Hi Folks, Problems with Dig Camera (Relisys Dimera 2000) & Modem (Rockwell 33.6K Internal) Motherboard is an "Explorer 1V 82430 VX"
I can not get the computer to recognise the camera. Sources advise me I have a conflict between the camera and the modem.
Information I have is the Modem is on Comm 4 (02E8) using IRQ3. I have connected the camera to the 25 pin Comm Port using a 25 to 9 pin adapter. I get the error message that the camera is not responding and to check the cables and power on etc .I have deleted the modem in control panel, modems and then tried to find the camera without success.
Anyone out there got any help with my problem? Thanks in anticipation -- Take Care,
try connecting your camera to the 9pin serial port. Your problem is that your camera is on com 2 and your modem on com4. These ports share the same memory address and IRQ, so when both are in use you will get a conflict. Or set your modem to Com3 IRQ4. as long as you are not using COM1 for anything, as again COM1 and COM3 use the same settings.
One last thing, you could try going into the BIOS and changing the IRQ/Memory settings for the COM ports. These will be in the BIOS as "onboard serial ports"
regards mikw
Was this helpful?
Yes
No
Solution #2
posted on Aug 11, 2005
Ross - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
Hey, My guess is the same as the previous reply...the modem and camera cannot share com1 and com3 or com2 and com4...(whatever)
But...and this might be pretty obvious...did you check the connector going into the camera to make sure it is seated? The only reason I ask is bacause I was hooking up a Dimera 3500 tonite and I could not get the computer to access the camera either. After screwing around with the serial ports, I finally reseated the connetor at the camera and it took off. There was a second click that I could hear when it finally seated. I don't know how the 2000 compares to the 3500, but that was how I solved my problem finally. Later Mike
On Sun, 12 Dec 1999 08:36:07 -0000, "Douglas R Leitch"
Was this helpful?
Yes
No
Solution #3
Luisa_K - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
I have the "mouse" on comm 1, will this cause the same problem?
I have thought of a USB card and mouse to free up comm 1. Any thoughts on that option?
Thanks for taking the time to reply Take care Dougie.
i have a canon camera an it lets me view pix but when i try to take them the screen is black..i...
(More)
i have a canon camera an it lets me view pix but when i try to take them the screen is black..i spent 400 on it can you fix it
Have previously conncected Canon IXUS 850is camera to macBook Pro and downloaded images. Now it...
(More)
Have previously conncected Canon IXUS 850is camera to macBook Pro and downloaded images. Now it won't work. Have installed Canon Software - still not working. Mac won't recognise camera. have tried using
my nikon l10 flashis not working technicians says that hardware is correct software is not switching...
(More)
my nikon l10 flashis not working technicians says that hardware is correct software is not switching the flash please guide me .
i used my ecap webcam one time. and then i started getting on skype and then after that i started to...
(More)
i used my ecap webcam one time. and then i started getting on skype and then after that i started to use my webcam again but everytie i tried to all it said was that my webcam was not going to function properly and to enable my video hardware or something like that so i uninstalled it and i dont know how to get it back.
I have Dimera 2000 cmara which appears to work O.K., but cannot find anything to read the card. The...
(More)
I have Dimera 2000 cmara which appears to work O.K., but cannot find anything to read the card. The camer has beenlittle used and is in as new condition. I have only the cmarea and card but no other attachments or handbook etc.. Solve?
