Question about Hitachi RAS-09UH Air Conditioner
Hitachi Soleus split Not blowing cool air.
Have a Hitachi Soleus split unit KFR-18GW(D). Not cooling. Called in a licensed master plumber. He put freon in. Pressure set at 40. Didn't work. He jumped wired to test compressor. Compressor would not kick in so he replaced compressor with a new one from manufact. After replacing it the sensor lite blinked 4 times and according to manual, this means compressor is not working. Shut down unit from electrical box because there isn't a manual shut off on unit only on remote. Still won't work. Plumber has been here 5 times since unit went on fritz. Heat valve not clicking in. Need to know if there is any help for us or should the unit be junked (Only 3rd summer unit has been used). a.petino@comcast.net
    Habit-Forming:
  • 109 Answers
If the freon is 410a the pressure must be 100-120psi,if it is 22 the pressure must be 45-55psi.you unlucky because hitachi havent problems with compressors.is it inverter the unit?if it is you must check the outdoor pc board,if the 4valve clicking in the you must replaced it propably has stucked.
Posted on Jul 09, 2009
2 Suggested Answers
  • 449 Answers
SOURCE: my Soleus KFR-18GW Split
Check your thermostsat see if there is a fan switch on it set it to auto
Posted on Aug 19, 2010
How do i get my soleus air conding unit to blow cold air, its blowing cool air. can i recharge this unit myself -if so then what type of freon would i use.
most likely have to install a line tap valve to charge. look for oil residue on lines to indicate leak. the evaporator is the weak point on most a/c systems.
Jul 05, 2014 | Soleus KY-25U Air Conditioner
My unit turns on and blows for a minute, then stops blowing.
you need to call a service man. Your transformer, blower motor or wiring is probably melting.
Aug 11, 2009 | Soleus KFR-18GW Split System Air...
My mini split only sometimes responds to the remote
indoor pcb in the indoor unit faulty and the responder.
Jun 09, 2009 | Soleus KFR-18GW Split System Air...
I have purchased 1.5 split air-conditioner of Electrolux model 18SCRDA1 from NEXT and got it installed. Till now it is working fine. suddnly we observed abnormal noise from the outdoor unit.Condenser fan...
hi there.dont touch the untit.its under warranty and if you touch the unit and try to repair it.the warranty will be non existant.im one of the serivc agent for eletrolux.
Jun 08, 2009 | Soleus KFR-18GW Split System Air...
Soleus KFR-18 Air Conditioner Problem
Check your thermostat settings at heat mode.
Jan 03, 2008 | Soleus KFR-18 Air Conditioner
Replacing squirrel cage blower
You have to take blower out by removing the 2 screws that is holding it ,then you loose the motor shaft from wheel by using a Allen key .Once motor shaft is loose you then loosen motor frame from housing and slide motor out .Might have to spray it with wd 40 .
On the housing should be some screws along the side so you loosen those and house ing would open up so you can get wheel out.
To install you reverse the process.
Please note the direction of the old wheel because if install backwards will not work right
Feb 14, 2018 | Soleus Mini Split 12000 BTU A/C Air...
Hitachi RAS-09UH Air Conditioner Logo
418 people viewed this question
Top Hitachi Heating & Cooling Experts
D. E. Hev
rugby prop
Are you a Hitachi Heating and Cooling Expert? Answer questions, earn points and help others
