Question about HP OfficeJet 6210 All-In-One InkJet Printer
When i send a print nothing happens. I opened the lid to check for a jam. nothing. but when i closed it the screen on mu printer says carriage jam.....
I had used the printer the day before with no problems. I turned it off before bed. In the morning I turned it back on and sent a print. The printer did nothing. I went to the printer section in control panel and sent the print again. It had the document I was sending in queue for about 1 second then it disappeared and again the printer did nothing. I did make a copy with it so the copier is working fine. Then I lifted the lid looking for a jam and saw nothing. When I closed the lid the printer beeped and said "carriage jam" and the screen on my cpu said the cartridges cannot move, their is a jam. Also my cpu is saying the printer is "ready" so the connection to the cpu seems to be connected fine. Can someone give me some advice? THANK YOU!!!!!
  • twstephens Jun 19, 2008
    Also the cartriges are moving. When I turn it off they move from side to side like normal.
  • twstephens Jun 21, 2008
    ok, now check this out. when i open the lid to check the cartiges a window opens on my cpu saying "door is open" and it had a link on the left side of the window, "check ink levels". so i click it and it takes me into another window where i can see ink levels. their is a tab for config.... so i go there and it has the option "send test print" i click it and IT SENT THE PRINT, THE PAGE PRINTED PERFECTLY!!! But i closed the window and tried to print the page i was on at the time and it again did nothing. Is this problem in my cpu?
    thanks!!
    Novelist:
    Scholar:
  • 70 Answers
Sounds like the "deadly embrace" problem...
Computer says to itself "waiting on printer status"
Printer says to itself "waiting on computer status"
Results....nothing.
Try this:
1. Shutdown (using the normal operating system shutdown) the computer.
2. Turn off and unplug both the computer AND the printer at the same time.
3. Plug the printer back in first (and if necessary, turn it on) THEN
4. Plug in the computer and allow it to start normally.
Now try a print.
Let me know if this works for you.
Posted on Jun 21, 2008
HP Laserjet Pro 400 m401n repeatedly prints the same .pdf file that was sent from an HP EliteBook 8460p. I have rebooted both printer and laptop, but the issue keeps occurring. As of this morning the...
Is it doing this while your printer is still connected to your 8460p? Disconnect your printer. Power down your printer. Depress and hold the "go" and "select" button while turning it back on. If that doesn't work, uninstall and reinstall the print driver.
Sep 09, 2017 | HP LaserJet Office Equipment & Supplies
Good morning, We have a bizhub C220 that is currently having issues. When a job is sent to the printer it won't automatically print as it states: 'tray cannot be used currently'. I can...
I had a c353, but the same error... I walked into work and someone had left the printer with this error... after looking online and having no results, I just turned it off (the hard power switch), and turned it back on, and it found tray 2 again!
Aug 12, 2011 | Konica Minolta Office Equipment & Supplies
Everytime I start my printer I get a message to realign while there is NO problem with the alignment.
The printer alignment has to be completed as below,
  1. After printer prints the alignment sheet.
  2. Place the printed sheet on the scanner bed and press "start scan" or "start color copy".
  3. Wait untill the printer Power light stops blinking.
  4. Now turn off the printer and turn back on.
  5. Printer will not print alignment sheet.
Regards
Riztech
May 29, 2011 | HP PSC 2175 All-In-One InkJet Printer
Yesterday I printed a page and could not print second page, so i shut everything down, this morning i turned on my computer and the printer started up & started printing & ran till out of paper....
Disconnect the printer power plug from the wall for 2 mins and plug it back in and turn the printer on and turn on your PC and see if that helps. The printer has a memory which stores information you may have sent to the printer. If you kept hitting the print button then it may have saved all those print commands in memory and it is printing that out. That is what happens most of the time at my office. So you need to erase the memory by turning off the printer from the wall. Hope this helps
Aug 14, 2010 | HP Office Equipment & Supplies
Printer has stopped printing .pdf files
Check your list of printers and make sure the default printer is the correct one.
Mar 18, 2017 | HP OfficeJet 6210 All-In-One InkJet...
HP k5400 KY printhead always reports bad on Monday morning
Remove the Printhead and clean the contacts on the back of the printhead and also in the where the printhead mounts.
Try leaving the printer turned on over the weekend as the fault maybe caused by the ink drying out.
Jun 22, 2009 | HP Officejet Pro K5400 All-In-One InkJet...
I have a 1100/1200 series all-in-one hp psc printer. It will print from info sent from computer but will not work as a copier. Does not scan info placed on glass to print.
sounds like your scanner bed is inop. you might need the either to send it in to the manufacturer or take it into a repair shop to have it fixed as this is a hardware problem not a software problem. although it would be cheaper to replace the printer altogether.
If you need further help, reach me via phone at https://www.6ya.com/expert/mark_445a24324be9eb03
Mar 01, 2009 | Office Equipment & Supplies
"Deadly Embrace" problem you answered
Tim...maybe not toast yet.
The slow moving cartridge after "boot up" from a total shutdown is normal. The system forgot everything and has to re-learn stuff like "where is the end of the carriage" believe it or not.
The disappearing print means that the system thinks there is a printer there but there isn't. The printer, on the other hand, is not getting the print either. Kind of like sending a letter to the wrong address. You sent it but it never got there. You didn't get it back so you assumed that it was received but it wasn't.
Let's try this....
1. Check to make sure that the cable between the computer and the printer are mechanically sound. This means: unplug the cable then plug it back in on both ends. (I've seen tiny insects crawl in between one pin...that's where the term "bug" came from) As you do this you may should see Windows (using MS?) acknowledge the plug but not the unplug...(...found new hardware...found printer...)
2. Check the printer "properties". Does it show more than one printer....look for "(2)" in the list.
3. Try disassociating the printer with the LPT1 or PRN port and then reassociating.
4. lots of other stuff...let's try the basics first.
From your description both devices are working fine. Just the communications is hosed up.
Jun 23, 2008 | HP OfficeJet 6210 All-In-One InkJet...
We were sent a fax this morning since then we havn't been able to fax send recieve print or copy model no x502n serial number 5831cnp job number 590057 we have been waiting all day for this problem to be...
Unplug the unit, wait 10 seconds then plug it back in. Do not just turn it off at the switch, physically remove the power cable from the wall.
It sounds like the unit has gone into a hardware lockup. Resetting the power should solve it.
If not please post back with any error messages you get or have had from it today.
Apr 16, 2008 | Office Equipment & Supplies
Unable to cancel a document from printing
I have a lexmark 640 and experienced the same problem today and read similar problems but noone provided a solution. Fortunately I managed to solve the problem by cancelling the job then while it was still in print queue, shut down and restarted the computer.
This worked for me.
Roden
Oct 01, 2007 | Lexmark Z600 InkJet Printer
HP OfficeJet 6210 All-In-One InkJet Printer Logo
631 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
