Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Side by side Kenmore fridge
The partition area between the freezer and the refrigeration area gets extremely hot. Any ideas?
  • brogan17 Jul 04, 2008
    Where is the energy saver switch?
  • 828 Answers
These areas are where the thermal break is made between the inside and outside temperatures to prevent humidity from condensing on the surfaces. They are called mullion heaters. If you have an energy saver switch turn it on and it will reduce the heating effect. If the temperatures on the inside of the refrigerator and freezer are elevated this will be noticed more so.
Posted on Jun 20, 2008
Why does it get very hot around the door's perimeter?
The door is heated so it doesn't stick shut with ice. It may be that the condenser is clogged or the fan isn't running, causing excessive heat in the strip. Clean the condenser thoroughly and check the fan.
Jul 01, 2012 | Kenmore Elite Side By Side Refrigerator -...
Kenmore elite model#5059903 the divider between the freezer and fridge gets extremely hot.
Refridgerators have coils than run thru then body of the fridge. They are there to reduce moisture and condensation. It is normal for tham to get warm and sometimes they do get hot it happens when the coil is too close to the body. Normally it only happens periodically. If it is so hot it burns or if it stays hot and dont stop than you have two options. #1 move contents of fridge to another location (back up fridge) and unplug for 24 hrs leave doors slightly open and have some towels near bottom there will be a little bit of water. Plug back in if this does not work. Contact the manufacturer and let them know. There may be a defect in the design.
Jun 05, 2011 | Kenmore Side by Side Refrigerator
The divider between the side by side frigerator/freezer where the door closes and seals is extremely hot- too hot to touch. Is something wrong with my refrigerator
The divider between the side by side frigerator/freezer where the door closes and seals is extremely hot- too hot to touch. Is something wrong with my refrigerator, should i unplug it?
Aug 25, 2009 | Kenmore 53642 / 53644 Side by Side...
Center front partition is very hot!
Either your coils are dirty ( clean from the front after removing the kickplate , only what you can get to ) or , the condensor fan motor is bad ( motor which cools the compressor ) .
Jul 07, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Panel between fridge and freezer very hot and no sound at all
Hi: Its just a coincidence you noticed it then. It is usually hot. It's the reverse side of the refrigerant (the hot side.) If you lived in a humid area the fridge would sweat. Water would run down between the doors. I live in a dry climate so no worries. Older fridges used an electric heating element to keep them dry. They also had an energy saver switch to turn it off. As Whirlpool uses the hot side of the refrigerant they don't use additional power to run the heater. Actually the heater is called a mullion heater. Nothing is wrong with your fridge. I'll look over my shoulder for angry retailers. Hope this helps, Jeff.
May 30, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Hot to touch
there is another fan at the bottom, rear, of the refigerator. remove the bootom panel and look at the cooling fins to make sure they are not bent into the fan blades. Caefully bend the fins away from the fan. this should improve the cooling of the refrigerator and get rid of the hot spot on the rail between the refrigerator and freezer.
Apr 26, 2009 | Kenmore 53542 / 53544 Side by Side...
Kenmore 5126101 middle separator b/t fridge/freezer extremely hot
There are 2 or 3 things that would cause this. first make sure the condenser coils are not plugged with dust (vacumn or blow them out) next check to make sure the fan that cools these coils is running, (this is the most likely problem). if both of these check out ok then you would need to check to make sure your interior lights ar going off when the doors are closed as these will add extra heat and cause the center rails to run hot. last and most uncommon would be a freon system problem.
fyi there is a hot gas freon line that runs in between the doors to prevent exterior sweating. when poor or no air flow problems for the condenser coil exist it causes this area to become hotter.
One more thing. if you do determine that the condenser fan motor is bad you can put a normal house fan blowing on to the coil to help cool this area down until you can get the unit repaired.
If you need any further assistance leave me a comment here and I'll gladly get back to you. Thanks Peyton
Mar 11, 2009 | Refrigerators
Kenmore elite side by side: hot divider
This is normal. There is a heater in this panel to stop condensation sweating between the doors.
Feb 23, 2009 | Kenmore Refrigerators
Kenmore fridge not getting cold
first thing to heck would be the condenser fan motor which is located int the compressor compartment pull the refrig away form the wall remove cardboard cover and inspect the fan motor that you will see. check for obstruction or if the fan motor is seized. if this motor fails it will cause the compressor to run extremely hot then shut off on internal motor protector. if you determine the motor is bad you can place a house fan behind unit blowing on compressor area to keep unit working until you get it repaired.
Thanks Peyton
Feb 17, 2009 | Kenmore 64522 Top Freezer Refrigerator
Kenmore ice maker
If the ice ejector (the plastic part) is pointed down and not pointed between 10 and 3 o' clock the ice maker motor has failed or somethin is binding. Replacing the ice maker is probably the best bet.
Aug 14, 2007 | Kenmore 57029 Side by Side Refrigerator
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
126 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
