Question about Peavey CH1 Speaker
Floor monitors Peavey
We had the monitors on the front of the pulpit and they just stop working. The were in line with the ceiling speakers there about 5yrs old, but still what could it be
  • 476 Answers
Can you tell me how every thing was set up,
Head unit/desk
amp/s
speaker configurations
power supply and room area
thanks
Posted on Jul 21, 2008
I have a Peavey mk VI bass head that has stopped working. It powers up and the fan works but nothing comes out. I've checked the cabling to the speaker cab.
Unfortunatly it could be a number of different things, and without the amp in front of me, I'd be shooting in the dark I suggest taking it into a Peavey repair center. Here is a link to the service locater page-
Peavey com
Feb 25, 2015 | Peavey Music
How do i hook up monitors to peavey 8300 mixer
Make sure main monitor switch is pressed in, look at back of unit, the speaker jack labeled main/monitor is now monitor output, you may use 2 8 ohm speakers, use controls on front labeled monitors.
Jun 27, 2012 | Peavey XR 8300 8 Channel Powered Mixer
I have recently acquired an XR600B . I printed out the documentation. Conversely to what I have seen answered here, it looks to me like they are suggesting the best/most powerful output will be acheived...
The speaker connections are on the BACK and are "Speakon" connectors... These are special plugs and these apparently can also accept 1/4 inch plugs. It appears that the MINIMUM impedance should be no less than 4 ohms, NOT 2 ohms. One of the back connectors is for the mains, the other ois for the monitor soeakers. The FRONT connections are line level which doi NOT drive speakers,
Jun 13, 2011 | Peavey Xr 8600 8 Channel Powered Mixer
I purchased a PV12M monitor and was wanting help connecting it to my Behringer xenyx 2442fx mixer
You will have to have an amplifeir between them since the PV12M is an unpowered speaker. The Xenyx 2442FX is likewise an unpowered mixer meaning it cannot directely drive a speaker. You will wire with a balanced line (TRS cable) between the 2442 and the amp and then from the amp to the speaker using a speaker type cable.
Jun 06, 2011 | Peavey Pv12m 12' Floor Monitor
I want to use both speaker outputs for loudspeakers on my Peavey 8600 without splitting the watts. How do I hook up monitor speakers in this situation? Can another mixer be patched into the front? I have...
Sorry, but this unit does NOT support "bridged" mode. You will have to drive seperate speakers from the two seperate outputs. You would NOT get any more power if you could do bridged mode than you could with 4 ohm speakers on each of the two output channels.
Nov 27, 2010 | Peavey Xr 8600 8 Channel Powered Mixer
Hi, I would to say thanks a lots to let put some words on yours email box. It's just regarding about how to set up a live band gigs @ outdoor stage in to mixer system. In a mixer setting, i wana know how...
You will need at least a 24 channel mixer to give you spare channels. You also need an active crossover and a snake. The advice you need is too much to include here so I am including some links:http://mixonline.com/live/FixIts/, http://en.wikipedia.org/wiki/Live_sound_mixing, http://mixinglivesound.com/blog/tag/outdoor-concerts/,http://mixinglivesound.com/blog/, and http://www.scribd.com/doc/11435651/Beginners-Guide-to-Mixing-Sound. You may need more monitors than you are planning on and you might consider in ear monitoring.
Aug 22, 2010 | Music
Wish to run sm450v2 Mackie powered speakers thru a Peavey XR8600
The Peavey XR8600 is NOT just an amp, but a powered mixer.
To SAFELY use this with your powered speakers, connect those speakers to the MAIN and MONITOR outputs on the front of the unit with 1/4 inch INSTRUMENT rated cables (NOT speaker cables).
To safely leave the power amps in the XR8600 with no output loads, plug GROUNDING plugs into the POWER AMP 1 and 2 input jacks on the front. This will prevent the power amps in the XR8600 from running with no load which COULD damage them.
Make the grounding plugs from 1/4 inch mono plugs by jumpering the centr aand sleeve terminals of the plug.
Jul 09, 2010 | Peavey Audio Players & Recorders
Karaoke, plenty vocals in floor ,no music without loud humming
Try a couple things
Try plugging the player directly into one of the stereo channels using correct cables (just go to Radio Shack or someplace like that) - you'll probably have to get a stereo to mono "Y" adapter that terminates in two mono mini or 1/4 inch male jacks ... if mini, then upsize them with another adapter ... it's not as rigged as it "sounds" ...
The benefit is, it is actually simpler and you will be able to use all of the channel strip controls for the player just as you would for a mic or guitar plugged in to a channel, and the volumes will behave more as you expect them to ...
Just be absolutely sure the cable you assemble is correct, meaning stereo single 1/4" (or whatever it is, two RCA's whatever) going into the player, and terminating on the other end with two MONO 1/4 inch jacks ...
I use this kind of "Y" connector to play my iPhone through my 808s and it works very well, and I have full control and no confusion.
I'm not sure what you mean by running your player through the "aux in" on the front of the 808s - there are different versions of this mixer, but mine doesn't have anything labeled "aux in" - if you mean the tape inputs on the right front ... RCA jacks ... that should also work, but I prefer just using the normal input channels ...
For example, use input 8 - it's labeled "mic 8" - but if you use the two 1/4" jacks above the Canon jack the mixer will automatically adjust to line level ... on my 808s these 1/4" jacks say "stereo mic/line" ...
Also, I would bypass the effects section completely unless you need it and understand how it works ... and
Make sure the "Power Amp Routing" switch is in the correct position ... since you are using mains and monitors you probably want the "mono" position, which disables the stereo outputs and instead uses one of the power amps for the mains and the other for the monitors ... on my 808s this is the "in" position
On the back, you'll use the speaker outputs labeled "left/main" to go to the main speakers and "right/monitor" to go to the monitor speakers
It's actually pretty simple - with the Power Amp Routing switch pushed in, you no longer have stereo, so ignore "left and right" on those speaker outputs, and follow the labels for "main" and "monitor" .....
Hope that helps!
For audio expertise and PA system help with feedback and noise, try our new DVD "PA Systems for Small Groups" at www.rexark.com
Jan 30, 2010 | Bob Mackie SRM350 Main / Stereo Speaker
Mic feedback. I sing on a shure beta 58 mic, into a 350 watt peavey amp, into 2 - 200 watt peavey speakers. My band is loud, and I simply cannot get my mic loud enough for them to hear me, without constant...
It sounds as though you are pointing the peavey at the band in a practice situation? If so make sure that each speaker is at about 60 degree angle to either side of the back of the mike (you facing the speakers), most mics reject feedback when the the user is directly in front of a monitor, but Beta 58s' tend to feedback more in that situation. Alternatively (if it is a practice room situation), why not place the speakers behind the band at 60 degrees each and turn to face the band.
Mar 12, 2009 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
Peavey floor monitor speakers
you can bypass the volume controller and use the master control. just take out the volume controller and splice the wires from there straight to master control.
Feb 23, 2009 | Audio Players & Recorders
Peavey CH1 Speaker Logo
119 people viewed this question
Top Peavey Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Michial Gueffroy
Are you a Peavey Audio Player and Recorder Expert? Answer questions, earn points and help others
