Question about GE Kitchen Ranges
Model. jtp35wom1ww serial.AR6 18302Q. Double Oven will not heat properly. Takes 40 minutes to heat to 350.
  • 77 Answers
Check to see if Lower element is red after 5 minutes. if not you are just heating on the broil unit at 110 volts (1/4 of its full watts), may never get much hotter than 300 that way. if bake isn't red it may need to be replaced.
Posted on Jun 20, 2008
Oven heats very slowly
15 minutes until the signal beeps? completely normal, BUT it will take up to 45 minutes for any oven to properly preheat COMPLETELY.
Mar 18, 2014 | Thermador C302U Electric Double Oven
Frigidaire gallery stove
Hello Debbie - Sounds like the unit has loss some of its heat inside of the oven cavity. This means it cannot reach the proper preheat temperature in the programmed 30 minute timeframe. A technician would be required to further diagnose this concern. They would most likely assess the convection heating element, thermal cutout, thermal oven sensor and all wired connections for repairs. Lastly the oven cavity and insulation should be checked to ensure there are no gaps or damages that will leak out the heat. At t his time, I would recommend contacting a professional to assist you further.
May 24, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
IT TAKES A LONG TIME TO REACH 350 DEGREES ON MY JGB920 GE STOVE
most likely you have a bad ignitor,remove the racks,remove the floor to the oven,remove the flame spreader,put the oven on 350,if the flame doesn't lite within 40 seconds you have a bad ignitor.i looked up your model number,it shows a round ignitor but when i look up the part number it shows a flat ignitor,call your local parts store,give them the full model number that's on the machine,open the bottom draw,look at the left or right side of the frame around the draw opening not on the draw and you'll see the model and serial numbers,give them the full model number and they will give you the correct ignitor,let me know how long it takes before the flame lites
Nov 29, 2010 | GE Profile Spectra JGB920 Gas Kitchen...
Ge gas oven not working
thermocoupler needs to be replaced...
Dec 12, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
My HBL452 double oven is slow to heat both upper
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Dec 01, 2009 | Bosch HBN 452 / HBN 456 Electric Double...
I have a gaggenau 194/195-610 Double oven that takes 25 minutes to preheat to 350%. Is there a quick diagnosis for this problem or do I need a repair service. These ovens have never really worked properly.
It could be a faulty stat or element, an engineer will be able to test them for you
Also he will make sure the cooker is wired properly at the cooker point (correct flex et.)
Sep 21, 2009 | Gaggenau EB294/295 Electric Double Oven
Oven won't reach proper temperature and hold
If the element glows its ok , if you have replaced the sensor with a new one it can only be the control board. in some cases you can adjust the temp. through the control , it should list directions to do so in the manual. Good luck
Dec 30, 2008 | Kenmore 91112 / 91114 / 91117 Electric...
Kenmore oven - Not heating up
Check the BACK of your temperature knob for an adjustment. I was ready to replace my heating elements when I accidently discovered the adjustment. Made the adjustment and no more problems. My oven now stays within 4 degrees of settings.
Aug 25, 2007 | Equipex PZ-330 Electric Single Oven
Kitchen Ranges Logo
98 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
