Question about Dryers
It seems i have to keep re drying clothes they come out amp have just put new vent on in may keep lint trap cleaned but have to run the load 2 or 3 times to dry.
  • 246 Answers
If you've made sure you have good air flow (you can feel air pressure on your hand where you dryer vents to the outside), try cleaning your moisture sensors. As you put your head inside the dryer drum, look on the rear wall or directly back towards where your lint screen is (depending on the manufacture and model). There should be 2 silver bars. These can get a coating on them over time and cause the machine to "think" the mositure is gone and shut itself off. Run the rough side of a sponge or a fine grit sand paper back and forth across both of them. Let me know if this takes care of it or if the problem persists, send me back your make and model.
Posted on Jun 20, 2008
Csn you remove trap where lint filter goes
How To Clean Your Dryer's Lint Trap, Screen And Vent ...
greenlivingideas.com/2014/08/14/clean-dryers-lint-trap-duct-screen/
Aug 14, 2014 - Cleaning your dryer's lint trap, screen and vent is a great way to keep it using energy efficiently. ... (Of course, if you can hang your clothes to dry, you'll not have to go ... Now use the vacuum to remove any lint from the lint trap.
Stackable Dryer-Lint Screen-Where is it? - YouTube
? 3:09
https://www.youtube.com/watch?v=-qu0OF9V2vA
Dec 27, 2011 - Uploaded by OcRefrigeration & H.v.a.c.
This Video Shows Where a " Lint Screen " is in a Stackable Washer Dryer and How to Remove it. Clean it ...
How to Clean a Dryer Lint Screen ' Cleaning Guides
www.howtocleanstuff.net > Cleaning Guides
Jan 11, 2016 | LG DLE5001W Dryer
Clothes are not drying as fast as before. Lint trap is not collecting ling.
venting issue. check vent tube for restriction. A quick way to know if it is external is disconnect vent tube run a load of clothes if they dry well then it is the tube, if it is the same then it is internal and the dryer will need to be disassembled and cleaned from the lint trap back. Good Luck Tim
Nov 29, 2010 | Maytag Centennial 7.0 Cu. Ft. Super...
Samsung dryer DV448AEP/XAA - lint buildup
Yes this is rellatively normal as clothes are just not made the same way any more. You could turn down the drying temperature slightly and put in an anti static drying sheet but it won't make that much difference.
Oct 13, 2009 | Samsung Dryers
Dryer not dring clothes completely
need to check your vent duct. if clogged it won't let the air flow through the dryer needed to dry your clothes.
Jun 24, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer isn't getting as hot as it should, clothes take twice as long to dry
clean out your wall vent,dryer hose and lint trap that should do it,what happens if you have a clogged vent the dryer keeps the wet hot air in loner and it take twice as long to dry-mike
Apr 20, 2009 | Dryers
My dryer is not drying properly. It takes 2 cycles to get clothes dry. I have cleaned the lint traps and vents but that did not seem to help. Is it worth fixing or is it time to get a new dryer?
You need to check the blower compartment to see if there is a restriction in airflow, also check the thermostat on the system as well. Where the stat is located is brand specific. Check your wiring diagram that is typically stored somewhere near the electronics on the inside in an envelope.
Apr 18, 2009 | Dryers
My lint trap has very little lint.
Older clothes do not produce as much lint as new ones. Also, if your dryer isn't getting as hot as it used to, then you won't get as much lint either. Does it seem to take a bit longer to dry your clothes? Also, check your dryer vent, if the airflow is reduced, the amount of lint that is expelled through the filter will deminish as well. You may have a build up of lint in the vent ducting to the outside that is restricting airflow.
Apr 08, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Kenmore Elite Heavy Duty Dryer 11063012101 Takes Forever to Dry
I think your vent has lint in the line between the wall and the outside of your house not allowing the moisture to get out
FIX
1 when the dryer is running go outside and observe the vent to see if hot air is coming out
2 Turn dryer off, disconnect electric from wall
3 pull dryer out from wall
4 take a nut driver or screw and remove the clamp that attaches the flex vent pipe to the wall
4 Also remove the flex pipe from the dryer
5 Inspect inside vent connection inside dryer for any trapped lint
6 inspect inside flex line for any lint
7 Look inside wall vent for lint you can also reach in with your hand to feel for lint
8 If you have a leaf blower or can borrow one(electric is best) from your neighbor put the snout of the blower into the vent going into the wall seal the area between the snout and the vent pipe at the wall ( i use duct tape you can use wash clothes rags etc
9 start blower and blow any lint in the line out through outside THIS WILL CLEAR THE LINT
10 Reattach the flex to the wall vent and dryer , plug in. run a load and you should be back in business
Good Luck
Jan 04, 2009 | Kenmore 63012 Electric Dryer
My whirlpool duet dryer is taking 3 cycles to dry????
have you checked your lint trap to make sure that it is clean after every load? Also the lint vent to the outside may be clogged and will not let the dryer vent like it should. This is dangerous. So check and replace if needed.
Dec 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Plugged venting causing low heat and poor lint output?
you need to check the dryer vent hole on the back of the dryer,make sure it's not blocked,also check the wall vent for the same thing,most of the time if there is a clogg it holds the moisture in the dryer and it take forever to dry,you can use a shop vac to **** out any clogged lint in dryer and wall ,then if you have a leaf blower put it on the wall side and blow it it all out.let me know how you do-mike
Oct 30, 2008 | Dryers
Dryers Logo
Top Dryers Experts
