8,617 Answers
Yes you can respond directly to me at slinteriors@yahoo.com and I would be happy to assist you with your problem.
Posted on Jun 19, 2008
I have a 51" Panasonic Rear Projection HDTV,
Try disconnecting all of your HDMI cables and plugging the power cord of the TV into another wall outlet. If this resolves the issue, you may have had a small power surge from either your wall outlet or one of your source devices. It is recommended to connect your TV to a surge protector if you haven't done so already.
Aug 12, 2013 | Televison & Video
Panasonic pt-51hx42f replaced 2 convergence chips and 6 convergence resistors. still can move any of the convergence set-up arrows. was told it might be the pico fuses. But I cant locate them on the...
No thats not the Problem you have to know HOW TO ENTER SERVICE MENU Their is a Long Step in getting into the SM
if not done correctly you can really Mess this TV up! Once you Enter the service menu then you can go to convergence and adjust
to correct Pattern,Then you Must Exit correctly with the Save Mode to Save alinement or you will have to adjust all over again.
Sep 20, 2010 | Panasonic PT-51HX42 51" Rear Projection...
Pt-51hx42f 3 red blinking lights come on when i try to turn on tv
hi friend i appreciate the words of praise that you have given, but i only know what i have studied and still do study. i also learn more as i repair more. i wish i could give you an answer to the three blinks, but panasonic does not share its information as freely as sony. i will tell you this. i have replaced the convergence chips before. i have seen the burned resistors before. and i have seen the set come on and last from one day to one week. if you are going to get chips i would replace all of them and i would definitely not go cheap. the cheap burn out fast. sometimes you will luck up and get some good ones and sometimes you will not. when i have convergence problems i replace the board. (partstore.com) this way you eliminate changing cap, resistors and a host of other problems. the really good chips cost around $46 a piece, the board cost around $160. now since you do have them. cut the legs off close to the board and simply desolder them one at a time. then take your time and resolder the others. this has to be a skill of patience, but i know you will triumph. tell me also what was your tv doing before it went out completely. please rate my solution and thank you, you are very kind.
Nov 18, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Panasonic pt 52lcx66 won't turn on
Sounds like the light engine. Is this a DLP or LCD rear projection? Did you see any patches of color any time before the problem with the really dark screen. Please rate my answer and let me know what other questions, Tech Malick
Jan 31, 2009 | Panasonic PT-52LCX66 Projection Television
Panasonic PT-50LC14 Service Manual
did you try the panasonic website??? if not e-mail me i have one, and could hopefully answer any question you have.......spqr163@yahoo
Jan 21, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Pioneer PT-51hx42f
hello. it sound like a power supply . problem to me.!!! check it.!!! "good luck"
Aug 02, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Panasonic Rear Projection PT-47WX42CF42
Make sure your yoke plugs are clean and no cold solder joints around them. Let me know? Do you have a scope?
Apr 04, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic IC's
usually you can see the resistors being a little discolored as they dont have color bands on them. If you dont notice any discoloration on those resistor you should be good to go. There are about 7 or 8 resistors right next to the ics they stand up off the boards easy to spot, just look them over real good.if you notice any discoloration let me know the code stamped on the resistor and I will give you the ratings of the resistors.
Mar 01, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-51HX42F
Sometimes, in the Panasonic projection sets, one of the convergence IC's shorts out and draws so much current that one of the resistors next to it glows red hot. The computer senses the extra current and shuts the set back off. This is quite an easy problem to correct, but the set should be serviced by a qualified tech familiar with panasonic projection sets.
Aug 23, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Televison & Video Logo
89 people viewed this question
Top Televison & Video Experts
