Question about Karcher 2500 PSI Pressure Washer
Karcher K3.92 M 1750 PSI poweer Washer motor won't start. Followed Reset/Test/Reset sequence with cord plugged directly into outlet. Light on cord near Reset comes on when Reset pressed down but goes off when Reset released (Normal?) Switch ON and trigger pressed releases water stream but no motor action.
  • Anonymous Mar 17, 2014
    My karcher 210 is leaking from somewhere inside near the water outlet hose connection, only when the trigger is pulled and the motor runs intermitantly. please can you helpMany thanksMartin
  • 3 Answers
They are sensitive to large extention cords. My father in laws pops reset when a small cord is used. If internally shorted- motor will continually pop the reset even plugged direct to outlet. Check voltage at outlet.
Posted on Jun 20, 2008
Karcher electric pressure washer help starting
The test / reset buttons are for a Ground Fault Interrupter built into the cord / washer. This device will help prevent deadly electric shock in the event of a malfunction - it is the same technology used in "GFI" electrical outlets located in bathrooms, outdoors, basements, etc.
You should have this serviced - or replaced before using.
Sep 18, 2015 | Karcher Garden
Is there a fuse on model no jvm1540dn1ww
There should not be a fuse on your washer- what is usually the problem here you have a reset button the power cord- also be sure to check if you are plugged to a GFI circuit-
if this is the case unplug the power cord-
reset the GFI outlet (wall plug)-
plug your power cord back into wall-
and push in the reset button-
TY,
perrytradesman
Aug 13, 2014 | Karcher 2500 PSI Pressure Washer
Kracher power washer won't turn on
Sure that the outlet you are using is powered? Is power reaching the motor? - I had my power switch on my karcher break internally rendering machine dead. If power is reaching the motor for sure and it does not run then there has to be an open motor winding. If pump jammed you would hear a humming noise from motor and the breaker would pop.
Aug 26, 2017 | Washing Machines
I has a Crosley Washing Machine Top Loader. Fill light comes on lid locks then NOthing!
seethis causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this time
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the hom
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Oct 02, 2012 | Crosley CCW5294W Top Load Washer
Electric pressure washer will not start
CLEAN FRESH WATER IS IMPORTANT FOR THESE PUMPS, I ALWAYS USE A HIT OF ARMOR ALL IN THE PUMP AFTER USE . YOU MIGHT SEE IF IT'S GETTING POWER TO THE MOTOR MIGHT HAVE A BAD GFIC ? PLUG IT IN PICK UP THE UNIT AND TRY DROPPING IT FROM A FOOT OFF THE GROUND, THIS JAR MIGHT SHOCK IT BACK TO LIFE ?
. Jay the pool pump whisperer FLORIDA 32750
Sep 21, 2012 | Karcher K5.540 2,000 PSI 1.4 GPM Electric...
It won't start. when I push the test reset button it attempts to come on for a second then nothing. I changed outlets and same thing happens. before I did this the water would come out of the nozzle...
Had a similar problem with a Karcher that I own, after a little troubleshooting it turned out to be the big plug end with the reset in it, I took the plug end apart and found the contacts inside had melted thus not allowing proper contact of the reset button, I opted for a cheap way out, instead of ordering a replacement reset plug assy i changed it over to a regular 3 prong gfi plug end, been working great the past few seasons,hope this helps
Aug 12, 2011 | Karcher Pressure Washer 1800 PSI 15 GPM...
When i operate the switch on my karcher pressure washer the power wash does not operate.
But water comes out the end right? just under hose pressure only I bet. I have one of these units and every time I think it has gone bad I manage to find the problem. This unit not only has the switch on the front that needs to be on but it also has a safety switch on the plug where it plugs into a wall or extension cord. The last time I thought mine had gone bad it had actually blown the fuse. the unit was plugged into an outside outlet via extension cord. It just so happens that that is an GFCI outlet. I think the wife got water on the extension cord and that caused it to blow. So check:
The power switch on the front The safety switch on the cord, The outlet it is plugged into
Usually, for us, it is the button on the cord when it is plugged into an extension cord it always gets the test button bumped which shuts it down.
Aug 22, 2010 | Karcher 1750 psi Electric Pressure Washer
New Karcher pressure washer won't start
replace the fuel carburetor filter and, or, your fuel tank filter
Aug 31, 2009 | Karcher 2500 PSI Pressure Washer
Reset Button
your testing the no fault short or motor overload feature. the red light indicates you have power. no light no power.
Apr 02, 2008 | Karcher 2500 PSI Pressure Washer
Karcher 2500 PSI Pressure Washer Logo
619 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
