Spilled liquid on keyboard. Keys don’t work - Computers & Internet
    Problem Solver:
  • 10 Answers
This is going to sound crazy but has worked in the past...
wrap the end of the cable (the connection tip) in a plastic bag, Wrap the wire around the unit and put it in your dish washing machine. Put the stetting on low and wash.
Please let the unit dry before trying it out!
Posted on Jun 19, 2008
Four keys in Belkin wireless keyboard are not working
If only specific keys are not working, something is obstructing those keys\' pickups which are located immediately beneath the keys. This is almost always caused by food debris or liquid spillage as dust doesn\'t provide particles big enough to cause issues.
If those four keys feel "funny" when being pressed, it\'s almost certainly a physical obstruction. If they feel "sticky" it\'s always a liquid spill. If you don\'t recall spilling anything over the keyboard, use a can of compressed air (found at office supply stores).
Turn the keyboard long side up, with the keys leaning slightly downward. Place the air nozzle close to the intersections of the keyboard, starting at one side and work your way to the other side, using short bursts of air. Repeat for every row of keys. Pay special attention to the four that do not currently work.
You\'ll probably see lots of junk fall out of the keyboard. That\'s good, if so--I would then retest the keyboard (no need to reboot the computer). That should fix it--if not, you may have to resort to pulling off the keys that don\'t work. The next possibility would be broken key hinges, but that\'s beyond the scope of this reply.
For liquids, cleaning is hit or miss. If left long enough, liquids will eat away at the circuits, or provide a short circuit and kill the component. Since only four keys are affected, I\'m really leaning towards food debris, but if you did spill a liquid, you can disassemble the keyboard and clean up any residue under and around the keys. Probably best to use rubbing alcohol and a q-tip for that--but if you\'re not comfortable taking stuff like this apart, it might be time for a new keyboard, or find a handy friend. Good luck!
Apr 07, 2014 | Belkin Wireless Keyboard/Optical Mouse...
Tip
Spilled liquid on Keyboard!
1. Purchase plastic keyboard cover. 2. Keep coffee etc. anywhere not near keyboard.
For spill, unplug keyboard. If non sugar liquid, invert keyboard, shake or tap gently. Wipe with lent free absorbent cloth while still inverted. If soda or coffee with sugar, pour 1/4 cup of clear clean (distilled the best) water onto keyboard (yes), Then invert. Let dry a minimum of several hours still inverted. I cheat with a hairdryer on low 6-12 inches. After keyboard is completely dry (and cool). Plug in after turning computer off, restart, test all keys, including shift, option etc. If keys miss or don't work buy new keyboard and cover! Aloha, Cliff
on Sep 27, 2014 | Apple 24" iMac Desktop
Some keys keyboard don t work
. Maybe some liquid spilled on the keyboard? If you are capable, you will need to open up the keyboard and clean the contacts with a q-tip and some alcohol.
Oct 31, 2013 | Music
Keyboard dont type
No matter how careful you may be, knocking a cup of coffee or spilling a glass of soda over your keyboard may happen. This does not, however, mean the end of your keyboard. If you act quickly, you may be able to fix your wet keyboard to avoid any corrosion of its electronic components or any short circuit which might render it unusable. By following a few recommendations, you should be able to fix your wet computer keyboard.
Unplug the keyboard from your computer immediately after the spill to avoid any corrosion or short circuit. If you spilled water over your laptop's keyboard, turn your computer off by clicking on "Shut Down" on "Turn Off" in the start menu, unplug the power supply and remove the battery. Turn the keyboard upside down and shake it to remove most of the water from it. Take a hair dryer and set it to its lowest temperature setting. Use it to dry any water which might remain under your keyboard's keys. Wait at least 12 hours before plugging your keyboard into your computer again. If your computer is a laptop, wait 12 hours before turning it on again. For Other Liquids Disconnect the keyboard from your computer immediately after the spill to avoid any short circuit or corrosion. Turn your computer off by selecting "Shut Down" or "Turn Off" in the start menu, remove the battery and disconnect the power supply. Place paper towels on a table, turn the keyboard upside down and shake it over them to allow most of the liquid to fall down. Take a few clean paper towels and wipe the liquid off your keyboard's keys. To clean between the keys, you can also use cotton swabs with just a little bit of water. If the liquid which you spilled over your keyboard contained a high amount of sugar, such as soda or sugared coffee, you might have to remove some of your keyboard's keys to clean the surface under the keys with paper towels or swabs. You can do so by lifting them gently with a screwdriver or by using a key remover, which you can find in some IT stores. Wait at least 12 hours before using your keyboard again. If your computer is a laptop, wait the same length of time before turning it on again. How to Clean Your Keyboard http://www.tucows.com/article/684 Fix Computer Keyboard Problems http://technologyandinternet.blogspot.com/2007/10/fix-computer-keyboard-problems.html
Apr 20, 2013 | E-Machines eMachines Desktop PC
The t and the y don't work
cleaned them with what?
key don't work on a laptop due to something being spilled on them(liquid) or something underneath them(hair, crumbs etc)
hold the laptop upside down(off of course) and GENTLY tap the edge near the keyboard bottom on table you might find something dropping out
otherwise new keyboard time
May 25, 2012 | MSI CR630228US 156Inch Laptop Black
Keyboard problems
Not working at all? Did you spill liquid on it? Not working is a very broad statement, tell us exactly what is going on with the keyboard. If it's not working then you need another keyboard. If there are certain keys that work and some that don't then that's another issue.
Apr 26, 2012 | Dell Inspiron 1545 Notebook
I spilt alcohol on my laptop and now the keys dont work
replaced ur keypad from the nearest hp service centre.
Apr 25, 2010 | HP CPQ175KB Keyboard
The keys have clogged up and all the keys dont work becouse water has gone iside any solutions
Replacement.
That is the ONLY solution for keyboards that have ANY kind of liquid spilled into them.
I can replace the keyboard and check the inside of the computer for additional damage that may have occurred because of the spill.
Jan 24, 2010 | Dell 0Y3740 Keyboard
Spilled liquid on laptop keyboard
Search for a keyboard on eBay. Should be about $5-15. Type in "(model name) keyboard."
Mar 14, 2009 | Fujitsu LifeBook N6100 Notebook
Computers & Internet Logo
71 people viewed this question
David Payne
David Payne
