Question about OKI C5100n Laser Printer
Oki C5150 Not Communicating with Computer
* I have a C5150n at my work that use to work just fine through a P2P network. It was plugged into Computer 1 and I was always able to print from Computer 2. Now computer 1 doesn't exists, so I plugged this printer straight into my computer and it doesn't work!
* From my Printers and Faxes folder, I deleted the old drive that had Computer 1 because I thought this would cause a problem since Computer 1 doesn't exist any more. After this I installed the printer's drive to start fresh. But it ain't working.
* I did the whole troubleshooting steps from windows. The cables work fine, the computer is online, it has ink and the driver has been installed twice! (I wanted to make sure I was doing it right)
* The printer is showing in my Printers and Faxes folder, and the only thing I can think is that I'm not selecting the right USB port...? I mean, that the physical port where it is plugged doesn't match to the port clicked on at the printer's properties...
* When I was following the troubleshooting steps, I found out that the printer wouldn't print even if I go to Command Prompt and type the "copy con lpt1" or the "ECHO HELLO 'ctrl + l' dir> lpt1" But again, I don't even know if that's the port where I actually have the computer plugged to.
* I also tried plugging the cable to a different USB port, but same thing.
Need help!
  • OKI Master
  • 2,794 Answers
Lpt1 usually only works for parrallel printers unless a USB port has been mapped as lpt1.
Is this being installed on a Windows Vista computer?
Posted on Jun 19, 2008
Am getting error 356: Belt Life - Is there a way to replace that yourself?
I suspect this is the transfer belt that needs to be replaced. I've seen the error as 355 not 356 but that could be depend on when in the life-cycle of the belt you see the error. You can replace this yourself. The entire list of steps is given here for the C5150n: http://my.okidata.com/man-c5150-c5200.nsf/MOCContents/380C6DEE82CF117285256CC50063D2D3?OpenDocument . (The entire manual is here: http://my.okidata.com/man-c5150-c5200.nsf/InsideUsersManual?OpenFrameSet .)
The transfer belt, part 42158711, costs ~$210 from this vendor: http://www.fastprinters.com/ProductDetails.asp?product_id=OKI-42158711 . It's probably close to $250 from OKI. Staples has it for $270; Amazon.com lists one for $166.
To replace the transfer belt, you have to take out the image drums and put them in black plastic bags (if you take more than 5 minutes to replace the belt). Remember their order. Then locate the blue locks on each side of the belt unit and rotate them about 45 degrees to unlock them. Lift out the belt unit using the handle at the front. Unpack the new belt and hold it with the handle to the front of the printer. Catch the gear at the back with the drive gear on the belt unit. Lock the blue locks and then reinstall the image drums.
I hope this helps.
(If the problem is the motor belt, that's a different issue.)
Feb 04, 2013 | OKI C5150n Led Printer
The oki c5150,keeps burning my transfer paper.
Are you sure the media you are using is certified for Laser Printers? Ink jet papers will not tolerate the heat generated by a laser printer. You can also check the paper type settings as most printers will print cooler and slower/faster depending on how you have the media type settings set.
Apr 22, 2011 | OKI C5150n Led Printer
Printer COki5150n....
I had the same problem. I came across the 160 error after I moved drums around. My issue started with error code 161. which appears to be the Magenta drum. Moving it to other color locations gave me errors 160, 162, 163. 160, I assume, is the cyan cartridge, then 161 is the magenta, 162 is the yellow, and 163 is the black. In my case, the magenta was very dirty. I pulled it out, used an eraser from a #2 pencil to clean the contacts. Used the shopvac to clean toner power out of printer. Turned it back on and it worked.
Apr 10, 2010 | OKI C5150n Led Printer
C5150: All color prints are extremely streaky and
This happened to me. It was caused by a bad "oki compatable" color cartridge. One time it ruined my drum. It was always the yellow color. Decide which cartridge is printing streaky. Remove it, bang it on the inside of a large plastic garbage can. Clean it. Reinstall it . If it still prints streaky throw it befor you ruin the drum. Replace it.
Nov 07, 2009 | OKI C5150n Led Printer
Toner sensor problem k toner 543
Try reseating the toner cartridge, it might not be in good. Reseat the whole drum unit (the part the toner fits into).
May 03, 2009 | OKI C5150n Led Printer
Okidata C5150 Servicing
I just changed all my color cartridges but the color printing does not show the right color. Is there a way to calibrate the colors or check how each cartridge is working or not?
Aug 21, 2008 | OKI C5150n Led Printer
Printing darker
charging connections are not properly connected
Sep 06, 2007 | OKI C5150n Led Printer
Driver problems
Sounds like it is recognising it but not properly installing it. Do you have any old printer settings on pc, if so delete to avoid conflict. Is there a chance that that your printer needs a higher OS many people forget to check this. Is it responding in any way at all and any error messgaes?
Aug 17, 2007 | OKI C5150n Led Printer
OKI C5100n Laser Printer Logo
150 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
