My cd-rom drive is not working on my computer. I have gone into properties on my computer and it has a warning sign under the dvd/cd rom drive. How do I fix it?
  • 1 more comment
  • jobsphx Jun 19, 2008
    It will not write or read anything.
    You are a genius bigbiggs! Thank you.
  • francisco de mesa
    francisco de mesa May 11, 2010
    what is the warning sign? when you say it is not working does it mean it doesnt read or write? does it respond if you push the eject button? when you put in a cd does it indicate that it is reading it?
    Sergeant:
    Champion:
  • 326 Answers
Use control panel - add/remove program and uninstall any programs for the DVD player. Next use control panel - system - hardware - devices and uninstall the DVD player. Leave the device connected. Reboot and when system detects the player load only the driver for Ur os. See if this fixes the problem. If still not work, sounds like time to replace. DVD writers do not have but a coupla' hundred writes and the laser burns out. Designed that way.
Posted on Jun 19, 2008
  • Rory Biggs
    Rory Biggs Jun 20, 2008
    Good, glad to b of help.
DVD FUNCTION WON'T WORK, what should i do?
Click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
If this does not fix the problem you might try
you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd drive including electrical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
Nov 11, 2011 | LG CRN 8245B (CRN-8245B) Internal 24x...
My dvd rom not showing in nero programme
you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver roll back driver or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options update driver roll back driver or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer Close all open programs Click Start, Run, and type regedit and press Enter
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
May 24, 2011 | LG GDR-8164B 16x DVD-ROM Drive -...
Can't read dvd's
Click start control panel administrive tools computer management device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Hope this helps
May 22, 2011 | Toshiba SD M1612 Internal DVD Drive
D: drive on my computer does not show up anymore. I boot up the computer and the letter does not appear under Computer. I put in a disk and the machine is connected for power, but I cannot load or write...
click start control panel administrive tools computer management device manager scroll down cd dvd rom drives if you see a yellow question mark? right click you will have options to update driver,roll back driver,or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Hope this helps
May 01, 2011 | LG (GCC4243N) CD-RW/DVD-ROM (Combo) Burner
My samsung dvd writer can't read cd
click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area or if this fails to fix the problem
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Apr 23, 2011 | Samsung SH-S223C 22X DVD Writer SATA Black...
Hi there, i purchased a second laptop for my kids to play with, the computer is running window xp. when i placed a cd or dvd into the computer the computer doesnt detect it. nothing happens.
Try the following steps:
right click on my computer, select properties
click hardware tab, then click device manager
in the device manager, click + sign next to cd-dvd rom devices.
you will see cd-dvd driver listed here.
right click on it and select un-install
driver will be gone
now open the following website and run fixit software
http://support.microsoft.com/kb/929461
it works for XP as well. if you are comfortable, you can delete upper and/or lowerfilters manually from registry editor. i hope it will work
Apr 19, 2011 | Compaq Presario 2100 and 2500 ,NX 9000...
DVD/CD-ROM > Does not
your drivers may have been corrupted or you might have a virus run your antivrus program
make sure that the cd-dvd is getting enough power test all leads that are attached to the cd/dvd including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps don
Mar 12, 2011 | Sony CRX320EE CD-RW/DVD-ROM Combo Drive
Mysystem drive working dvd play but not working cd
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
(you will only need to do this if you cant see the drive in my computer/windows explorer))
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Jan 22, 2011 | LG Computers & Internet
Cd-rom
Check it from Device manager;
Right Click my computer. Go to properties.Hardware tab; Device manager; See under device manager ! any yello sign; ETC;
If you could not find any alternate Best Solution is try replacing CD DVD Rom
Regards
Rafique
Mar 17, 2008 | HP (PR017UA) PC Notebook
CD rom drive not working
sounds like it's gone home early. replacement will do the trick..
Mar 06, 2008 | Compaq Deskpro EP PIII-650MHz/ 128MB/...
Computers & Internet Logo
67 people viewed this question
David Payne
David Payne
