Question about Saeco Vienna De Luxe Espresso Machine
You cannot see the drain because it is behind the axle that drives the group, but you can feel it if you stick your finger in and down to the right.
Hello, can you tell me the place..i can not imagine where it is...
thankyou
  • 515 Answers
It is behind the brewing unit, when you take out the brewing unit then you can see the hole in the chassis
Posted on Jul 11, 2008
My Jeep Cherokee Laredo 1993 suddenly started making loud noise and steering got tight after driving it hard
the fluid for the power steering has ran out...fill it.usually located in the dashboard, near the steering wheel....
Oct 15, 2014 | Cars & Trucks
Water is pouring from the dispenser drawer, how do I fix this
First check the drain hose behind the machine. It must not enter more than 4" to prevent siphoning situation. If that looks okay check for a sock or similar item between basket and tub. They seem to like to stick close to the dispenser drawer when they get in there and often cause the symptom you are describing. Make sure to check the drain hose between tub and drain pump for objects. When checking pump basket, stick a finger in and feel around the propeller of the pump. If it feels at all wobbly or bent to one side the pump may need to be replaced. If that doesn't solve your problem you may want to check this video:
http://www.youtube.com/watch?v=SFEQsJ-vLxw
It's a bit more involved and i about went to sleep listening to the guy but he's informative.
Good Luck.
Jan 07, 2013 | Kenmore HE2 Plus Front Load Washer
How to remove c lock to slide axle out of 2004 grand cherokee
To remove the c clip, you need to remove the shaft that retains the spider gears. Depending upon which design you have it's held in either by a bolt or roll pin at one end. Once the shaft is out, be careful rotating the carrier as the spider gears tend to lag behind and can fall out. I usually stick my finger into the shaft hole and turn the driveshaft very slowly till I can access the clip.(turn too fast or hard and it can hurt your finger though) To remove the clip, after the shaft is out, just push the axle in and the clip will come right out.
Jun 06, 2011 | 2004 Jeep Grand Cherokee
Where is the bolt drain transmission of toyota corolla ve 98
There are two plugs. The drain plug you will see by looking at the tranny from driver side near the drive axle. The fill plug is the one you stick your finger in and is somewhere below the clutch slave cylinder. Undo them with a 24mm socket. And yes, open the fill plug first. For diagram, click the link below:-- http://technoanswers.blogspot.com/2011/05/where-is-transmission-drain-bolt-on.html --------- this should help.thanks.Helpmech.
May 29, 2011 | 1998 Toyota Corolla
Oil change 2001 softail
From the right side of the bike, look at the very lowest point of the oil tank. Back behind it is a hose that runs down behind the transmission and comes out down below the clutch release mechanism, that chrome cover on the right end if the transmission. The hose goes right down by the frame and behind the exhaust system. It either has a metal plug in the end of the hose or the hose connects to a crossmember of the frame. If it's connected to the crossmember, feel on the underside of the crossmember and you should feel a drain plug. Drain the oil and refill the tank with three quarts of 20W50 oil.
Good Luck
Steve
Apr 03, 2011 | Harley Davidson FLSTF Fat boy Motorcycles
My washer will not drain
Hello there:
I would check the drain pump for a clog. Remove the front panel of the washer, the pump is at the front bottom right side, with 2 hoses attached. Now either get the water out of the tub with a shop vac, or pinch off the hose connecting the tub to the drain pump. Take the top hose off, and stick your finger down the hole and feel for anything. also you can stick a screw driver down the pump and see if the impeller moves freely...
Read more: http://forum.appliancepartspros.com/washer-repair/8486-ge-washer-will-not-drain-spin.html#ixzz10rBUaUUw
Sep 28, 2010 | GE Washing Machines
Driving on interstate, ac working fine....then not blowing air. Still cold, just not moving
your drain is not draining properly, it is located on the drivers side. The best way to get to it is on a lift. You can get to it on ramps but it is not easy. once it is off the ground go head first from the drivers side, make sure you let the exhaust cool. There is a 3/4" hole on the firewall, to the left of the accelerater bolt(passenger side). There are two lines running down and about four that are snapped on above the hole, you will have to unsnap two of them. The nipple is about 3/4" down and towards the right(drivers side) if you lay on your right side and stick a finger in there you can feel it. Pipe cleaners should do the job. It is not easy believe me
Aug 09, 2010 | 2004 Mitsubishi Endeavor
I have oil leaking from my rear-right wheel. It seems to be coming from the rear dif. Is there a seal at the wheel?
yes theres a seal from the axle shaft, but theres a also your brake cylinders. to find that you need to remove the tire and check the brakes or check the brake fluid reservoir for low fluid. either way you need to remove the tire. if its your axle seal then the pin theres pins on the actual differential to remove the axle shaft. a little more complicated. check the axle shaft to wear from the seal and bearings. also check the diffrential for a good level or you will loose the diffrential if you keep on running it. the level check is on a plug like half way that ususally removed by hand or a ratchet then stick your finger and if you dont feel it put oil on,. the proper oil level is when you can feel the oil with out sticking in a rod or stick in there. hope this helps
Aug 01, 2010 | 1994 Toyota Pickup
Can not locate duckbill drain on 05 Endeavor Passenger side of firewall
I assume you are referring to the AC drain.
It is located on the driver side, just toward the center from the gas pedal.
From the outside, you will not be able to see it. It is located in a box in the frame and does not protrude all the way out.
You need to be underneath the vehicle to reach it at all.
On the frame right where the brake line packs turns from horizontal to vertical is a hole roughly 1" in diameter. Facing the vehicle, the drain is in that hole, 1/4" down and 1/2" to the right.
You can feel it if you stick your little finger in the hole so that your finger bends down a little.
If you have an AWD endeavor, this is even more difficult to reach, and should be left to someone with a lift to put the vehicle in the air.
Oct 31, 2009 | 2004 Mitsubishi Endeavor
Saeco Coffee maker container is leaking
OK, I finally called Saeco. There are about four rubber rings that you need to get. The one for the water resevoir is a big thick black ring and once you get it and look at the new and the old, you can see why it is leaking. Anyway, fixes it no problem.
The overflow in the drip tray? There are two rings in the back of the machine that will fix that problem. Problem? I got them, but haven't put it on there because it very hard to get in there.
Last one, the ring around the coffee puck maker (what do you call that part) It's the piston that catches the coffe and raises up to tamp it down, then holds it as the water goes through. ANyway, big ring around that. If you aren't getting a nice crema on top, that ring will cure that.
I saw get all four, replace them all at once and then descale the coffee maker and be done with it. You'll be working like new in a few hours or maintenance. For most of us, it's been like 3 years anyway, time to do it.
Lastly, when you call Saeco, (Pronounced I found our SA Yey Co) ask for the directions for cleaning out the grinder. Even has notes on how to get it back together with all the adjustments in the right spots.
The rep on the phone says she likes this model better than most fo the new ones.
Nov 07, 2007 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna De Luxe Espresso Machine Logo
16 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
Mike Cairns
Mike Cairns
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
