Getting error message that says flash error, back up the data and format the player
  • lincec Jun 22, 2008
    Problem Resolved. Thanks
  • 8,596 Answers
Depends on the manufacturer/model # - i would highly suggest checking the manufacturer's website for your product first before trying my methods:
There are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
Posted on Jun 20, 2008
SOURCE: mp3 player has an error
save from mp3 to your pc hard drive and right click the mp3 iqon and click format then when done put the songs back on ..
Posted on Dec 23, 2007
SOURCE: flash error message
You should try to reload the songs on
Posted on Nov 07, 2008
  • 8596 Answers
SOURCE: ILO MP-556 MP3/WMA player
Revised iLo instructions for Windows Media Player 11:
Connect the iLo to the computer
In Windows Media Player 11, Run the mouse over the Sync tab
Click the little black arrow that appears underneath the Sync tab
Select More Options
Click the Devices Tab
Highlight the iLo
Click Properties
Uncheck box, "Create Folder Hierarchy on Device"
Download the firmware file at:
then proceed with the rest of the directions
-Tha Mp3 Doctor
iLO Mp3 Player
"Flash Error"
1. Connect the player to the PC using the USB cable. 2. Open Windows Media Player. 3. Go to the Sync or Devices tab and delete all content from the player. 4. Go to the Tools menu and select Options. 5. Select the Devices tab, highlight the ILO or Siren player and click on Properties. 6. Uncheck the box "Create Folder Hierarchy on Device" ---- "Firmware Upgrade" (provided by jwmgotee):
I just repaired/reformatted my 1.0 GB Ilo following the instructions below with no problems:
Please connect the player to a rear USB port on the computer. The display should show “USB Connectedâ€
. (If not, please press the power button.) Please make sure that all unused programs and applications are closed. You can close the applications by closing as many of the icons in the lower right hand corner (by the clock) as possible. Download the correct Firmware Click here ( to download the ILO 116 Firmware Click Open to initiate the download Double click on the ILO or Siren folder icon. There will be 14 icons. There will be a Setup icon that looks like a box with a blue line on it; please double click on this. Then click Run - this will open the Install Wizard. The Install Wizard has the instructions on the screen as you go through it. Once the firmware has installed, please click the Start menu, then Programs. Look for the icon that says ILO or Siren, and then double click the Firmware Update to install to the player. Depending on how severe the corruption to the firmware on the player is, you might have to do this step 2 or 3 times in order for it to completely repair the firmware. It will now search for the ilo. This may take a while depending on how corrupted the firmware is, so be patient.
After it has found the ilo, it will say, "A device has been detected in recovery mode and is being initialized. Please wait."
The ilo should come back to life and start showing it's glorious "USB Connected" screen.
The "Firmware Update" window should appear. Select "Format Data Area" to rid the player of corrupted firmware data. And click "Start".
It can take anywhere from 2 to 4 minutes to re-flash the ilo and the program might appear to have locked up, but it hasn't. So don't close the program or disconnect the ilo!
If the program fails to find the ilo and gives you an error like, "Device Timeout" or something similar, you need to reinstall the ilo drivers. This can be done by inserting the ilo cable into a USB port it has never been plugged into before. Or you can reinstall the drivers by reinstalling the Rave-MP program. (Remove it, restart the computer, and then install it again).
Although, plugging it into a new USB port is the fastest and easiest option.
If your player won't even turn on, follow these instructions first and then those above:
First, remove the battery. While this isn't necessary to get the player into recovery mode, it insures the unit will not power on before the cable is inserted.
On the ilo, hold the "Power" button down while inserting the USB cable. Continue holding the power button down for 5 seconds more after the cable is inserted. The backlight on the ilo will remain off during this time, making the screen appear to be blank.
An hourglass should appear on your computer and Windows should say,
"Found new Hardware 'SMTP3500".
Posted on Jan 10, 2009
  • 59 Answers
SOURCE: flash error backup data and format
just connect it to the computer then save all ur folders to ur desktop thats the easy way to back up data
Posted on May 15, 2009
  • 98 Answers
SOURCE: flash error! please backup the data and format the player
Umm... Vague, but I'll work with it. Connect it to a PC. under "My Computer", find your device, and right click it. You should see "Format Device", or "format".This will remove any and all media from the device, as well as clear your settings.
Posted on Jun 02, 2009
How to recover from format error message in walkman
Format error are often shown if the file stored on your Sony NW-E505 is not recognized by the system. Try to review the supported audio formats of your player,use audio (format) converter for better compatibility.
Aug 27, 2009 | Sony NW-E505 MP3 Player
Usb flash drive problem
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
1. Download this tool:
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Nov 11, 2008 | iLO (2 GB) MP3 Player
Flash error ,back up data and format the player
it keeps saying format the player and back up the dta
Sep 04, 2008 | iLO (2 GB) MP3 Player
Mp3 player not working
mp3 player is showing a flash error message.Please back up the data and format the player.
Aug 29, 2008 | iLO (2 GB) MP3 Player
I cant get into mi psp internet
I have a error message on my ilo digital audio mp3 player, how do I fix this problem?
flash error!
please back up the data and format the player.
Aug 19, 2008 | Audio Players & Recorders
Flash error message
Jun 05, 2008 | Audio Players & Recorders
just do what the message says, just back up & save your file & then format your mp3 drive..
this error occur when some files is corrupted or your flash drive is in critical status.. this will be resolve when you format the mp3 flash drive..
thank you
May 28, 2008 | iLO (2 GB) MP3 Player
Trutech mp3 player
I fixed this error by right clicking on the internal storage withing the player, formatting. Then copy one song to the flash, and while it is still plugged up to the computer, double click on the song within the flash it'self as if to play it on the computer. Allow it to play a little and then disconnect the player from the computer. Play the song that you copied. Then you can re-attach the player to the computer and copy songs back on to it.
Feb 03, 2008 | Koss CDP3600 Portable Personal MP3/CD...
Flash error
same here just a diff mp3 ...
Nov 25, 2007 | MyMusix PD-6030 MP3 Player
Mp3 player has an error
My Musix MP3 when turned on says flash error please backup the data and format the player. When I put it in the computer no message to tell me how to do this comes up. I don't have the manual anymore. Please advise.
Oct 24, 2007 | MyMusix PD-6070 MP3 Player
