Back to:
Tags:
IBM ThinkPad T40 2373 PC Notebook
Defintely getting power, but not switching on. (by 2 users)
posted by Tommy_TomTom on Jun 19, 2008
Hi. I've got a Thinkpad T40 which worked one day, the next when I came to switch it on nothing happens. The power is working fine because when I plug in the adaptor the battery light indicates that it's charging (orange) then eventually indicates that it's charged (green). However, the thing simply wont switch on with or without the battery plugged in or the adaptor plugged in. The laptop was not moved from one day to the next, so I've no idea what could be causing the problem. I even tested it with a different adaptor to be sure and I get the same problem.
Any ideas, anyone?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Jun 20, 2008
I have the same problem. It shut down when I plugged in my phone to sync and will not turn back on.
Best Solution
Helpful (85)
Pyrhyc
Rank:Guru Guru
Rating: 86%, 1020 votes
There are several possibilities. Let's start with the easiest two. First the battery, take it out and try starting up only with the power supply. Then the memory chips. If a memory chip fails it can cause a no start in IBM's. Take the memory out and try it. Then try it, putting them in one at a time. If these don't work, then I'm afraid your problem lies within. Namingly the power management chip on the motherboard. The pm chip controls the power input, and allows such functions as switching between battery and AC, and battery charging. The pm chip can go without warning, and just because it lights and shows charging doesn't mean this chip hasn't malfunctioned. I've had several IBM's come through my shop that have experienced the same problem you're describing. I've also had them with problems like; it will only power with the battery, won't charge the battery, will charge battery and only run with battery shuts down while charging, only power under AC, etc... all pm chip related issues. Unfortunately, the only solution is motherboard replacement.
Rating Locked! (?) Tommy_TomTom has rated this solution as Helpful
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Defintely getting power, but not switching on.:
I don't want to Accept this solution
Can you Help with these PC Laptops problems?
PC Laptops
Power button does not respond. Screen is black, lights are...
PC Laptops
The charger slot on my Amilo Pro v2055 laptop had become...
(posted by dgm9 on Nov 15, 2007 -...
My printer won't print anything, can you please help me...
R40 Thinkpad - 4 years old - Windows XP - CD / DVD player...
Loading problems.
Repair Service
Find PC Laptop Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
