Question about Apple iPod MA446LL/A MP3 Player
IPod White - 2005, 30GB, A1136A, Generation 5th
When connected to the computer nothing happens. I metered the battery at 2.8 VAC. I understand that the voltage should read 3.7VDC.
I left the iPod connected to the computer for over one hour. Then I noticed a rainbow effect across the LCD screen so I unplugged it.
I have checked my 2006, 5th Generation with the same USB plug and it works.
What do you think could be the issue with the 2005, 30 GB, 5th Gen iPod?
  • Tim Babcock
    Tim Babcock May 11, 2010
    Is there any heat comming from the IPod?
  • Anonymous Mar 25, 2014
    Was able to do transfers before 8.1update
Bubbabear64 there is no heat associated with the rainbow affect of the LCD screen.
Posted on Jun 19, 2008
No there is no heat associated with this rainbow affect.
Why is my 5th generation ipod have a white screen and there isn't anything else?
Here is a link to the Apple iPod troubleshooting site iPod Troubleshooting Assistants
If that doesn't help. the main Apple iPod support site is iPod Apple Support
Dec 11, 2014 | Apple iPod nano 5th Generation
Mi ipod nano 5th generation bacame blanck all white the screen and does not connect to the itunes or does not resset
Welcome to Fixya
Looks like the software just hanged-up on you. Try to reset the Ipod by following the procedures below.
1st option:
Turn the Hold switch on, then back to off.
Press and hold the Menu and Select buttons for 10 seconds (until the Apple logo appears).
You may need to repeat the reset several times.
If the reset doesn't help, then put the iPod into forced disk mode.
2nd option (Disk Mode):
Plug the iPod into a high-powered USB port, let it sit for 2 hours, then disconnect it. If you have a wall charger, plug in the iPod, then follow these steps while it is still plugged in.
Press and hold the Menu and Select buttons until the Apple logo appears
Immediately switch your figures to press and hold the Select and the Play/Pause buttons until "Disk Mode" appears at the top.
For a lot of people, this solves the problem. Connect the iPod to the computer and (assuming it shows up) reset the iPod again to get it out of Disk Mode. If at this point you still have the white screen, restore the iPod using the restore function in iTunes under the Summary tab (this will erase everything on the iPod and put it at factory settings).
Note: Do not disconnect or eject the iPod until the store is totally done. After you think it's done, wait another five minutes.
Feb 17, 2011 | Apple iPod nano 5th Generation
My Computer and iTunes does not recognize my iPod
sorry unless you can get it to set to factory settings then your stuck id take it to a shop or trie some one ells computer if this fails then it a fixit job
Nov 26, 2008 | Apple iPod nano 3rd Generation
Ipod 5th generation white
Try connecting the iPod to your PC. Sometimes this will reset your "hung" screen.
You may have tried this already but:
1. Switch the hold button on, then off.
2. Place the iPod on a flat surface (to make this process easier.
3. Press and hold the center button and the "Pause/Play" button at the same time until the Apple Logo is displayed.
If this doesn't work, try calling Apple or visiting the support section on the Apple website.
http://www.apple.com/support/ipodclassic/ (iPod Support)
http://support.apple.com/kb/HT1435 (Battery Screen Information)
I hope these links help, and good luck!
Jul 31, 2008 | Apple iPod MA446LL/A MP3 Player
Wont charge new battery
maybe your new battery is messed up
Apr 07, 2008 | Apple iPod nano 3rd Generation
I-Pod wheel broken?
To reset an iPod with a Click Wheel, including: ipodnano3.jpg ipodclassic.jpg icon_ipod_5g.gif ipodnano2.jpg ipodnano.jpg ipodphoto.gif ipodg4.gif ipodmini.gif
  • iPod nano (3rd generation)
  • iPod classic
  • iPod (5th generation)
  • iPod nano (2nd generation)
  • iPod nano
  • iPod with color display (iPod photo)
  • iPod (Click Wheel)
  • iPod mini
  • iPod mini (2nd generation)
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
Dec 06, 2007 | Apple iPod MA446LL/A MP3 Player
Apple iPod MA446LL/A MP3 Player Logo
170 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
