Question about Canon PIXMA MP830 All-In-One InkJet Printer
Vertical line on page
I have a Canon Pixma MP830. Recently, a vertical line started appearing on copies. I think I've cleaned everything that can be cleaned, but I must be overlooking something.
I do not get the line on the page when the copy is on the platen (as opposed to the ADF). Any ideas?
  • 1 more comment
  • annlsussman Jun 19, 2008
    I appreciate the quick response however, when I try to go to that website, it comes up "page not found."
  • greg3482 Jul 16, 2008
    everytime i make a photocopy of anything a black line appears on the bottom, how do i stop this.
  • Howard Goffen Aug 04, 2008
    I found out what was causing the vertical line on the page when copying. I called Canon, and even though I was out of warranty, they did not charge me for the call. First, lift up the lid to access the glass platen. Note on the left side the lock and unlock switch. Immediately to the right of that button and between the glass platen there is a glass narrow strip. Take a soft very very slightly damp cloth and wipe the area. When I initially looked at that area I didn't see anything, but upon closer inspection, I saw that there was a very fine vertical smudge. After wiping the area with a very damp cloth, the vertical line went away. Good luck to all.
I have the same problem although its a horizontal line
Posted on Jul 16, 2008
Problem making copies (not print from my computer)
Does the line show up when you copie from the bed of the scanner or from when you send it through the auto feeder or both? Check the glass for any small mark and remove it if you find one and try again. Its more then likely a mark on teh glass somewhere.
Jun 30, 2010 | Canon PIXMA MP830 All-In-One InkJet...
My canon MP830 produces a thin vertical black line on documents fed through the document feeder to be copied or faxed. This only happens using the document feeder.
The expert told me to run a porous piece of paper through the adf 10 to 15 times. I used a piece of Avery textured paper for notecards that I had. The problem was solved after about 5 runs through.
Mar 19, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Red vertical lines, scanning to computer
I had one red line appear when i used the duplex. I happened to notice that the thinner glass window on the scanner was dirty. I cleaned it and now no line appears.
Nov 24, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Scan Copy no good
Most likely the document scanner has gone bad. I'm not sure, but I think you may have to replace the entire scanner assembly and not just the scanner itself.
Canon parts are not cheep. Call a Canon shop and get a price on a replacement scanner unit.
Nov 02, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Streaks on faxes and copies but not on printed documents
Clean the glasses on top!!! Your CORONA lens is dirty!!! it must have some cleaning brush or bar near the side!!!
Jan 20, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Vertical lines through scanned images.
You should clean the small glass under the top lid. Chances are there is some white out or ink or mark on the glass. Look carefully because usually it is just a small dot>
Dec 01, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Vertical Line on copies made from automatic feeder
i just used some dust off spray air on the ADF everywhere that there is an opening to spray. it appears to have helped some...its not perfect yet. hope this helps.
Oct 25, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Canon pixma mp780 - vertical line on printing
Not sure if this will help but there is a small glass panel to the left of your flatbed scanner- this must be clean or else I get a black vertical line in my printing.
Jul 04, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Print Problem - vertical lines
If the problem only occurs when using the document feeder, the problem is not usually caused by the drum. When using the document feeder, try to notice where the scanner (the light assembly under your scan glass)stops just before the paper is being fed. Some multifunction machines have a small piece of glass that is separate from the large scan glass and the scanner assembly stays parked underneith it as the original is being fed over it. Most likely there is something on the glass where the scanner parks as originals are being fed thru the feeder. When putting your original on the large scan glass to copy, the mark on the glass will only show as a spot, but will show as a vertical line thru the whole copy when using the feeder.
Feb 23, 2007 | Brother MFC-7820N Laser Printer
Canon PIXMA MP830 All-In-One InkJet Printer Logo
318 people viewed this question
old marine
old marine
