Hi, I found a Wurlitzer organ that I am thinking of buying but the D, D#, F and F# keys don't work of the upper and lower key boards. The keys sound responsive but don't make the noise that an organ key should make. Is this organ worth buying? How can I fix it?
    Novelist:
    Champion:
  • 236 Answers
You may have trouble finding the parts for that. But if you know a place where to get the parts for such brand and model then you just have to buy replacement for the rubber contacts of all the keys, it seems though sequencial keys maybe it got dirtied by some liquid and the owner did not try to clean and dry. maybe you can have it checked or try to keep a closer look in the keys, the area that keys doesnt work if any sign of liquid spill before. no use getting it if you find some sign of it.
Posted on Jun 19, 2008
Why lower keys dont come on , on a kimball model 700-775
I think you are speaking of an organ.
Your organ has electronics inside it, and I believe the circuit board for the lower keys has a broken connection.
You should find an electronic organ repair place.
I just looked online and found several places.
Since you may be near to none of these, relay on your computer to find someone who can repair this circuit board.
They will have to tell you how to take it out of your unit.
God bless your efforts.
Feb 24, 2017 | Music
QS8 keyboard. Why is volume in organ mode much louder than piano mode when I switch between modes without touching volume slide?
On organ mode, in general, almost all brands of the modern keyboard, velocity setting is not enabled. Setting velocity is used to determine how much the level of the sound that follows how strongly you press the keys. It is really just to imitate the sound of vintage organs, which in the past, electronic organ technologi not use the velocity on the keys. So, how strong / slow we press the keys, the sound level will remain the same.
At the Piano mode,modern keyboard using setting velocity. This also to imitate an acoustic piano, which, if we press the keys slowly, the sound level will be slow as well, and vice versa.
So, in your case,at the same volume slider, try to play on the organ modes, note level. Moving to the piano mode and press the keys securely powered (full power). Then the sound level should be equal to the organ mode.
On modern keyboards, also included organ sound that added velocity setting. Usually found on the user bank.
Sep 01, 2015 | Alesis Music
Alesis QS8 keyboard. The volume of the organ is much louder than the keyboard when I switch between both modes without touching the volume slide. How can I fix this.
I have a 1983 wurlitzer omni 4000, power comes on, keys light up, but no sound in upper, lower, or pedal. Could this be something as simple as a fuse?
I have one with the same problem and am trying to find a solution too.
Please leave a response on this website if you find a fix and I will do the same.
Good Luck
Oct 22, 2012 | Cars & Trucks
ORLA R610 factory reset keys
hi there try Hold down the 4 Lowest Keys on Upper Manual C C# D D# hope this helps you
Jan 06, 2012 | Computers & Internet
MY WIFE WAS PLAYING THE ORGAN THIS MORNING, SHE HEARD A SNAPPING SOUND AND THE KEY BOARD WENT DEAD UNTIL YOU GET TO THE NEXT TO THE LAST C ON THE LEFT SIDE OF THE KEY BOARD. ALSO THE VOLUME LOWERS ITSELF...
Servicing is obviously required. By the symptoms, I think a bad electrolytic capacitor is the likely culprit. One other possibility is contamination, including an insect has gotten into the works and causing a short at some point.
Nov 15, 2010 | Music
Wurlitzer organ, highest key plays note one octave too low.
If this is the kind of organ with the wire sticking out of the key that makes contact with the bus bar to create the note you will have to make sure that key is operating the same as adjacent keys. The busbars have to be clean and the contact wires have to be clean. Sometimes when cleaning the wires they will spring out of place and not make contact with the appropriate bus bars. Check that key against the rest and see what you find. Hope this helps.
May 17, 2009 | Music
On my Technics EX-70 organ, have lost my presets that were originally set up by a professional teacher who is no longer available. I need some detailed help in programming the Voice Setting Computer and...
To Big Gord. To program voice setting computer, set up a sound you want press & hold white button then button 1 while still holding
white button. repeat for other setups. before turning organ off always press cancel on VSC should hold settings for next time you use it.
To set upper organ presets, the sequence is shown on page 17 of the manual.
To RishiMalla. To reset organ turn on Fullband Setting Computer switch then press black Inital key on bottom key board.
Feb 28, 2008 | Audio Players & Recorders
287 people viewed this question
 Grubhead
Grubhead
