Question about AEG B1180-4 Electric Single Oven
My oven turns off on me after only a minute never heating up fully
I turn on my oven to any temperature and it heats up for a quick minute and then shuts off completely... what is the problem? oven heats up fans runs for ten mins or so then fan shuts of and light goes out
  • Anonymous Oct 17, 2008
    Oven heats up, fan spins, then it turns itself off after reaching 100 deg+. There is extra heat on the control panel at the top....
Could be caused by either of following;
1. Faulty thermostat.
2. Faulty thermal cut out switch. (controls power to cooling fan).
3. Faulty cooling fan (not fan inside oven).
Test thermostat by setting thermostat to low temperature like 60 oC. If oven gets much hotter then its a faulty thermostat.
To test cooling fan and thermal switch take oven out and remove top or rear panels to expose components.
When oven gets hot the cooling fan should turn on. If it doesn't then check to see if there is a mains voltage present.
If mains current exist but fan is not turning then replace fan. If mains voltage is not present then its the thermal switch.
Posted on Sep 17, 2009
    New Friend:
  • 18 Answers
The control setting is not working properly, so when you turn it On- it automatically switched to the high temperature. Since any heating appliances has thermal fuse on its motor, it will automatically shuts off after reaching the maximum heat.
you need to repair or replaced the control panel/ settings.
Posted on Mar 09, 2009
SOURCE:
I have a New World Double oven, dual fuel range cooker - NW 90DFD0 The main oven isn't heating up.
Hello Ally;
My name is Peter. I am a retired field service appliance technician.
You may not have a problem. Normally your oven will rise about 40 degrees F. above the set temperature and then shut down, until the oven temperature falls 40 degrees F. below the set temperature, then the oven turns back on.
Your oven temperature is controlled by you oven thermocouple.
You also have a high temperature limit switch, which turns the fan on when you go too far above the set temperature to vent the oven. This may be bad.
Mar 10, 2016 | Ovens
Oven temperature will not cycle
How To Fix Oven With Little or No Heat When Baking ...
www.partselect.com/Repair/Range-Stove-Oven/No-Heat-When-Baking/
Repairing a range, oven, or stove can seem like a big task, but our ... Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake... If the bake element isn't working, the oven may not reach the set temperature or ...If the element appears to look normal, then turn the oven on to a bake ...
Electric Stove Repair ' Electric Oven Repair Manual ...
www.appliancerepair.net/oven-repair-4.html
Inside the oven, the heating element is called a "bake" or "broil" element. ... To maintain a set temperature in an electric cooktop, the element is cycled on ... Do not put any cleaning agents or solvents directly on heater elements or surface units. ... A switch will show no continuity when off and good continuity when turned on.
Electric Oven Will Not Heat ' RemoveandReplace.com
removeandreplace.com/2015/.../oven-not-heating-how-to-fix-range-repa...
Aug 24, 2015 - The issue is most likely a bad internal fuse, oven temp sensor, ... oven replacement parts ... Bake and Broil Element Test - Electric Oven Repair ... Dryer Spins But No Heat - How To Troubleshoot Dryer is turning the drum but ... If your dishwasher is completing the wash cycle but will not dry your dishes, we ...
Oven Temperature Not Accurate - Repair Parts ...
Jan 28, 2016 | Frigidaire Ovens
Maytag electric wall oven model #CWE4800ACB
Try shutting off the breaker and turning it back on after a few minutes.
Sep 05, 2014 | Ovens
Delonghi Oven temperature problems - ESF 461
Certainly not working right with those readings. I would replace it
Sep 20, 2017 | DeLonghi Ovens
I selected "proof" and turned the oven on this
F33 ( upper oven over temperature while cooking ) Check sensor should read 1080 ohms at room temp.
You will need to replace the oven temperature sensor. There is no quick fix for this problem to get you up and running on this Thanksgiving day, sorry. Where are you located and I will see what resources are close to you so you can make the repair?
Nov 24, 2011 | Thermador C301U Electric Single Oven
I dont no how to pre heat the oven
To pre-heat an oven is to simply turn it on to the desired temperature and wait 5 to 10 minutes. If you have a timer then set the timer for the desired time you want to pre-heat then begin baking as usual.
There is no magic to pre-heating an oven and everyone that bakes has a different opinion.
Sep 23, 2010 | Ovens
We have a GE JKP15 oven that will not heat to temperature (350F) when first turned on. The oven will beep (temp confirmation) and the display will indicate 350F but the oven temp will only be at 220F...
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Dec 26, 2009 | GE JKP15 Electric Single Oven
AEG B1180-4 Electric Single Oven Logo
3,873 people viewed this question
Top AEG Ovens Experts
Steve Allison
Steve Allison
Sal De
Jason Harris
Jason Harris
Are you an AEG Oven Expert? Answer questions, earn points and help others
