Question about Whirlpool Dryers
Does not dry clothes. I can run it for three hours before they get dry. The outside of the machine is very hot to the touch. Vent seems to open as I can feel the exhaust outside.
  • 413 Answers
Although you may feel the exhaust, the airflow my not be sufficient to dry your clothes efficiently and costing alot of money on your utility bill. A hot machine is a good indicator that this is the case. Proper airflow across the heater is important to maintain heater efficiency. If airflow is poor, the heater will overheat and eventually fail. If the vent system goes through the roof, the vent screen is probably blocked. If the vent system is longer than 10ft, there is probably lint accumulated in the pipe. Check out this site http://www.linteater.com/.
Remember..the purpose of the dryer vent is to get rid of moisture. If the moisture can't be removed quickly....the clothes will take a long time to dry, no matter how much heat there is....
Posted on Jun 19, 2008
Hotpoint A1400WD Washer Dryer
Check your dryer vent (probably outside) to be sure something or a kid hasn't flattened it, making it not vent moisture properly. Replace the vent or pull it back out so the damper door will open.
Feb 26, 2014 | Dryers
Dryer has to run two or three times to dry clothes seem to be hot enought. any suggestions
Check your lint filter. Keep it clean every time you dry clothes. If it is clean ther is a good chance the hose that carries the hot air and lint from machine to the outside of the building. Also the lint fan may be burned ot. YOu should feel air blowing when you pull the lint filter out of the machine. If not the motor is shot.
Sep 24, 2010 | Dryers
Dryer is hot when opened, but takes 3 or 4 timed cycles to get clothes dry on very dry setting and timed setting
Check for a restriction in exhaust system,not just behind unit but all the way to outside vent,should feel warm decent airflow at outside vent.If not all you will end up with is warm moist clothes,You need good airflow to take away the moisture in the clothes not just heat.This issue can happen slowly over time and next thing you know its taking two or three times longer to dry even though when you open the door its hot inside.
Good luck
Aug 08, 2010 | Amana Dryers
Whirpool dryer takes 3 hours to dry jeans or towels.
Most likely your heating element has partially failed. Some dryers have two separate resistance heaters in them. If one fails what you are describing can happen. If you have the tools and are willing to take it in it's not that bad a job. You have to take the cover off the dryer to see it, then it is two bolts. Any appliance repairman can handle this easily.
Mar 22, 2010 | Whirlpool LER5636P Electric Dryer
The dryer takes three hours to dry a large load. It is almost one year old and it seems to take longer than it used to and the clothes don't actually get that hot anymore
is your dryer getting hot if so disconnect your dryer vent and run a normal load and if it drys that load in a normal ammount of time it is your vent pipe in the wall clogged
Mar 16, 2010 | Maytag Dryers
I have to run the dryer cycle three times before the clothes are dry.
Your exhaust is probably clogged. Your macnine must be able to breathe.
Pull your machine away from the wall and check that hose all the way to the outside. Check that outside vent device as well, make sure it will open and close as is necessary. While you have it open, run a vacuum hose into the dryer to assure no clogging internally.
If you can do it, I suggest you replace your plastic hose with a aluminized hose available at ACE and other good hardware stores.
Thanks for your interest in FixYa.com
Feb 05, 2010 | Whirlpool GGW9250PL Gas Dryer
Wont dry clothes, i can turn it on and wait a second then open door and heat appears to be onbut it seems to take hours and hours to dry a load
You may have a blocked vent.
Remove the connecting vent from the rear of the dryer.
Run a load of laundry.
Use timed dry at 50 minutes if possible.
If it dries correctly clean and repair the exhaust vent.
Dec 26, 2009 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Dryer gets hot but wont dry clothes
Do you know if the dryer vent is free of obstructions?Check outside where the dryer vents outside ,and see if the air is weak or flowing freely.If it is not clogged the air should be pretty strong from the vent outside.If it has blockage it will definitly take longer to dry your clothes.
May 17, 2009 | Roper RGX4634KQ Gas Dryer
Dryer heats up but clothes won't dry
Sounds like to me, that you need to check the vent going outside from the dryer. I had the same problem, and found a birds nest in the dryer vent on the outside of my house restricing air flow. If that doesn't fix the problem, look into a new heating element and or thermostats for the dryers. The old ones could just not be getting hot enough anymore. Good luck.
Apr 08, 2008 | Whirlpool LER5636P Electric Dryer
Dryers Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
