Question about RIM BlackBerry Pearl 8100
Can't get the battery cover of the Braun Thermoscan Plus
  • shopper22 Oct 25, 2008
    Yes - last thing you need when you need a thermometer.  How does it open?  Does it open?
  • jdenhart Nov 05, 2008
    That battery cover will NOT come off!
    Help!
I just figured it out.
Holding the device so that the ear piece part is pointing towards you, locate a little raised arrow on the top of the device, just below the battery cover.
The arrow points to a little hole, which you need to push something sharp like a pen point into. This should release the cover, which you can now slide off.
Mine did not release so easily, so I also used a flathead screwdriver (a pretty small one, only about a 1/3 inch wide) to drive in between the body and the battery cover, twisting it off as I pushed a pen into the little hole.
Should work fine. Now you just need to get those weird lithium batteries it uses!
Good luck.
Posted on Nov 05, 2008
The battery is 3-volt Number 2032. I was ready to run it over with a Winnebago when I finally discovered that little arrow and figured out that I had to put something into the little opening to release the (very abused after I tried to pry it off with a knife) battery cover.
Posted on Jun 03, 2010
Me too. I've been trying for hours to get it open. Anyone?
Posted on Jul 31, 2008
Instructions for braun thermoscan plus
check this link it is for all..... Braun Thermometer Owner Manual ManualsOnline com
go down and change model....
Oct 01, 2012 | Braun Health & Beauty
What is the flashing horn signal on braun thermoscan
It looks like a horn it is actually a picture of the thin plastic cover that goes over the end before you put it inside the ear. Put the cover on and it will work.
Sep 25, 2012 | Braun IRT3020 Thermoscan Ear Thermometer
4 year old braun thermoscan IRT4520 having some problems
is the drawer that its stored in, in the bathroom? the humidity or moisture could affect it. I have had mine for 8 yrs and works perfectly. Are you placing the probe covers on correctly and waiting for it to click or a pop before inserting into ur ear.?
Jul 03, 2012 | Braun IRT3020 Thermoscan Ear Thermometer
How do I go about removing the batteries in my HM3 thermoscan?
Replacing the batteries - Using the tip of a ball-point pen, press the battery door lock to open the battery compartment - Using your finger, press the battery release - Remove the batteries and replace with new batteries, making sure the poles are in the right direction - Slide the battery door in until it snaps in place
May 17, 2011 | Braun IRT3020 Thermoscan Ear Thermometer
I need to open the thermosacn plus to replace the battery. can't seem to get it opened. i know this sounds funny bey, how do i do that?
If the back cover won't come off, try spraying a little (!) WD-40 on a Q-tip, then rubbing the oil around the edge of the cover. If you don't have WD-40, try olive oil.
Apr 04, 2011 | Braun IRT3020 Thermoscan Ear Thermometer
I have a Thermoscan HM1 and am getting error code 2. I need to know what it is and how to fix it. Thanks.
2 says patient temperature out of range. the error codes are in the case. Usually where the probe covers are stored. take them out to look at the codes.
Jan 15, 2011 | Braun Thermoscan Thermometer Probe Covers
RIM BlackBerry  Pearl  8100 Logo
1,147 people viewed this question
Top RIM Computers & Internet Experts
ismael castillo
David
Martin Murray
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
