Question about Compaq Presario S6300NX PC Desktop
Sound Card - Microphone for Internet Calling
Where do I plug the cable into the computer
  • 4,472 Answers
You are talking about the little 3.5mm jack on the end of the microphone? That plugs into the back of your computer and it should be the pink ring on your sound card.
If that is not what you meant. Please describe further and I will be happy to assist you.
Thanks,
Lee
Posted on Jun 19, 2008
I am 80 and living alone...doing OK but people say they cannot hear me. Could you please help me locate the microphone on my SCEPTRE X9W? Thank you
Hello Ron
The Sceptre X9W is a computer monitor with an amplifier and speakers. Unfortunately, it does NOT have a microphone. You would need to buy a cheap microphone and plug it into the sound card on the back of the computer.
The Specifications on your monitor are here.
SCEPTRE X9WG NagaV Black 19 34 8ms Widescreen HD Ready LCD Monitor 300 cd...
You can pick up a microphone like this for 10 bucks at Walmart
Omni Directional Condenser Computer Desk Microphone Walmart com
Sep 02, 2017 | Sceptre Computers & Internet
Tip
How to play guitar using a computer
<p>Playing a guitar using a PC at home is a simple process that some audio devices and a computer to an analog line or microphone port on your sound card to obtain. There are two kinds of freeware, that a user can provide to the task. Basic freeware that standard on any Windows computer, including audio drivers free, microphone input, even if the computer's speakers to play. Users to make recordings of your own burning freeware, however, were interested in Windows freeware called "Sound Recorder" can do the work in the most elementary sense. <br /> <p><br /> <p>1. Plug the Phono-style audio cable into the guitar phono audio jack. <br /> <p><br /> <p>2. Connect the large to small-RCA adapter to the end of the other side of the RCA cable. <br /> <p><br /> <p>3. Connect the adapter cable and phono large on the back of the computer through a computer microphone. <br /> <p><br /> <p>4. Adjust audio properties of the system from the Start menu and Control Panel of your computer to play audio into the microphone port on the speaker. The exact process of adjusting the settings may be proprietary software, the sound card came with the computer system vary. If you have problems, ask the help documentation for software and manual for your computer sound. On most systems, the microphone volume level using the properties menu of the extended microphone system sound settings. <br /> <p><br /> <p>5. Set the switch to the guitar pickup - the pickup is a version of power - the "on" position. Adjust the volume on the computer so the computer speakers clearly the natural sound of the guitar can be heard. <br /> <p><br /> <p>6. Play a few notes on the guitar. If your computer speakers to play the guitar sound, the method proved unsuccessful. <br />
on Jun 22, 2011 | Computers & Internet
ConnectLand cl-me 606 goose neckdesktop microphone to desktop
Look for a 3.5 mm microphone port on the computer. Usually the port on the back of the desktop will have a pink surround. (There will be other ports there; the usual minimum are the green port for speakers and blue one for line-in.) Put the 3.5 mm jack on the end of the cord on the microphone into the port. If you have an add-in sound card, use the microphone port on the sound card.
Some machines will also have a front panel microphone port. This will have a small mike icon next to the port.
Next you need to ensure that the audio device is set to Microphone. For Windows systems (Vista/7/8), enter the Control Panel and go to the Hardware and Sound panel. Click on Manage Audio Devices under Sound. Then click on the Recording tab. Check if the microphone listed as plugged in. Make this the default recording device. (XP has a slightly different name for the panel.) For XP through Windows 7, click on the start button and then find the Control Panel listed on the right. For Windows 8, from the desktop, press the Ctrl and X keys at the same time. Then find the Control Panel in the list. (Alternatively, activate the Charms menu, Ctrl+C or hover on the upper right of the screen. Move down and click on the gear (Settings). Then select the Control Panel.)
If the computer doesn't indicate that the microphone is plugged in, make sure that the 3.5 mm plug is in the correct port. Next try the microphone on another computer. The audio card port could be damaged or the microphone cable could be faulty. If the microphone works on another computer, you can try a USB audio adapter (StarTech ICUSBAUDIO or similar) or a new sound card. (Note: some older sound cards do not work properly on newer versions of Windows. If you have a sound card installed and the motherboard has an on-board audio device, remove the sound card. Enable the on-board audio in the computer's BIOS. Install the appropriate audio drivers. Try that audio device. Accessing the BIOS will depend on computer. Often you can press Esc, F1, F2, F10 or Delete repeatedly after you turn on the computer. If Windows starts to boot, turn off the system and try again.) If another computer doesn't recognize the microphone, I'd recommend a new microphone. Fixing the cable isn't worth the effort.
I hope this helps.
Sep 20, 2013 | Computers & Internet
The microphone on my ic014c webcam won't work!
if the microphone has a second cable with a jack plug ..than you have to use it in the pink inlet on the sound card ..and will work ..or in the mic in of the laptop ..
If there is no second cable (split cable ) with jack plug ..it means the mic is using the usb ..and in this case you have to get to the sound settings and select the usb for the mic ..Also select the usb for each instant messaging programs you use..to d that just open the program ...get to the tool options ..and select sound devices and under mic select the usb instead of regular windows default or sound driver ..
Dec 23, 2011 | Computers & Internet
I am unablem to use the mic for the internet chat!!!!
First of all find the latest version of the audio driver which is compatible to vista, as most of the drivers that are shipped with sound-card or motherboard cd contain drivers which have support for only until windows Xp.
So it is strongly recommended to download the latest audio driver from the internet for your sound-card or on board audio chipset. Install the vista compatible audio driver (sound driver) for your sound-card or motherboard audio. After this re-start your computer. Half of the work is done.
Now plug in the microphone in your sound-card / motherboard audio pin (generally pink in color for microphone).
After this go to control panel > sound and audio device settings. Check whether the microphone is detected by Vista or not. If not, check whether you have selected the frontal microphone or rear, as vista recognizes them separately unlike windows Xp. Correct the configuration of front/rear mic if needed.
Nov 16, 2010 | Computers & Internet
Mic wont work of course
which operating system do you use? and check the sound driver from { if windows,right click my computer then click manage then device manager, see there is sound driver is installed or not.} if not then install sound driver.
Apr 29, 2010 | Cyber Acoustics CVL-1064 Consumer...
Feedback sound
If moving the microphone doesn't work then suspect "microphonics" where a loose electronics component is vibrating and acting as a microphone. Could be cable. Unplug all microphone cables, still feedback? Right click speaker icon, sound properties, temporarily disable computer sound input devices. If still feedback then analog section of sound card (or motherboard sound chip) or your speaker system.
Oct 15, 2009 | Altec Lansing Multimedia Computer Speakers
My microphone dosnt pick up any sound
Vista always has sound card problem.
I had too because with my headset (microphone) It works through your sound card
but it works well now after I installed it as below
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=US&swItem=ob-78911-1
ADI SoundMAX Integrated HD Audio Driver for Windows Vista
I am using Vista 32-bit, Logitech Clear Chat Style
Hope can help
Aug 24, 2009 | Logitech Internet Chat Consumer Headset
Usin for an internet conference
You need to buy a Computer Calling Kit from Polycom. That is essentially a cable with a 2.5mm connector to the Polycom Soundstation 2W on one end and two 3.5 mm connectors to the PC Sound card end (one to the Microphone port and the other to the Speakers port).
Mar 08, 2009 | Polycom SoundStation 2W (2200-07800-001)...
Sound and microphone problems
check for proper drivers for your sound card it will solve you problem....
Sep 14, 2008 | Dell Inspiron E1505 Notebook
Compaq Presario S6300NX PC Desktop Logo
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
