Question about Dometic Rooftop RV Air Conditioner
Remote thermostate Is it OK to replace the batteries in the remote thermostat with rechargeable batteries? This has been the most troublesome air conditioner we have ever had, and I think it is because of the remote. It is hard to keep the signal going from the thermostat to the air conditioner. Is it possible to replace the remote with a regular thermostat and if so what costs would be involved?
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
No,its not possible, what about manually control and forget the remote!
Posted on Aug 28, 2008
Can reset everything on my SkyScan Atomic Clock except for the outside temp. Have new batteries in both units. Main clock and outside remote thermostate..Any suggestions??
I expect that since the unit reads the outside temperature from the remote thermostat, there is no need to "reset" the displayed number since this data is obtained live from the thermostat.
Nov 04, 2015 | Home
Skytech receiver batteries keep going dead
Joe,
The heat from the fireplace can have an adverse effect on the life of the batteries. Sometimes simply re-positioning the receiver to a cooler location under the firebox and/or adding a heat-shield can improve battery performance with the Skytech remote receivers.
As a test, you could even place the receiver outside the fireplace for a period of time to gauge the effect of heat on the unit.
According to the owner's manual for the Skytech 3301 Thermostat Remote:
"For REMOTE RECEIVERS that operate on BATTERY POWER, these heat conditions can cause batteries to discharge when temperatures exceed 115 degrees F. Studies show that alkaline batteries, when exposed to a constant temperature of 120 degrees F, can lose up to 50% of their operating power. When the battery cools down, it will partially recharge itself, but constant heating and cooling will reduce the battery's normal life expectancy."
Hope this helps!
Dec 01, 2012 | Skytech 3301 Thermostatic Gas Fireplace &...
I need to replace the 4 cell rechargable ni-cad battery for my Denon RC 8000 remote control.Denon informs me that the battery pack is no longer available.Is there another manufacturer that has a compatible...
Hello
Nickel-Cadmium battery will have a voltage of 1.2V. Four cells together with in series connection give you 4.8VDC, The number 8000 on Denon battery denotes, that it has a current rating of 8000ma [milliampere]. Most of the Ni-Cd batterys will have the same rating. You can use any company's prodcut, provided the size should be the same. That is all. Some battery packs will have 1 ampere capacity, can be used in place safely. No problem at all. OK.
Mar 29, 2011 | Denon RC-8000 LCD Touchscreen Remote...
I replaced the batteries but the remote does not
Ur Lithium battery fully take in the charges,u recharges?Let the rmote sit without battery about couples hours.Put battery back in again,should work.
Apr 22, 2010 | Logitech Harmony 550 Remote Control
Remote thermostat off several degrees
if you can locate the sensor the remote thermostat is sending the signal to you may be able to get terminals to wire a thermostat to let me know if it is possible what the terminal letters are normally G is fan, Y is cooling, w is heat, red is 24v hope this helps
Jan 06, 2009 | Dometic Rooftop RV Air Conditioner
Carrier Weathermaker gas 8000 will not ignite
1. check indoor unit wiring.
2 check sensar of thermostate.
3if not change thermostate
Mar 25, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Dometic Rooftop RV Air Conditioner Logo
141 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
