Question about Whirlpool GD5SHAX Side by Side Refrigerator
Ice maker I changed the filter and now my ice maker isn't making any ice.
  • Anonymous Jun 25, 2008
    Same problem here very very weird?????????.
You too this is wierd? I just change my filter and Ice stopped. I called whirlpool to just to get zero help!
Posted on Jun 25, 2008
Ice maker no longer making ice after changing filter,GE Eterna ESS25LG refrigerator
recheck filter install is water valve on and is ice maker itself on
Jul 24, 2016 | Refrigerators
Ice machine making cloudy ice
ice maker may need cleaning, filter and/or scale collector changed. IF there is no water fiter you should add one.
Jan 23, 2013 | Ice-O-Matic ICEU220HA Undercounter Ice...
Ice maker not working
pour water in your ice maker. when it dumps ice cubes, keep filling it up again.after 5 or 6 times it should start working on its own
Oct 21, 2012 | Frigidaire Refrigerators
Water dispenser isnt working. Water is slowed to a trickle and ice maker isn't getting enough water to make cubes. We have checked the line from the wall for clogs and it is clear.
Is there a water filter in the unit and if so, when was the last time you changed it? If there is a water filter and the flow of water to the dispenser and icemaker could be impeded by a filter full of "stuff".
Oct 11, 2011 | Maytag MSD2756GES Side by Side...
I have replaced my ice maker filter. Now when the ice maker comes on or we press tab for water, the box where the filter cartridge pushes in leaks water through 2 holes in top of refrigerator side.
either the filter isn't in correctly or when you changed it out you broke the filter holder.take out the filter and try reinstalling it,also look at the filter to see if it's damaged or try putting the old filter back in,if it leaks with both filters then i'd have to say the filter holder is broke,if it only leaks with the new filter then you could have a defective filter.try reinstalling it.good luck.
Sep 05, 2011 | Refrigerators
Water thru the door does not work
First, is your ice maker making ice normally? If it is then you have water. If it isn't then it might be time to replace the water filter! If the ice maker IS working then it has to be either the dual water valve solenoid or the switch.
Jun 16, 2011 | GE Refrigerators
My model is 596-50699001 and the problem is does't do ice, and change a filter what can I do to fix it ? Thankyou for helpingg me
There three problem that will not make your ice maker to make ice.
If the water’s route is blocked or the solenoid doesn’t work
If the bail wire is lifted—the ice maker won’t make ice.
Your home’s water pressure must be strong enough to serve an ice maker.
For your ice maker to maker ice,
be sure the bail wire above the ice tray is in the down position.
If the ice maker doesn’t make ice but you can see the arm swing into motion and you hear a buzz for about 10 seconds after it is finished, the water valve is asking for water that isn’t arriving. This means the valve and the solenoid are probably okay, but the water supply is not. Be sure the water supply line isn’t kinked behind or beneath the refrigerator (1/4-inch copper tubing is much better than plastic fill line).
Also,check to see if something has caused ice to back up around the mechanism—this can cause the fill tube to freeze, blocking the mechanism. When ice cubes are small and seem to be getting smaller, it generally indicates a frozen fill tube.
Check the water line that enters the back of the freezer for a blockage. Find the water shut-off valve behind the refrigerator or under the sink, turn it off, unscrew the copper line from the back of the refrigerator, put the copper line in a bucket, turn on the valve, and see if pressurized water pours out.
The water line attaches to a solenoid at the back of the refrigerator and then travels to the ice maker. The solenoid may be defective or may not be receiving power. You can try removing the sediment screen inside the solenoid and flushing it with water to clean it, and at the same time you can inspect any seals or diaphragms to ensure that they are sound. Unplug the refrigerator first.
Check the tap valve; a bad tap valve may cause the problem where the ice maker supply tube connects to the water pipe. If necessary, replace the inlet valve and the tap valve. For the tap valve, use the type that requires you to drill a 1/4-inch hole (as opposed to the “self-piercing” type). You can do this yourself, or call a repair person or plumber to install an inline water filter when replacing the valve.
Thanks for contacting Fixya.
Jul 26, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker not making ice
Make sure that the filter is the right one and that it is pushed in all the way. The most likely cause is the water solenoid behind the fridge. Take an ohm meter and test across the two terminals and it should NOT ohm out (beep). If it does not ohm out I would replace the P.C. Board kit, emitter & receiver icemaker control.
Dec 27, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Changed filter, red light flashes, not making ice at all
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
kjkjl
Aug 08, 2008 | U-Line Refrigerator Ice Maker
Ice Maker Problem Question
take the ice bin out look in the hole at the ice maker you may have a ice cube stuck between the tines of the ice maker if not look at tines somtimes they get crossed up if not that feel in the ice maker does it have water or ice in the maker? also there is a on off switch on the side of the ice maker make sure it is on, you will also see the white ice level arm you can move it up and down it is about 8 in long make sure it is free to move
May 22, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
Whirlpool GD5SHAX Side by Side Refrigerator Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
