Question about Hitachi DZ-MV350A DVD Camcorder
Door is stuck
My Hitachi MV350A door is stuck. Daughter put in disc wrong way and now when you try to eject, you just get a ticking kind of response. I will take you out to dinner for the answer.
Thanks
Charlie
    Problem Solver:
  • 5 Answers
I had the same problem with mine. I contacted Hitachi, and the only solution was to send it to the dealer for repair. I live in Las Vegas and the closest dealer is in Carson, California, so I shipped it. It took about 3 weeks and was quite expensive, but it worked after that. Now I am having the "error code 2881" problem when I try to record with a DVD-RW. According to this website, our camcorder does not support that, it only uses DVR-R or DVR Ram. I am off to the store to buy some, and will let you know if it works.
Good luck Charlie.
Lynda
lyndelgado@hotmail.com
Posted on Jun 28, 2008
SOURCE:
How to download from Hitachi DZ-MV350A video camera to my computer that uses windows 7. I tried the enclosed dvd but it does not work on windows 7.
Your best bet is to use the drivers from the CD.
To do this on windows 7, you'll need to use compatibility mode.
Browse to the contents of the cd in windows explorer. Right click on the driver installer file, and select "properties".
Select the "compatibility" tab from the properties window, and select "windows xp sp3" from the drop down menu. Also tick the "run as administrator" on the bottom.
I did this with my own hitachi DZ_MV350A and it worked just fine.
Dec 02, 2012 | Hitachi DZ-MV350A DVD Camcorder
My daughter put a small disc for her music in my mac computer how do i get it out
Five ways to eject a stuck CD or DVD from the optical drive
Ejecting the stuck disc can usually be done in one of the following ways:
1. Restart the computer and after the chime press and hold down the left mouse button until the disc ejects.
2. Press the Eject button on your keyboard.
3. Click on the Eject button in the menubar.
4. Press COMMAND-E.
5. If none of the above work try this: Open the Terminal application in your Utilities folder. At the prompt enter or paste the following:
/usr/bin/drutil eject
If this fails then try this:
Boot the computer into Single-user Mode. At the prompt enter the same command as used above. To restart the computer enter "reboot" at the prompt without quotes.Alternatively follow the following instructions: How do remove stuck Mini CD from the SuperDrive on Macbook Pro
Dec 29, 2010 | Apple iMac OS 9.1
Something stuck inside disc drive
try this, press and hold eject button for around 15 seconds, this resets the cd drive, hope this helps
Jan 10, 2009 | Sony Playstation 3 (PS3) Console
Hitachi DZ-MV380A NTSC won't eject Disc
I have the same problem, I unfortunately cannot fix it.
Jun 28, 2008 | Hitachi DZ-MV380A DVD Camcorder
Help ejecting dvd
I had the same problem and tried for ages (even tried forcing the door open thinking I could just tape it shut) without luck.
Then my very clever wonderful husband had a go (I know i'm crawling and yes my knees hurt).
Any way to the relevant bit. If you hold the eject button down and at the same time slide a knife or similar object round the edge of the door where the screw is near where it says photo/select you'll find that the door opens as this is an override mechanism.
Feb 22, 2008 | Hitachi DZ-GX3200A DVD Camcorder
WII NOT EJECTING DISK
try switching off unplug then start again after a few minutes.
Jan 06, 2008 | Nintendo Wii Console
Hitachi mv350a dvdcan
I figured it out out of frustration. I used a small flat head screwdriver & gently pryed it open just above the control for turning it on/off. Inside I found that the mini-DVD was shoved in there outside of the mini-DVD sleeve thus causing a perpetual jam. Works OK now as long as my kids don't mess with it!
Jan 05, 2008 | Hitachi DZ-MV350A DVD Camcorder
Disc Eject won't work after improperly inserting disc and since removing it.
I have an DZ-MV780 with the same problem. I found that the cover plate around the flash hot shoe only has a single screw. If you remove it and pull up the cover you gain access to the gear and lock mechanism. Hit eject and if necessary press on the white gears you see in front of the zoom switch. It should then cause the door mechanism to unlock and open.
Aug 24, 2006 | Hitachi DZ-MV580A DVD Camcorder
Hitachi DVD camcorder
The door might be stuck. Try "helping" it open manually after pressing the eject button. Otherwise, something is probably broken and you might have to call a repairman.
Apr 09, 2006 | Hitachi DZ-MV580A DVD Camcorder
Hitachi DZ-MV350A DVD Camcorder Logo
372 people viewed this question
Top Hitachi Video Cameras Experts
Damen Wong
Damen Wong
Marvin
Marvin
Jerry Greenberg
Jerry Greenberg
Are you a Hitachi Video Camera Expert? Answer questions, earn points and help others
