Question about D-Link / RangeBooster N 650 / DIR-635 / 300Mbps / 802.11n / 4-Port / Cable/DSL Wireless Router (DIR635)
Problem with the wireless d link DIR- 635
My router is fed through a modem. My problem is I am connecting the home computer thru the router. My laptop is wireless and is not working. But my home computer is working fine. I tried many times to fix it but it didnt work.
  • 1 more comment
  • skl36490 Jun 26, 2008
    Thanks Blak1ce, for your help.
    I did wath you told me but it didnt work, Thanks agin, and I appreciate your help.
  • belalugosi Nov 01, 2008
    It's a DIR-635
    and i can always see the router wireless but not the outside world. Only after some time It is letting in and out some information on wan...
  • Anonymous Jan 08, 2009
    I have exactly the same problem, after installing Firmware 2.21EU (previously I had 2.20EU and everything was fine). I have tried different changes in config of router, but the WAN IP connectivity comes and goes (with no problem in the WiFi Connection, as the router can "see" my laptop and signal is excellent).
    I am going to install previous firmwares after a hard reset of the router, and check the results, but I am waiting for dlink to send me that firmweare (it is unavailable in the whole internet!!!)
    Problem Solver:
  • 10 Answers
I'd try doing a power cycle. Power off all the equipment. Plug in the Modem untill the online light is solid, then plug in the router, then i'd turn on your laptop.
Ensure that your connecting to the right network. Under the network settings the SSID is your Network name. Make sure it's not a generic name.
If you have a cable provider, you can just bring it to Geek Squad. They'll setup the router and setup all the security features in the store within about 10-15minutes.
Posted on Jun 19, 2008
Computer says that the pin number is incorrect, please use no. on modem. modem nuber keeps coming up incorrect
You should refer to your wireless router setup manual for pin number....
you can also prefer this link to search modem pin no-http://www.dlink.com/uk/en/home-solutions/connect/routers/dir-615-wireless-n-300-router
Sep 03, 2012 | D-Link DIR-615 Wireless Router
Cant connect to d-link DIR-615 wirelessly, can someone help me?
What is the operating system on your laptop?
Can you access the Internet if you connect the computer to the router with the Ethernet cable?
If the wired connection is working then it must be the problem with the wireless network.
If the wired connection is also not working then you may need to reset and reconfigure the router.
If only wireless is not working then you can try creating a new wireless network and then connect your laptop to the new wireless netwok.
I can suggest you a website which may help you for Home network connection.
May 20, 2012 | D-Link DIR-615 Wireless Router
D-link DIR 635. Upload speed is sometimes very low
No it is NOT, most probably a spooling problem, or may need more RAM. some jobs depending on size and type can take a long time to spool, and print, try setting print quality lower too this helps.
Mar 19, 2010 | D-Link (DI-784) Wireless Router
The problem is that after one year, the wireless connection does not work. My laptop finds the network, but it does not receive anything.
Try to reboot everything and make sure that cables are properly intact from the modem to the WAN or Internet port on the router
Mar 18, 2010 | D-Link / RangeBooster N 650 / DIR-635 /...
How can i change the password of my D-link DIR-635 router
To change any settings on the router, you will need to access the router set up.
Do you have any computer connected to the router with the cable?
If not then you will need connect the computer to the router.
open the setup page and change the settings.
Click Here for step by step instruction
Dec 05, 2009 | D-Link / RangeBooster N 650 / DIR-635 /...
Trying to setup router without cd drive or start menu
Open your web browser. In the address bar type 192.168.0.1 and hit enter. You should be presented with the router's web interface. Your username is admin and the password should be left blank.
May 14, 2009 | D-Link / RangeBooster N 650 / DIR-635 /...
D-link WBR-1310
The software that was installed for the router should have detailed step by step instructions to get the pc online. If you have followed all the steps try below.
Check and see that the modem is enabled for the computer. There is also a place to troubleshoot the modem connection there.
  1. Double-click Modems, right-click your modem, and then click Properties.
  2. In Device usage, select Use this device (enable) from the drop down list, and then click OK.
note.gif Note
  • To open Device Manager, click Start, click Control Panel, click Performance and Maintenance, and then click System. In the System Properties dialog box, click the Hardware tab, and then click Device Manager.
    In that list you will see modems, click the box for the drop down and right click the correct choice (if more that one) then click properties and make sure the device is enabled.
Apr 26, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Router seems to drop connection frequently
What a static ip is, is the ip address that the router automatically assigns to other equipment. (computers, xbox, ect.) Find D-links customer support line for help.
Apr 11, 2008 | D-Link DIR-625 (790069292637) Wireless...
D-Link DIR-635 - wireless not working
Hello GEMD,
There may be different reasons why your wireless network is not working properly, let me ask you few questions in order to narrow down the problem.
  1. Is your D-Link DIR-635 brand new therefore we are talking about a new installation?
  2. Are you able to connect via wireless your two laptops in other locations?
  3. Could it be that the wireless has not been enabled yet in your router settings? To check this you will have to log on to your router by typing 192.168.0.1 in the address bar of Internet Explorer then select Admin as Username and leave the password field blank. Go to the Wireless Settings and Setup tab in order to enable  the "radio" signal.
  4. Could it be that an SSID has not been assigned yet to your wireless network?
You can download the complete product manual from the following page.
http://www.dlink.com/products/?pid=487
Regards,
GiBi
Oct 19, 2007 | D-Link / RangeBooster N 650 / DIR-635 /...
Hi, I am assuming that you can connect to your router's web based interface (192.168.0.1). On a PC LAN wired to the router, open a browser; Type "192.168.0.1"; Log-in username/admin and password/(blank); Go to Tools > Misc and the option to select the WAN speed (bottom); Lock the speed down on the WAN port of your router to 10Mbps (Some versions do not have this feature). Hope this works for you. If not pls post back with your modem brand/model. You may also want to log the IP settings (IP Add, Subnet Mask, Default Gateway, DNS Servers) of the PC that is directly connected to the modem when you can access the Internet when not using the router. Good luck and kind regards.
Oct 02, 2007 | D-Link / RangeBooster N 650 / DIR-635 /...
Computers & Internet Logo
477 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
