Question about Lexmark Office Equipment & Supplies
Lexmark 6170: Copier does not work. Paper is pulled half-way into the copier, copier arm moves across the underneath of the glass, but then nothing happens.
  • 48 Answers
Check if any particles have fallen inside the printer...
Try to move the cartridge carries manuelly....move the roller...
Turn the printer up side down and shake it well but be carefull
Posted on Jun 19, 2008
Why do we have blank copies on Xerox XC830?
is it problem when you try to copy vis adf or its aucord in platen glass also?
Sep 17, 2012 | Xerox Office Equipment & Supplies
Lexmark X-6170 instalation to my desktop comp.
There are Lexmark X6170 drivers available for download in the Lexmark website. Just click on this link: http://bit.ly/b0XDka. Printer only works with Windows operating system. No drivers for Macintosh unfortunately. Choose the correct driver compatible with the version of your computer's operating system. Download and install the software. Hope this helps but if you need more assistance, just leave a comment and I'll get back to it. Thanks.
May 19, 2010 | Lexmark X6170 All-In-One InkJet Printer
Fine line running from left to right across page but fades about half across page to nothing, if you print from memory no line, if you run origional thru adf no line, What is causing this line when...
if it is copied on long or legal size of paper are the fine lines on top to bottom or left to right? if it id from top to bottom check for the charge roller, clean an dry it with a cloth, wet with alcohol or water. if from left to right on a legal size of paper check for any vibration coming from the developing unit, like loose gears.
Mar 05, 2010 | Ricoh Aficio 450 Copier
Has stripes going down it when scanning or faxing this to paper or pc and ect is it light or deeper thing Lexmark X5150 aio Lexmark X5150 aio Lexmark X5150 aio
Lift the cover where you place originals to scan / fax, and clean the narrow scanner glass underneath. There are simply some specs of dirt that when the original is scanned across them, they show up as lines
Jul 28, 2009 | Lexmark X5070 ALL-IN-ONE InkJet Printer
Auto Feed doesn't work. When I press the start button I get an error to open the copier and remove the paper. There is no paper above the glass. The symbols showing are LIFT and PAPER JAM.
There is a mircoswitch which may become slightly bent. The microswitch rides on the left hindge of the feeder inside the covers. When the start button is pressed the feeder may move upward slightly causing the miroswitch to loose contact with the hinge. You can usually reform the arm of the switch and make it work.
Jul 16, 2009 | Canon NP 7130 Black and White Copier
Paper will not feed from drawer
Pull the paper tray out of the machine. On the right side underneath you should see a rubber paper feed roller. Clean this off with a slightly damp cloth until it is "squeaky clean". Also, look about to be sure there is nothing blocking the paper path. Sometimes paper gets torn off and left in the machine when clearing a jam.
Apr 21, 2009 | Canon PC-941 Copier
Check Document
Look at the sensor arms on the feeder cover...open feeder,and take it off from the sides..there are little wings that pop out of socket, and look at the black toggle arms... one most likely is dislodged...make sure they all toggle freely...ckeck the one towards the bottom first...if you have to , take screws out and pull cover apart to re-insert toggle arms....
Aug 28, 2008 | Canon imageCLASS MF6530 Monochrome Laser...
Feeder crunching up paper
I have the same printer. Have you cheked the paper path for the document feeder to make sure there is nothing in the way. Like a label, a torn piece of paper, etc. It really sounds like there is something in the paper path.
Jan 14, 2008 | Lexmark X6170 All-In-One InkJet Printer
Line Across Page
There could be something on the scan glass. You have to open the cover on the scanner and look across the scanner glass. It is only about a half to an inch wide strip that the original passes over.
If there is nothing on that glass then some of the segments in that array have gone bad and it would need to be replaced.
Dec 20, 2007 | Lexmark X4270 All-In-One InkJet Printer
Will not scan
With the power off & the machine unplugged, remove the scan glass & move the scanner a few inches from "home" position. Plug in & turn on machine. Does the scanner return to home position? If not, you either have a bad scanner motor or scanner cable. I'll look for you to post the results of the scanner drive test.
Jun 19, 2007 | Canon PC-1080F Copier
37 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
