Question about Dell 1600n All-In-One Laser Printer
Have a Gateway laptop with Windows XP. Want to use Dell 1600n printer
Dell is not listed in my printer/fax add-on list. Not my printer, so no disc for it. How can I add this printer?
    Genius:
  • Dell Master
  • 1,056 Answers
Download the drive from Dell, and run it to unzip it. When adding the printer, click "Have Disk" and point it to the folder that you downloaded the driver to.
Posted on Jul 22, 2008
All functions work on my 1600n printer with the exception of the scanner. The workstation names that normally appear when a doc is scanned do not appear
The Dell 1600n requires that the Dell Network Scan Manager is running. Windows Vista and Windows 7 require user level authorization for this app to run properly and may be prompting you at start up. If you are telling it "no" when propmted then this is one thing that can be hanging you up. It is also possible the app is simply not running at all. Go to start>programs>Dell>Network Scan and see if it picks it up then. This app is how the dell printer itself gets the names to put in the list of available workstations to scan to.
Jul 26, 2011 | Dell 1600n All-In-One Laser Printer
Desktop computer windows xp...sons laptop windows 7 ..wireless router....same internete signal...can his laptop find my printer..or do i need to run same cd on my sons laptop..to get it to install on...
Yes it is possible, you have to install the pritner software on your Sons laptop.
1) For sharing, if you have a network printer connected to your router, then select the network option while installing the printer (If you would have given us the printer model and make we could have given step by step instructions).
2) If the printer is connected to your XP computer and you want to share it, share the printer from XP as mentioned in the steps below.
>> Open Printers and Faxes. Click Start, click Control Panel, click Printers and Other Hardware, and then click Printers and Faxes.
>> Right-click the printer you want to share, and then click Sharing.
>> On the Sharing tab, click Share this printer and then type a share name for the shared printer (e.g. MyPrinter), click on Apply and Ok. (as shown below)
Now goto the Windows 7 laptop and follow the steps as mentioned below,
>> Click Start >> Click on Devices and Printers >> Click on Add Printer (as shown below)
>> A new window will come up, click on Add a network printer (as shown below)
>> The laptop will search the network for the printer and display it on the list, click on the printer and click on next. The laptop will install the software required, do ensure the printer installation disc is in the laptop in case if Windows 7 wont have the driver it will take it from the disc.
Regards,
Shrey
Jun 03, 2011 | Office Equipment & Supplies
How to enable ms fax services
  1. 1
    Open the Start menu and select "Run", then type "appwiz.cpl" into the textbox and press "Enter". This will bring up the "Add/Remove Hardware" dialog box.
  2. 2
    Click the "Add/Remove Windows Components" button in the left portion of the dialog box. It will take several seconds for the list of installed components to compile.
  3. 3
    Click the check box next to the "Fax Services" entry and click "OK". This will start the install process for the Windows XP Fax Service. You will be prompted to insert your Windows XP setup disk at some point in this process. Do so, then press "OK" to continue and complete the installation.
  4. 4
    Click "Finish" to exit the installer program.
Jan 14, 2011 | Dell 924 All-in-One InkJet Printer
Prints faint copies
If the print rubs off the page, this means the toner is not being fused to the page. Fused......this is done by the fuser. This would have nothing to do with light print.
The dell (1600n and 1815n /1815dn) printer drivers has a toner saver mode, which can contribute to light print.
To turn Toner Save Mode off, (Windows XP) perform the following steps:
  1. Click the Start button, click Settings, and then click Printer and Faxes.
    The Printers and Faxes window appears.
  2. Right-click Dell Laser MFP 1600n, 1815dn, and left-click Printing Preferences.
    The Dell Laser MFP 1600n, 1815dn Printing Preferences window appears.
  3. Click the Advanced button.
    The Dell Laser MFP 1600n, 1815dn Advanced Options window appears.
  4. Click to highlight Toner Save.
  5. Click the drop-down list and change it to Off and click OK.
  6. Click OK.
One thing that you mentioned in your post "it takes the printer forever to warm up". The fuser does have to reach operational temperature in order for it to fuse the toner to the page. So it is possible that you are having fuser problems, because of the time it is taking for it to warm up. Another thing that can contribute to the warm up time is not plugging the laser printer directly into a wall outlet. This would be true for any laser printer, not just a Dell laser printer. The low voltage power supply is what works the fuser, along with sensors and other motors in the printer.
Replacing the fuser and or the low voltage power supply in this model of printer is not an easy task. If using a Dell branded toner cartridge and checking the toner saver mode does not fix the issue. Then you would be looking at more expense then the machine would possibly be worth.
May 04, 2009 | Dell 1600n All-In-One Laser Printer
Dell fax machine will not recognize incoming fax call on comcast cable telephone line
Direct from COMCAST FAQ:
Do fax machines work with Comcast Digital Voice service? Yes. However, there may be some equipment brands or models that are incompatible with Comcast Digital Voice® service. Click here to review a list of equipment that has been known to have compatibility issues with Comcast Digital Voice service.
Jan 15, 2009 | Dell 1600n All-In-One Laser Printer
Dell 1600n only receives 1 page of fax.
turn off ECM (error correction).
then if problem persists, slow down the fax speed to 9600 bps.
this problem always occurs with a digital or VOIP line.
Jan 14, 2009 | Dell 1600n All-In-One Laser Printer
Add Printer
The Z22 does not appear on Lexmarks vista compatability list and so there is no specific vista driver.
There is a driver for Windows XP which you could try
http://downloads.lexmark.com/perl/downloads/downloads.cgi?ccs=227:1:0:0:0:0
Select Z22 as printer model and search
then choose windows XP from the list of operating systems
Nov 23, 2008 | Office Equipment & Supplies
Problems installing a printer
what is your operating system? If you have windows XP or Vista, you dont need to download anything from Epson. Just go to your start menu and look for control panel. In control panel, open "printers and faxes" or "printers and other hardware" then "printers and faxes". Once you are in "printers and faxes" click Add Printer...
An "add printer wizard" will appear in a new window, click next...
On the next screen, choose local printer. And make sure that the option "Automatically detect and install..." is selected. It will start searching... If the wizard did not find the printer, it will come up with a list of manufacturers... From this list choose EPSON and a list on the right side will show you the model names. Look for the LX-300 on the list, it should be there! Install it and you're done... The driver is already included in the windows operating system. You dont need the disc if you have Windows Xp or Vista....
Jun 27, 2008 | Epson LX-300 Matrix Printer
New printer instalation
Go to Start/Printers and Faxes/Add a printer.
Wheh this starts it will look for a P'n'P printer it may find it and the job is done
If it aske for disk or select from list - choose select from list
Select HP then the model.
It seems as if the supplied disc in these cases is defective and is worth taking up with HP
Dec 16, 2007 | HP LaserJet 1018 Printer
Windows Vista can't find networkd Dell 1600n
Make sure you're using the drivers for Vista, which can be found on support.dell.com. You'll want to use the choice for Vista 32-bit.
Also, try turning off your firewall, as it may be blocking the network data.
Dec 15, 2007 | Dell 1600n All-In-One Laser Printer
Dell 1600n All-In-One Laser Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
