Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
How can I copy in blk. & white. It will only print in colour?
Im not able to print a copy from the glass. I set it on blk & white but it keeps coping in colour.
    Problem Solver:
  • 5 Answers
Set it to black and white then save the settings
Posted on Jul 12, 2008
Copier leaves a black line when printing through the top paper feeder. Ok coping from the flatbed
When copying from the feeder the page is fed across a fixed point at the head of the flatbed. Any dirt etc on the glass at this point can present as a dark line running vertically down the printed page. When copying from the flatbed, the scan head is moved down the page so any dirt on the glass will only appear as specs. Try cleaning the glass, especially at the head of the flatbed where the feeder is loading the page to be copied.
Jan 12, 2014 | Office Equipment & Supplies
Mg6150 wont print in colour
Make sure that u have made this the default printer first. Then go to start control panel then printers folder. See if there are other printer listed . THen right clk on this one go down to properties. Make sure it is config for color not blk white..then hit test print button..see if it comes out.
Check the printer setup to..might need to update firmware.
Good luck
Dec 24, 2013 | Microsoft Computers & Internet
Black vertical line when coping
if you make a copy form the glass is there any lines. if not clean the small glass on you left.
you can also press menu
menu agian
go to test
look for shading
swich unit off and on.
Oct 21, 2011 | Samsung SCX 4521F All-In-One Laser Printer
How do i use only black ink in this printer? its asking me to put the color ones in there and i dont want to do that bc it keeps wanting to print color and im out of color ink?
you can select to print only in black from within the print driver under preferences in the print screen.. but now that the tricolor is needed to be replaced you must replace it before you can proceed once you do that you can select it to print only in blk
Mar 31, 2010 | HP Officejet Pro L7680 All-In-One Printer
Put in a new color cartridge, but it still prints blk & white
Go in to the setting to see if you have enabled colour, it may be set to print in black only. check the cartridge to see if the ink is actually coming out. I once had the same problem when using a refillable cartridge and the chip on mine was faulty and had to be taken back to the shop.
Mar 12, 2010 | HP PSC 1315 All-In-One InkJet Printer
White Out Line
wjite areas are usualy to do with dust on the scanner mirrors or on the lens slips for the laser unit. when you lift the feeder of the copier put a liece of paper on the glass and do a copy if you look at the scanner mirors where the bulb is you might see some dust either white paper dust or dirt this has a blanking effect on the copy quality also if you are connected to print to the machine and the copies are fine then this points to the copy side of things and the dirty mirrors.. they can be cleaned off with a dry cloth.. first turn off the machine then undo the screws holding th covers on the top holding the glass in place.. then gentley move the scanner to the side so you hav eaccess to the mirrors and gently wipe the dust off.. then replace glass and covers and try again. if the lines are still there the problem is with the dev units or toner supply.. also check the amount of toner in all cartridges as this will afffect the colour balance if one is out..if you let me know what machine you have I can probably get more details on proceedure
Aug 13, 2009 | Office Equipment & Supplies
Printing black line when coping
You may need to replace the toner cartridge or the fuser assembly.
If you open the toner cartridge door and see a black line on the roller, you will need to replace the cartridge.
Aug 07, 2009 | HP LaserJet 3050 All-In-One Printer
Black line down page when coping from copy feed
The small glass surface at the top of the scanner bed had some gunk on it. I scrapped it off and the line went away! Yay!
Jan 01, 2009 | Brother Multi-Function Center MFC-240C...
Photo-copied Blk & White pictures come out with a pink tinge instead of blk & white.
haven't come across this problem myself, but renew all the ink cartridges, using Epson genuine only and no refills
Feb 09, 2008 | Epson Stylus RX500 All-In-One InkJet...
I want to print black only
On the programs that you want to print off you can select to print in black and white or grayscale.Check File>print setup>printing properties.
if it still wont allow you to print remove the empty colour cartriges and leave only black.
Jan 20, 2008 | Epson Stylus C60 InkJet Printer
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
